I thought I’d write a piece about my thoughts on the best hardware to use for your IoT projects if you’re just starting-out with Blynk.
I did what many people do, started-off buying an Arduino Uno and uploaded some code to make it flash an LED. After about 10 seconds of watching the LED flash I was bored, and wanted to do more (I have a short attention span
The next task was getting the Uno connected to the internet and I chose the Ethernet Shield route. After around 6 months of messing around with the Ethernet shield (I’m also very persistent
) and experiencing regular problems, especially when the Uno was restarted, I decided that the Ethernet shield had to go.
I started looking at alternatives and came across the ESP-01, so ordered one, but while I was waiting for it to arrive I realised that the ESP range of boards could also be programmed via the Arduino IDE using basically the same code as the Uno. After a bit more research I decided that the NodeMCU board was worth investigating, so ordered one of those and pretty soon the Uno was gathering dust.
After a while I switched to using the Wemos D1 Mini (not to be confused with the Wemos D1, which is basically a Uno with an ESP-01 chip attached) and that’s now my “go-to” board for all of my IoT projects. I use this board because it works well for the type of projects that I do, and it obviously won’t be the best choice of board for everyone.
I’ve chosen to compare 5 basic boards which are readily available ‘mainstream’ products that should be on the shortlist for an IoT beginner. These are (left to right in the photo below):
- Arduino Uno
- Arduino Mega
- ESP-01
- NodeMCU
- Wemos D1 Mini
I also give a mention to the Wemos D1 Mini Pro, mostly because I’m now drifting towards using this as my day-to-day board.
There are other boards available, including the ESP32 (which will probably become the preferred choice of board for many in the future) and some slightly less mainstream boards like the ones from Adafruit and Particle. There is also the Raspberry Pi, but in my opinion the Pi is better suited to being a local Blynk server than a client device.
However, when it comes to simplicity and ease of learning for newcomers, I think you’d be better limiting your choice to one of these 5 (or 6 if you include the D1 Mini Pro) as your starting point. These boards are all fairly cheap and readily available, so you can usually get up and running fairly quickly. If you decide you want to try less mainstream alternatives in future then what you’ve learned using one of these boards will provide you with valuable knowledge and experience.
I’m not going to discuss Bluetooth/BLE or USB serial connection methods, as I don’t think these have a real role in most IoT projects, so I’m going to assume that you want a board that is Wi-Fi capable - either with native Wi-Fi support or by using an ESP-01 as a Wi-Fi modem.
Here’s a table showing the main features of of these 5 (okay, it’s 6 really) boards:
| MCU | Memory | Clock Speed | Logic Voltage | GPIO Pins | Analogue Pins | Approx Cost (USD) |
| Arduino Uno | 32 KB | 16MHz | 5v | 14 | 6 | $3.00 |
| Arduino Mega | 256 KB | 16MHz | 5v | 54 | 16 | $8.50 |
| ESP-01 | 512 KB - 4MB | 80MHz/160MHz | 3.3v | 2 | 0 | $1.60 |
| NodeMCU | 4MB | 80MHz/160MHz | 3.3v | 11 | 1 | $2.30 |
| Wemos D1 Mini | 4MB | 80MHz/160MHz | 3.3v | 9 | 1 | $2.10 |
| Wemos D1 Mini Pro | 16MB | 80MHz/160MHz | 3.3v | 9 | 1 | $3.60 |
Prices are based on a quick search of AliExpress and based on buying one board. I’ve gone for the sellers who offer free postage (to the UK) and chosen to use the universal currency of US Dollars. Delivery times tend to be quite long when buying from AliExpress, Bangood or Chinese sellers on eBay and if you’re like me you want it, and you want it NOW, which means you’ll probably pay more to buy from a local retailer selling on eBay.
Here’s a quick summary and Pros and Cons of each device (as I see them):
Arduino Uno
The Uno is the standard entry point for many people wanting to dabble with microprocessors, but its main disadvantage is that it has no way of connecting to the internet without adding either an Ethernet shield or a Wi-Fi modem (usually an ESP-01), so in its standard form it isn’t an IoT device.
The Ethernet shield is notoriously unreliable, and hooking-up to an ESP-01 has a few pitfalls that can catch beginners out.
Advantages
16 GPIO and 6 Analogue pins
5v logic levels (can also be a disadvantage)
Can be programmed via the Arduino IDE
Disadvantages
No Ethernet or Wi-Fi connectivity without additional hardware
Limited memory
Slow processor speed
OTA not available
Physical size
Arduino Mega
The big brother of the Uno, it still has many of the Uno’s disadvantages. The main plus points are more serial ports, which makes adding an ESP-01 Wi-Fi modem simpler, and a bit more memory. It obviously has more GPIO and Analogue pins, but seriously, how many do you need on one device? (I’ll discuss this more later).
Advantages
54 GPIO and 16 Analogue pins
4 Serial interfaces (UARTs)
Disadvantages
Limited memory (better than the Uno, but still low)
OTA not available
Physical size (even bigger than the Uno)
Higher price
ESP-01
The ESP-01 is often used with the standard “AT” firmware to act as a serial modem for an Arduino Uno or Mega, bit it actually has more processing power and memory than either of these Arduino devices.
The ESP-01’s main feature is that it’s tiny, so can be used to add IoT capabilities to existing hardware.
Advantages
Physical size
Can be updated using OTA (the 1mb and 4MB versions are better for this)
Can be programmed via the Arduino IDE (after installing an add-in)
Disadvantages
Lack of available GPIO pins
No Analogue pin
3.3v logic levels (can also be an advantage)
Pin layout can be difficult to work with
No on-board serial to USB adapter, so needs a separate USB (FTDI) adapter to be able to flash code to the device
GPIO0 needs to be manually pulled low when flashing code to the device (except if OTA is used)
Several different variants with different memory sizes, can be difficult to know what you have
NodeMCU
The NodeMCU ought to be the entry point for anyone wanting to experiment with IoT. It is easy to work with, has built-in Wi-Fi connectivity and enough memory to handle most sketches and still be able to be updated via OTA.
Advantages
Built-in Wi-Fi modem
Large memory and fast processing speed
Physical Size
Disadvantages
The two rows of pins are too far apart to work well with most breadboards
Fewer GPIO pins than the Arduino boards (and care needs to be taken when choosing which pins to use)
Only one Analogue pin
Pin numbering can be confusing
Wemos D1 Mini / Pro
This is really a variant of the NodeMCU on a slightly smaller board. Fewer GPIO pins are available, but the narrower distance between the two rows of pins makes it easier to use with breadboards. There is also a large range of ‘shields’ that can be used with these boards.
The Pro version has an external antenna connector. To use this a surface mount zero ohm resistor has to be re-soldered in a slightly different position. The Pro also has more memory, but this can’t be utilised in most situations.
Advantages
Same as NodeMCU except the smaller board works better with breadboards
Wide range of accessories that use the same format
The Pro version can be used with an external Wi-Fi antenna for extra range
Supplied with no pins soldered in place, so has greater flexibility (also a disadvantage?)
Disadvantages
Same as NodeMCU plus:
Fewer GPIO pins than the NodeMCU
Basic soldering skills required
GPIO and Analogue Pins - Do the Numbers Matter?
General Purpose Input/Output (GPIO) pins are used to connect digital input devices like sensors and output devices like relays. Generally, one GPIO pin is needed per sensor/relay, as the other side of the circuit is connected to ground.
Analogue pins are used when it’s necessary to measure the voltage that’s being received from a sensor.
You might think that things like temperature and humidity sensors would output analogue values, but that’s not the case with modern sensors. Virtually everything now is digital, as it provides a much more stable and interference-free way of communicating between devices.
Many modern sensors are multi-functional, so something like the BME280 can measure temperature, humidity and atmospheric pressure using a single sensor and one GPIO pin.
This meas that you don’t really need many GPIO pins to build a fairly sophisticated device. Something like a thermostat with a digital display could need:
- 1 GPIO for the sensor
- 1 GPIO for a relay to turn the heater on/off
- 2 GPIOs for an OLED display
- 3 GPIOs for an auto/manual switch and up/down temperature buttons
A total of 7 GPIO pins to build a fairly sophisticated thermostat unit.
Okay, I hear you say, but I want to measure outside temperature as well, and maybe wind speed, rainfall, and light levels; and I want to open and close the garage doors, turn the garage lights on automatically and measure the temperature in the garage as well.
That’s all fine, but you wouldn’t use a single microprocessor to do all of those things. There would be a separate one on the roof acting as a weather station, and another one in the garage making sure your car is nice and cozy. Rather than running a rats nest of wires to a single control point with one microprocessor board, you’d have a dispersed system - with a separate microprocessors performing a dedicated range of tasks.
I actually have 9 different microprocessors in my living room. Some of these are built-in to Sonoff S20 type sockets that control lighting, or are built-in to RGB controllers that also control lighting. Others take temperature readings, transmit Infrared signals to devices, transmit and receive 433MHz radio signals or control a touch screen display. Having all of these controlled by one microprocessor device isn’t practical because it would mean running wires between each sensor or item that is being controlled. By using dispersed ESP8266/NodeMCUs that are controlled via Wi-Fi makes for a very neat solution, but each of these microprocessors only uses two or three of its available GPIO pins to do its dedicated task.
Edit May 2020 - another alternative to solving the problem of needing more GPIOs is to use a port expander such as the MCP23017 and that’s covered in detail in this topic:
I mentioned earlier that care needs to be used when choosing which GPIO pins to use on a NodeMCU or Wemos D1 Mini. There is more on that subject in this topic:
GPIO Voltages - 3.3 or 5 volts?
The Arduino Uno and Mega, along with most of the other Arduino variants, uses 5 volt logic levels for its GPIO pins. This means that setting one of the GPIO pins HIGH will result in 5v being applied to that pin. When signals are passed between sensors then these signals will switch between 0 and 5v at high speed.
The ESP98266/NodeMCU devices (including the Wemos) operate at 3.3v logic levels. It’s been shown that these devices can tolerate having 5v applied to their GPIO pins, when connecting them to sensors that output a 5v logic signal, but it’s generally regarded as a ‘do it at your own risk’ approach.
However, most modern sensors are compatible with both 3.3v and 5v boards, so can be used without risk of damaging anything. All modern boards use 3.3v logic, so at some point you may find that it’s the Arduinos that are incompatible with the newer sensors.
If you do need to convert between 3.3v and 5 logic levels then it’s very easy using a simple board like this, which costs around $0.50
I’ve only needed to use one of these once, to interface a RFID card reader to a Wemos D1 Mini for my door entry system (more on that below).
GPIO Pin Numbering on the NodeMCU/Wemos D1 Mini Boards
One thing that catches many people out when they start experimenting with NodeMCU/Wemos D1 Mini type boards is the strange pin numbering that the manufacturers adopted. Don’t ask me why they did it, we just have to be aware of it and live with it.
They pins have numbers like D1, D2, D3 etc and it’s logical to assume that these represent GPIO1, GPIO2 and GPIO3, but these pins are actually GPIO5, GPIO4 & GPIO0.
You need a diagram like this close to your desk when you’re wiring things up:
What is OTA, and Why Does it Matter?
I’ve mentioned OTA in my comparison of various devices, and some newcomers may not be aware of what it is and why It’s so useful.
OTA stands for Over The Air, and is basically a way of flashing new code to your board without having to physically touch it. The new code is sent via Wi-Fi, so the board could be in an inaccessible place, or in a piece of hardware that requires significant disassembly to reach the board and plug a USB cable into it.
OTA requires a few add-ons to be installed on the computer that is running the Arduino IDE and a few extra lines of code to be added to the sketch that’s uploaded to the board when you first program it. After that, the board appears as a virtual port in the IDE and a new sketch be pushed out to it without even having to leave your chair.
The new sketch is uploaded to the board alongside the old sketch, then the board reboots and the new
sketch is used. For this reason, the board needs at least 50% of its memory to be available, so ESP-01s with 512KB of memory don’t really have enough memory for OTA. The 1MB versions are okay if you have a fairly basic sketch that you want to upload.
OTA only works with ESP8266 based boards (this includes the ESP-01, NodeMCU and Wemos boards). It can’t be used with Arduino boards, or ESP-01 that are being uses as a Wi-Fi modem for an Arduino.
A Bit More About Wemos Accessories
There are a wide variety of accessory ‘shields’ that can be used with the Wemos D1 Mini/Pro range of boards, including double and triple bases, relays, OLED displays, sensors, switches, motor control shields, MicroSD card readers, prototyping boards etc.
These can either be stacked piggyback style on top of each other (the boards come with a variety of different connectors and you have to put some thought into the type of connectors you solder to the boards if you want to use them this way) or they can be positioned side by side on the double or triple bases. (You could actually do both - stacking and side by side - if you wish).
Here’s a picture of the door entry project I mentioned earlier. Wemos D1 Mini Pro (with external antenna connected) on the left, relay in the middle, and a prototyping board with the logic level shifter and a voltage regulator circuit on the right. All plugged-in to a triple base, giving the ability to easily swap components out if needed.
I do have a few situations like this one where I need to attach an external antenna to a Wemos board, so I’m tending to order batches of the Pro version of the board so that I have the option to add an antenna to any of my boards if I need to.
So, Which Board Should You Choose?
Everybody will have different requirements and priorities, and you should choose a board that is the best fit for the project(s) you have in mind.
If you want to monitor the voltages on a bank of 30 batteries, which will need lots of analogue inputs, then the Arduino Mega is probably your best bet.
If you want something tiny that will fit inside your existing smoke detector to turn it into a smart detector then probably the ESP-01 is the best choice.
If you’re doing a school or university project and your teacher has told you that you must use an Arduino Uno then take your teacher on one side and tell them that “Uno’s are SO not cool” (or whatever that translates to nowadays).
For someone who just wants to buy a board that can be used as a test-bed, but which can ultimately be used as the MCU in a serious project then the NodeMCU or Wemos D1 Mini is what I’d recommend.
I’m sure there’ll be dozens of people who chip-in with differing views, and there will probably some who may agree as well. What’s important is that you choose a board that’s right for the project you have in mind, and hopefully this thread will help to narrow-down the choices and make an informed decision.
If you’re still confused just buy a Wemos D1 Mini (or two) ![]()
