Yes, I use the D1 Mini Pro, they work fine.
You say:
In your photo, the zero ohm resistor hasn’t been moved, so attaching an external antenna will make absolutely no difference - the built-in antenna (the white ceramic thing with “Rainsun” written on it) is what’s being used.
Sure! they are the obvious choice, when an external antenna is needed. And as @PeteKnight had pointed ONLY THEN the 0ohm resistor needs to be MOVED (or replaced with simple solder shunt)
And your issue… I don’t know. It connects to WIFI, obtains IP, and then can’t reach host. DNS issue??
When I look closely at the circuit board near the antenna and do some tests with my ohmmeter, it seems that the antenna is isolated from everything else. So removing 0 ohm resistor will desable internal antenna but not sure it’s enough fot activating external intenna. Don’t we need to connect the 0 ohm resistor or some jumper to extenal antenna ?
So thank you for these clarifications but first of all and whatever the antenna chosen i should be able to connect to blynk. Isn’t it !
@zener In Arduino IDE choose:
Tools/Board/Boards Manager.
Scroll down towards the bottom of the list and find “esp8266 by ESP8266 Community” and tell us what version you have installed.
If it’s anything higher than 2.4.2, downgrade to 2.4.2 and recompile/upload your code and tell us what happens.
