Hi All
I’m using my wio link + grove temp humidity and blynk, following post WIO Link with Blynk and Blynk with Seeed Wio Link? and this Blynk + wio link
My sketch is:
http://twitter.com/blynk_app
This example shows how value can be pushed from Arduino to
the Blynk App.
WARNING :
For this example you'll need Adafruit DHT sensor libraries:
https://github.com/adafruit/Adafruit_Sensor
https://github.com/adafruit/DHT-sensor-library
App project setup:
Value Display widget attached to V5
Value Display widget attached to V6
#include <DHT.h>
char auth[] = "78692b97ec314bxxxxxxxxxxxxxxxx";
char ssid[] = "Encona AP4";
char pass[] = "3112159010";
#define DHTPIN 14 // What digital pin we're connected to
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
Blynk.begin(auth, ssid, pass, "192.168.88.100", 8442);
dht.begin();
And result in my console :
Failed to read from DHT sensor!
Thanks in advance!
