Node - Configuration - The configuration node can be “enable” or “disable” now, when disabled no connection is start on boot and all linked node show the red dot “disabled” status.
Node - Image Gallery - New node to simplify the use of this new widget (set images urls is not yet implemented in app)
Node - Set Property - Implemented “url, urls, opacity, rotation, scale” property for Image Gallery widget (blynk cloud or local server >= v0.39.4) [NOTE: url and urls property are not yet supported in app]
Check SLL certificate on connection for blynk cloud
Changed
All nodes - Conversion, where necessary, of “isBuffer” checks into “isArray” checks
All nodes - Avoid input processing on client node disconnected or disabled
Node - zeRGBa - Check if a valid RGB value is passed, otherwise it will generate an alert and the message will be discarded
Node - Table - It will generate an alert on a simple payload without other parameters and the message will be discarded
Increase heartbeat timeout to 15 seconds - see Blynk Server Issue #1294
Compatibility with Blynk Library 0.5.4
Fixed
Node - Write - Now it accepts multiple values as input via arrays and forwards them to the server correctly - see this
Is there a simple tutorial how to use it? I have no idea how to start, even I am not new in HA or Blynk (but I haven’t done anything new in the last period with blynk since all my new projects are on HA).
I have ESP8266 HVAC control (well not the last version) and I would like to see desired and actual temperature, change the desired temperature and turn the heater on and off in HomeAssistant via NodeRed. Can anyone help me how?
@NvAriec start a new topic and explain your issue in detail, with screenshots and any other relevant information, and we’ll help you to resolve the problem.
