hello @John93! thank you for your prompt reply. i’ve replaced all “atoll” with “atol” & the error still persists.
Arduino: 1.8.19 (Mac OS X), Board: “Arduino Uno WiFi Rev2, ATMEGA328”
BlynkParam:16:10: fatal error: Blynk/BlynkConfig.h: No such file or directory
#include <Blynk/BlynkConfig.h>*
compilation terminated.
exit status 1
“Show verbose output during compilation”
option enabled in File → Preferences.
#ifndef BlynkParam_h
#define BlynkParam_h
#include <string.h>
#include <stdlib.h>
#include <Blynk/BlynkDebug.h>
#define BLYNK_PARAM_KV(k, v) k "\0" v "\0"
#define BLYNK_PARAM_PLACEHOLDER_64 "PlaceholderPlaceholderPlaceholderPlaceholderPlaceholderPlaceholder"
#if !defined(BLYNK_NO_FLOAT)
extern char* dtostrf_internal(double number, signed char width, unsigned char prec, char *s);
#endif
#if !defined(BLYNK_NO_LONGLONG)
extern long long atol_internal(const char *s);
#endif
class BlynkParam
public:
class iterator
public:
iterator(const char* c, const char* l) : ptr(c), limit(l) {}
static iterator invalid() { return iterator(NULL, NULL); }
operator const char* () const { return asStr(); }
operator int () const { return asInt(); }
const char* asStr() const { return ptr; }
const char* asString() const { return ptr; }
int asInt() const { if(!isValid()) return 0; return atoi(ptr); }
long asLong() const { if(!isValid()) return 0; return atol(ptr); }
#if !defined(BLYNK_NO_LONGLONG) && defined(BLYNK_USE_INTERNAL_ATOL)
long long asLongLong() const { return atol_internal(ptr); }
#elif !defined(BLYNK_NO_LONGLONG)
long long asLongLong() const { return atol(ptr); }
#endif
double asDouble() const { if(!isValid()) return 0; return atof(ptr); }
float asFloat() const { if(!isValid()) return 0; return atof(ptr); }
#endif
bool isValid() const { return ptr != NULL && ptr < limit; }
bool isEmpty() const { if(!isValid()) return true; return *ptr == '\0'; }
bool operator < (const iterator& it) const { return ptr < it.ptr; }
bool operator >= (const iterator& it) const { return ptr >= it.ptr; }
iterator& operator ++() {
if(isValid()) {
ptr += strlen(ptr) + 1;
return *this;
private:
const char* ptr;
const char* limit;
public:
explicit
BlynkParam(const void* addr, size_t length)
: buff((char*)addr), len(length), buff_size(length)
explicit
BlynkParam(void* addr, size_t length, size_t buffsize)
: buff((char*)addr), len(length), buff_size(buffsize)
const char* asStr() const { return buff; }
const char* asString() const { return buff; }
int asInt() const { return atoi(buff); }
long asLong() const { return atol(buff); }
long long asLongLong() const { return atol_internal(buff); }
long long asLongLong() const { return atol(buff); }
#endif
double asDouble() const { return atof(buff); }
float asFloat() const { return atof(buff); }
#endif
bool isEmpty() const { return *buff == '\0'; }
iterator begin() const { return iterator(buff, buff+len); }
iterator end() const { return iterator(buff+len, buff+len); }
iterator operator[](int index) const;
iterator operator[](const char* key) const;
void* getBuffer() const { return (void*)buff; }
size_t getLength() const { return len; }
size_t getBuffSize() const { return buff_size; }
// Modification
void clear() { len = 0; }
void add(int value);
void add(unsigned int value);
void add(long value);
void add(unsigned long value);
void add(long long value);
void add(unsigned long long value);
#ifndef BLYNK_NO_FLOAT
void add(float value);
void add(double value);
#endif
void add(const char* str);
void add(const void* b, size_t l);
#if defined(ARDUINO) || defined(SPARK) || defined(PARTICLE)
void add(const String& str);
#if defined(BLYNK_HAS_PROGMEM)
void add(const __FlashStringHelper* str);
#endif
#endif
template<typename T, typename... Args>
void add_multi(T last) {
add(last);
void add_multi(T head, Args... tail) {
add(head);
add_multi(tail...);
template <typename TV>
void add_key(const char* key, const TV& val) {
add(key);
add(val);
void remove_key(const char* key);
protected:
char* buff;
size_t len;
size_t buff_size;
class BlynkParamAllocated
: public BlynkParam
public:
BlynkParamAllocated(size_t size)
: BlynkParam(malloc(size), 0, size)
~BlynkParamAllocated() {
free(buff);
inline
BlynkParam::iterator BlynkParam::operator[](int index) const
const iterator e = end();
for (iterator it = begin(); it < e; ++it) {
if (!index--) {
return it;
return iterator::invalid();
inline
BlynkParam::iterator BlynkParam::operator[](const char* key) const
if (!strcmp(it.asStr(), key)) {
return ++it;
++it;
if (it >= e) break;
inline
void BlynkParam::remove_key(const char* key)
bool found;
do {
found = false;
const char* key = it.asStr();
++it; ++it;
const char* next = it.asStr();
memmove((void*)key, next, (buff+len)-next);
len -= (next-key);
found = true;
break;
++it;
if (it >= e) break;
} while (found);
inline
void BlynkParam::add(const void* b, size_t l)
if (len + l > buff_size)
return;
memcpy(buff+len, b, l);
len += l;
inline
void BlynkParam::add(const char* str)
if (str == NULL) {
buff[len++] = '\0';
return;
add(str, strlen(str)+1);
inline
void BlynkParam::add(const String& str)
#if defined(ARDUINO_AVR_DIGISPARK) \
|| defined(__ARDUINO_X86__) \
|| defined(__RFduino__)
size_t len = str.length()+1;
char buff[len];
const_cast<String&>(str).toCharArray(buff, len);
add(buff, len);
#else
add(str.c_str());
#endif
inline
void BlynkParam::add(const __FlashStringHelper* ifsh)
PGM_P p = reinterpret_cast<PGM_P>(ifsh);
size_t l = strlen_P(p) + 1;
return;
memcpy_P(buff+len, p, l);
len += l;
buff[len] = '\0';
#endif
#endif
#if defined(__AVR__) || defined (ARDUINO_ARCH_ARC32)
#include <stdlib.h>
inline
void BlynkParam::add(int value)
char str[2 + 8 * sizeof(value)];
itoa(value, str, 10);
add(str);
inline
void BlynkParam::add(unsigned int value)
char str[1 + 8 * sizeof(value)];
utoa(value, str, 10);
add(str);
inline
void BlynkParam::add(long value)
ltoa(value, str, 10);
add(str);
inline
void BlynkParam::add(unsigned long value)
ultoa(value, str, 10);
add(str);
inline
void BlynkParam::add(long long value) // TODO: this currently adds just a long
add(str);
inline
void BlynkParam::add(unsigned long long value) // TODO: this currently adds just a long
add(str);
inline
void BlynkParam::add(float value)
char str[33];
dtostrf(value, 5, 3, str);
add(str);
inline
void BlynkParam::add(double value)
char str[33];
dtostrf(value, 5, 7, str);
add(str);
#endif
#else
#include <stdio.h>
inline
len += snprintf(buff+len, buff_size-len, "%i", value)+1;
inline
len += snprintf(buff+len, buff_size-len, "%u", value)+1;
inline
len += snprintf(buff+len, buff_size-len, "%li", value)+1;
inline
len += snprintf(buff+len, buff_size-len, "%lu", value)+1;
inline
len += snprintf(buff+len, buff_size-len, "%lli", value)+1;
inline
len += snprintf(buff+len, buff_size-len, "%llu", value)+1;
#if defined(BLYNK_USE_INTERNAL_DTOSTRF)
inline
char str[33];
dtostrf_internal(value, 5, 3, str);
add(str);
inline
char str[33];
dtostrf_internal(value, 5, 7, str);
add(str);
#else
inline
len += snprintf(buff+len, buff_size-len, "%2.3f", value)+1;
inline
len += snprintf(buff+len, buff_size-len, "%2.7f", value)+1;
#endif
#endif
#endif
#endif
