How do i make a button in blynk to control a set of Function such as Auto light or manual light
Actually to use a Widget to control a Blynk function would be this example as a basis⦠it uses a slider, but a button or other control widget would work as well
@Al3xRud3r you should start reading through these Help Pages and the Documents for more Blynk info⦠but have you decided on the hardware and connection type you want to use?
yes im just going to use my arduino mega 2560 r3 with ESP-01 i fixed the bug with cant find ESP8266_Lib.h, i had an add-on code in C:\Program Files (x86)\Arduino\libraries that messes with it
i make the program that allows to use a slider to control what auto ph would like, iām not going to share it because i went thru hell to do it⦠sorry
Did someone ask for your code??? I donāt see that post anywhere
But speaking of not going through a lot of effort writing some code to just hand out copies to the unwashed masses⦠good thing I donāt think that way
