BLYNK
BLYNK.IO       📲 GETTING STARTED       đź“— DOCS       👉 SKETCH BUILDER
How to connect Arduino Uno WiFi Rev2 to Blynk.Cloud
I cannot connect my Arduino UNO WiFi Rev2 to Blynk.Cloud. I tried the code in Connecting Arduino UNO Rev2 WIFI to blynk app, but it didn’t compile. So I tried this code :
 #define BLYNK_TEMPLATE_ID   "*****************"
#define BLYNK_DEVICE_NAME   "***********"
#define BLYNK_AUTH_TOKEN "************************"
/* Fill-in your Template ID (only if using Blynk.Cloud) */
#include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
char auth[] = "**********************";
char ssid[] = "********";
char pass[] = "*************";
but it gave me this error :
Arduino: 1.8.16 (Mac OS X), Board: "Arduino Uno WiFi Rev2, ATMEGA328"
In file included from /Users/warrickcleet/Documents/Arduino/libraries/Blynk/src/Blynk/BlynkApi.h:36:0,
                 from /Users/warrickcleet/Documents/Arduino/libraries/Blynk/src/BlynkApiArduino.h:14,
                 from /Users/warrickcleet/Documents/Arduino/libraries/Blynk/src/Adapters/BlynkWiFiCommon.h:24,
                 from /Users/warrickcleet/Documents/Arduino/libraries/Blynk/src/BlynkSimpleWiFiNINA.h:22,
                 from /Users/warrickcleet/Documents/Arduino/Working/Working.ino:35:
/Users/warrickcleet/Documents/Arduino/libraries/Blynk/src/Blynk/BlynkParam.h: In member function 'long long int BlynkParam::iterator::asLongLong() const':
/Users/warrickcleet/Documents/Arduino/libraries/Blynk/src/Blynk/BlynkParam.h:48:50: error: 'atoll' was not declared in this scope
         long long   asLongLong() const  { return atoll(ptr); }
/Users/warrickcleet/Documents/Arduino/libraries/Blynk/src/Blynk/BlynkParam.h:48:50: note: suggested alternative: 'atol'
                                                  atol
/Users/warrickcleet/Documents/Arduino/libraries/Blynk/src/Blynk/BlynkParam.h: In member function 'long long int BlynkParam::asLongLong() const':
/Users/warrickcleet/Documents/Arduino/libraries/Blynk/src/Blynk/BlynkParam.h:89:46: error: 'atoll' was not declared in this scope
     long long   asLongLong() const  { return atoll(buff); }
/Users/warrickcleet/Documents/Arduino/libraries/Blynk/src/Blynk/BlynkParam.h:89:46: note: suggested alternative: 'atol'
                                              atol
exit status 1
Error compiling for board Arduino Uno WiFi Rev2.
I hope you can help.
Yours faithfully
Warrick
First, please edit your post and add triple backticks ( ``` ) before and after your sketch.
Second, I highly recommend you to use a different board.
I flagged this bug with the Blynk developers recently…
UPDATE on how to fix this error…
@Andyy has figured-out how to fix this issue, the solution is to edit the Arduino\libraries\Blynk\src\Blynk\BlynkParam.h file in the library as documented here:
