Time to update this topic with current status and code.
This system basically monitors a simple charge controller that is fed from a couple of solar panels wired in parallel. The App sits on my treadmill and “runs”
24/7 Giving me updates on charge rate, battery voltage, outside temperature & humidity (with a bridge feed to another bench-top project with indoor temp & humidity monitoring) and a history graph of the whole thing so i can look back a recollect how sunny but cold that there day was
And since I also mounted a couple of 1.5 meter RGB strips on the solar panels - One facing outward and the other, wired in parallel, facing upwards to reflect on the windshield and thus inside. I figured I can have a single Wemos D1 Miini, doing multi-duty by controlling them as as well. It is running a FastLED scrolling demo, also 24/7.
I used to have the batteries power the LED strips, but since I doubled them up and let them run all night… these little batterys don’t have the holding power… so for now the LEDs are powered via as AC adapter.
#define BLYNK_MAX_READBYTES 1024
#define BLYNK_MSG_LIMIT 500
#define BLYNK_HEARTBEAT 60
#define BLYNK_NO_BUILTIN // Disable built-in analog & digital pin operations
#include <ESP8266WiFi.h> // For Blynk
#include <BlynkSimpleEsp8266.h> // For Blynk
#include <DHT.h> // For DHT22
#include <Wire.h> // For INA219
#include <Adafruit_INA219.h> // For INA219
#include <ESP8266mDNS.h> // For OTA
#include <WiFiUdp.h> // For OTA
#include <ArduinoOTA.h> // For OTA
// ---------- For RGB Strip ----------
#include "FastLED.h"
FASTLED_USING_NAMESPACE
#if defined(FASTLED_VERSION) && (FASTLED_VERSION < 3001000)
#warning "Requires FastLED 3.1 or later; check github for latest code."
#endif
#define DATA_PIN 13
#define LED_TYPE WS2812
#define COLOR_ORDER GRB
#define NUM_LEDS 90
CRGB leds[NUM_LEDS];
#define BRIGHTNESS 100
#define FRAMES_PER_SECOND 120
#define LED_LIMIT_MILLIAMPS 3000 // Limit current in mA (Must be using FastLED v3.1.1+)
#define DHTPIN 0 // For DHT - GPIO0(D3) on Wemos D1 Mini - DHT22
#define DHTTYPE DHT22 // For DHT
DHT dht(DHTPIN, DHTTYPE); // For DHT
float h, t; // For DHT
Adafruit_INA219 ina219; // For INA219 Current Sensor
float shuntvoltage = 0; // For INA219 Current Sensor
float busvoltage = 0; // For INA219 Current Sensor
float current_mA = 0; // For INA219 Current Sensor
float loadvoltage = 0; // For INA219 Current Sensor
char auth[] = "xxxxxxxxxx";
char ssid[] = "xxxxxxxxxx";
char pass[] = "xxxxxxxxxx";
char server[] = "xxx.xxx.xxx.xxx";
int port = 8080;
int CLK = 0; // void loop() count variable
WidgetBridge bridge1(V43); //Initiating Bridge Widget - For Temp output to Mega
dht.begin(); // For DHT
uint32_t currentFrequency; // For INA219 Current Sensor
ina219.begin(); // For INA219 Current Sensor
Blynk.connectWiFi(ssid, pass);
Blynk.config(auth, server, port);
Blynk.connect();
// Timed Lambda Function - UpTime & void loop() cycle display
timer.setInterval(1000L, []() {
Blynk.virtualWrite(V0, millis() / 60000);
Blynk.virtualWrite(V10, CLK); // Display the void loop() cycles per second
CLK = 0; // Reset the void loop() cycles per second
}); // END Timer Function
// Timed Lambda Function - INA219 Current Sensor function
timer.setInterval(1200L, []() {
busvoltage = ina219.getBusVoltage_V();
shuntvoltage = ina219.getShuntVoltage_mV();
loadvoltage = busvoltage + (shuntvoltage / 1000);
current_mA = ina219.getCurrent_mA();
Blynk.virtualWrite(V4, current_mA);
Blynk.virtualWrite(V3, busvoltage);
// Timed Lambda Function - RSSI display
timer.setInterval(4500L, []() {
Blynk.virtualWrite(V9, WiFi.RSSI());
// Timed Lambda Function - DHT22 Temp & Humidity sensor
timer.setInterval(62200L, []() {
h = dht.readHumidity();
t = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
// Check if any reads failed and try again.
if (isnan(h) || isnan(t)) {
delay(600);
Blynk.virtualWrite(V7, h);
Blynk.virtualWrite(V8, t);
// Timer for MEGA Bridge Data Dump Function
timer.setInterval(63000L, MEGAupdate); // Sending bridge data to MEGA
ArduinoOTA.setHostname("Wemos D1 Mini Solar Monitor - Fast LED RGB"); // For OTA
ArduinoOTA.begin(); // For OTA
// FastLED LED strip configuration
FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
FastLED.setBrightness(BRIGHTNESS); // set master brightness control
} // END Setup Loop
BLYNK_CONNECTED() {
bridge1.setAuthToken("d1e516ca1d8b4d57a172dac786907a90"); // Token for the Mega
Blynk.virtualWrite(V0, "REBOOT");
Blynk.virtualWrite(V5, WiFi.macAddress());
Blynk.virtualWrite(V11, ESP.getCoreVersion());
Blynk.virtualWrite(V12, BLYNK_VERSION);
BLYNK_WRITE(V6) {
if (param.asInt()) {
MEGAupdate();
void MEGAupdate() { // Sending data to MEGA
bridge1.virtualWrite(V43, t);
bridge1.virtualWrite(V44, h);
bridge1.virtualWrite(V47, current_mA);
bridge1.virtualWrite(V48, busvoltage);
// List of patterns to cycle through. Each is defined as a separate function below.
typedef void (*SimplePatternList[])();
SimplePatternList gPatterns = { rainbow, rainbowWithGlitter, confetti, sinelon, juggle, bpm };
uint8_t gCurrentPatternNumber = 0; // Index number of which pattern is current
uint8_t gHue = 0; // rotating "base color" used by many of the patterns
#define ARRAY_SIZE(A) (sizeof(A) / sizeof((A)[0]))
CLK++; // Count the void loop() cycles per second
ArduinoOTA.handle(); // For OTA
gPatterns[gCurrentPatternNumber](); // Call the current pattern function once, updating the 'leds' array
FastLED.show(); // send the 'leds' array out to the actual LED strip
FastLED.delay(500 / FRAMES_PER_SECOND); // insert a delay to keep the framerate modest
// do some periodic updates
EVERY_N_MILLISECONDS( 20 ) {
gHue++; // slowly cycle the "base color" through the rainbow
EVERY_N_SECONDS( 10 ) {
nextPattern(); // change patterns periodically
} // END Void loop
void nextPattern() {
// add one to the current pattern number, and wrap around at the end
gCurrentPatternNumber = (gCurrentPatternNumber + 1) % ARRAY_SIZE( gPatterns);
void rainbow() {
// FastLED's built-in rainbow generator
fill_rainbow( leds, NUM_LEDS, gHue, 7);
void rainbowWithGlitter() {
// built-in FastLED rainbow, plus some random sparkly glitter
rainbow();
addGlitter(80);
void addGlitter( fract8 chanceOfGlitter) {
if ( random8() < chanceOfGlitter) {
leds[ random16(NUM_LEDS) ] += CRGB::White;
void confetti() {
// random colored speckles that blink in and fade smoothly
fadeToBlackBy( leds, NUM_LEDS, 10);
int pos = random16(NUM_LEDS);
leds[pos] += CHSV( gHue + random8(64), 200, 255);
void sinelon() {
// a colored dot sweeping back and forth, with fading trails
fadeToBlackBy( leds, NUM_LEDS, 20);
int pos = beatsin16( 13, 0, NUM_LEDS - 1 );
leds[pos] += CHSV( gHue, 255, 192);
void bpm() {
// colored stripes pulsing at a defined Beats-Per-Minute (BPM)
uint8_t BeatsPerMinute = 62;
CRGBPalette16 palette = PartyColors_p;
uint8_t beat = beatsin8( BeatsPerMinute, 64, 255);
for ( int i = 0; i < NUM_LEDS; i++) { //9948
leds[i] = ColorFromPalette(palette, gHue + (i * 2), beat - gHue + (i * 10));
void juggle() {
// eight colored dots, weaving in and out of sync with each other
byte dothue = 0;
for ( int i = 0; i < 8; i++) {
leds[beatsin16( i + 7, 0, NUM_LEDS - 1 )] |= CHSV(dothue, 200, 255);
dothue += 32;
