What do the BLYNK_DEBUG Codes(output) mean?
I can easily enable the BLYNK_DEBUG function, I get multiple prints in the serial monitor - but what do they mean? I can find no documentation about what the debug statements should be telling me?
EG:
⸮t|⸮⸮ $⸮⸮⸮4⸮2(h⸮[76] Connecting to GoTigers!_2GEXT
[1080] Connected to WiFi
[1080] IP: 192.168.0.45
[1080]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.6.1 on ESP8266
[1156] Connecting to blynk-cloud.com:80
[1501] <[1D|00|01|00] nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn
[1920] >[00|00|01|00|C8]
[1920] Ready (ping: 418ms).
[1920] Free RAM: 48576
[1987] <[11|00|02|00]Hver[00]0.6.1[00]h-beat[00]10[00]buff-in[00]1024[00]dev[00]ESP8266[00]build[00]Feb 13 2020 16:53:32[00]
[2069] <[10|00|03|00|00]
[2136] <[14|00|04|00|0C]vw[00]39[00]393939
[2447] >[00|00|02|00|C8]
[2746] >[14|00|03|00|06]
[2746] >vw[00]4[00]0
What does it mean? Is there a way to interpret this? It’s useless without documentation.
Thnx
billd
Has been a long time since I looked at it but vw i believe means virtual write and the 2 lines ending in 00 and C8 I would say it’s heartbeat.
Most of the stuff you’re seeing here seems to come from the BlynkApiMbed.h library file.
I think the “<” and “>” symbols indicate the direction of the data. “<” means this is data being sent to the server, “>” means data received from the server.
The auth code is being sent to the server.
The server responds with an enumerated BlynkStatus code of C8, which is Hex for 200, which means “BLYNK_SUCCESS”.
These status codes are in BlynkProtocolDefs.h…
BLYNK_SUCCESS                  = 200 [C8]
BLYNK_QUOTA_LIMIT_EXCEPTION    = 1
BLYNK_ILLEGAL_COMMAND          = 2
BLYNK_NOT_REGISTERED           = 3
BLYNK_ALREADY_REGISTERED       = 4
BLYNK_NOT_AUTHENTICATED        = 5
BLYNK_NOT_ALLOWED              = 6
BLYNK_DEVICE_NOT_IN_NETWORK    = 7
BLYNK_NO_ACTIVE_DASHBOARD      = 8
BLYNK_INVALID_TOKEN            = 9
BLYNK_ILLEGAL_COMMAND_BODY     = 11 [B]
BLYNK_GET_GRAPH_DATA_EXCEPTION = 12 [C]
BLYNK_NO_DATA_EXCEPTION        = 17 [11]
BLYNK_DEVICE_WENT_OFFLINE      = 18 [12]
BLYNK_SERVER_EXCEPTION         = 19 [13]
BLYNK_NTF_INVALID_BODY         = 13 [D]
BLYNK_NTF_NOT_AUTHORIZED       = 14 [E]
BLYNK_NTF_ECXEPTION            = 15 [F]
BLYNK_TIMEOUT                  = 16 [10]
BLYNK_NOT_SUPPORTED_VERSION    = 20 [14]
BLYNK_ENERGY_LIMIT             = 21 [15]
The same library file contains enumerated BlynkCmd codes, which see to be how the hardware tells the server what type of instruction its sending…
BLYNK_CMD_RESPONSE       = 0
BLYNK_CMD_LOGIN          = 2
BLYNK_CMD_PING           = 6
BLYNK_CMD_TWEET          = 12 [C]
BLYNK_CMD_EMAIL          = 13 [D]
BLYNK_CMD_NOTIFY         = 14 [E]
BLYNK_CMD_BRIDGE         = 15 [F]
BLYNK_CMD_HARDWARE_SYNC  = 16 [10]
BLYNK_CMD_INTERNAL       = 17 [11]
BLYNK_CMD_SMS            = 18 [12]
BLYNK_CMD_PROPERTY       = 19 [13]
BLYNK_CMD_HARDWARE       = 20 [14]
BLYNK_CMD_HW_LOGIN       = 29 [1D]
BLYNK_CMD_REDIRECT       = 41 [29]
BLYNK_CMD_DEBUG_PRINT    = 55 [37]
BLYNK_CMD_EVENT_LOG      = 64 [40]
So this: [1501] <[1D|00|01|00] nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn is a “1D” command followed by your auth code, which means “Hardware Login”
This: [2069] <[10|00|03|00|00] seems to be a “Hardware Sync” command, which I guess may be triggered automatically, or by a Blynk.sync command in code?
Presumably the virtualWrite commands contain the pin number (in decimal?) and the value sent or received. “vr” will appear when a virtrualRead is performed.
You’ll also see “dw” and “dr” for digital write and read commands, “aw” and “ar” for analogue.
If you figure-out more, based on what your code is doing then please share.
Hi Pete,
Thnaks for the information. I would also have some question. I don’t want to get answer in a certain question, I do want to know the systematic behind it.
For example here is a code:
<[14|05]z[00|09]vw[00]13[00]255
How should I understand the parts?
< means, hardware sends information to the server. it is OK
[14|05] means notification ( BLYNK_CMD_NOTIFY = 14,) which shows, item is not authenticated ( BLYNK_NOT_AUTHENTICATED = 5,) ? is it correct?
Why does Z stand for?
[00|09] means the token is invalid ( BLYNK_INVALID_TOKEN = 9,)?
vw is virtual write, ok
Now I see only one number in the [ ], and another outside. Why? What is the difference?
The commands sent are in hex format, so 14 isn’t BLYNK_CMD_NOTIFY, as that would be sent as a hex value of E
The 15 represents BLYNK_CMD_HARDWARE
As this is a hardware to server message, you can only use values from the second table. This doesn’t contain a 05 value.
To be honest, it’s almost impossible to figure-out any more without more information about your sketch, hardware and app.
I guess you could work out more with a simple sketch that does a number of operations on a timed basis and compare the results with what is happening in your sketch at that point.
