I have been puttering with this one for awhile on a NodeMCU and seperate OLED… and just recently switched to a TTGO ESP32 with built in OLED.
I am using the following parts…
- TTGO ESP32 with integrated 18650 LiPo (holder) and SSD1306 OLED (I2C)
- Nextion 2.4" HMI touchscreen (not using any touch features in this project, thus connected via TX only, so doesn’t conflict with IDE programming)
- BME280 - I2C based Temperature, Humidity and Barometric sensor
And getting weather forcast data from openweathermap.org
I used a simple random() generation to move the OLED display around… as well as blank it out every few seconds to prevent burn-in (I totally killed a smaller OLED wired to an ESP8266 due to static display… very bad burn-in made the display all blotchy and hard to read for other purposes).
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <U8g2lib.h> // For LCD
#define OLED_SDA 5
#define OLED_SCL 4
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R2, OLED_SCL, OLED_SDA, U8X8_PIN_NONE);
#define ARDUINOJSON_ENABLE_PROGMEM 0
#include <Adafruit_BME280.h> //https://github.com/Takatsuki0204/BME280-I2C-ESP32
#include <ArduinoJson.h> //https://github.com/bblanchon/ArduinoJson
#define ALTITUDE 23.0 // Altitude in my location
String CityID = "xxxxx"; // My city location
String APIKEY = "xxxxx";
char auth[] = "xxxxxxxxxx"; // Local Server
char ssid[] = "xxxxx";
char pass[] = "xxxxx";
char server[] = "xxx.xxx.xxx.xxx";
int port = 8080;
#define I2C_SDA 17
#define I2C_SCL 18
#define LED_PIN 16
#define BME280_ADDRESS 0x76 // If the sensor does not work, try the 0x77 address as well
float temperature = 0;
float temperature2;
float humidity = 0;
float pressure = 0;
int weatherID = 0;
int iterations = 1800;
String weatherDescription = "";
String weatherLocation = "";
char* servername = "api.openweathermap.org"; // remote server we will connect to
String result;
int Counter = 0;
int antiBurn;
Adafruit_BME280 bme(I2C_SDA, I2C_SCL);
WidgetLED led2(V5);
/// ========== Images Start ==========
// Thunder cloud
#define pic_3_width 57
#define pic_3_height 32
static unsigned char pic_3_bits[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf8, 0x01, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0xfe, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff,
0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x07, 0x3e, 0x00, 0x00, 0x00,
0x00, 0x00, 0xc0, 0x03, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x01,
0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x00, 0xe0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x78, 0x00, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7c, 0x00,
0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x00, 0xc0, 0x01, 0x00, 0x00,
0x00, 0x00, 0x0e, 0x00, 0xc0, 0x01, 0x00, 0x00, 0x00, 0x00, 0x0e, 0x00,
0xc0, 0x01, 0x00, 0x00, 0x00, 0x00, 0x0e, 0x00, 0xc0, 0x01, 0x00, 0x00,
0x00, 0x00, 0x0e, 0x00, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x00,
0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3c, 0x00, 0x78, 0x00, 0x00, 0x00,
0x00, 0x00, 0xf8, 0xff, 0x3f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf0, 0xff,
0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfe, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3c, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
// Sunny
#define pic_4_width 57
#define pic_4_height 32
static unsigned char pic_4_bits[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x7c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7c,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3c, 0x7c, 0x70, 0x00, 0x00, 0x00,
0x00, 0x00, 0x7e, 0x7c, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7e, 0x7c,
0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfc, 0xff, 0x7e, 0x00, 0x00, 0x00,
0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x83, 0x0f, 0x00, 0x00, 0x00,
0x00, 0x00, 0xe0, 0x01, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x01,
0x1e, 0x00, 0x00, 0x00, 0x00, 0xc0, 0xff, 0x00, 0xfe, 0x07, 0x00, 0x00,
0x00, 0xc0, 0xff, 0x00, 0xfe, 0x0f, 0x00, 0x00, 0x00, 0xc0, 0xff, 0x00,
0xfe, 0x0f, 0x00, 0x00, 0x00, 0xc0, 0xff, 0x00, 0xfe, 0x07, 0x00, 0x00,
0x00, 0x00, 0xe0, 0x01, 0x1e, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x03,
0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x87, 0x0f, 0x00, 0x00, 0x00,
0x00, 0x00, 0xf0, 0xff, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf8, 0xff,
0x7f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfc, 0x7c, 0x7e, 0x00, 0x00, 0x00,
0x00, 0x00, 0x7e, 0x7c, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3e, 0x7c,
0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3c, 0x7c, 0x70, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
// Sun and cloud
#define pic_5_width 57
#define pic_5_height 32
static unsigned char pic_5_bits[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00,
0x7f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0xe0, 0xff, 0x03, 0x00, 0x00,
0x00, 0x00, 0x78, 0xf8, 0xff, 0x0f, 0x00, 0x00, 0x00, 0x60, 0x78, 0xfc,
0xc3, 0x1f, 0x00, 0x00, 0x00, 0xf0, 0x78, 0xfe, 0x80, 0x3f, 0x00, 0x00,
0x00, 0xf0, 0x79, 0x3f, 0x00, 0x7e, 0x00, 0x00, 0x00, 0xe0, 0xff, 0x1f,
0x00, 0x7c, 0x00, 0x00, 0x00, 0xc0, 0xff, 0x0f, 0x00, 0xf8, 0x00, 0x00,
0x00, 0x80, 0xc7, 0x07, 0x00, 0xf0, 0x00, 0x00, 0x00, 0xc0, 0xc3, 0x03,
0x00, 0xf0, 0x01, 0x00, 0x00, 0xfe, 0xf1, 0x03, 0x00, 0xe0, 0x01, 0x00,
0x00, 0xfe, 0xf9, 0x01, 0x00, 0xc0, 0x01, 0x00, 0x00, 0xfe, 0xfd, 0x00,
0x00, 0xc0, 0x03, 0x00, 0x00, 0xfc, 0x3d, 0x00, 0x00, 0xc0, 0x03, 0x00,
0x00, 0x80, 0x3f, 0x00, 0x00, 0xc0, 0x03, 0x00, 0x00, 0xc0, 0x1f, 0x00,
0x00, 0xc0, 0x03, 0x00, 0x00, 0xc0, 0x0f, 0x00, 0x00, 0xc0, 0x03, 0x00,
0x00, 0xe0, 0x0f, 0x00, 0x00, 0xc0, 0x03, 0x00, 0x00, 0xf0, 0x1f, 0x00,
0x00, 0xe0, 0x03, 0x00, 0x00, 0xf0, 0x1e, 0x00, 0x00, 0xe0, 0x01, 0x00,
0x00, 0x60, 0x3e, 0x00, 0x00, 0xf0, 0x01, 0x00, 0x00, 0x00, 0x7c, 0x00,
0x00, 0xf8, 0x00, 0x00, 0x00, 0x00, 0xf8, 0xff, 0xff, 0xff, 0x00, 0x00,
0x00, 0x00, 0xf8, 0xff, 0xff, 0x3f, 0x00, 0x00, 0x00, 0x00, 0xe0, 0xff,
0xff, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0x03, 0x00, 0x00,
// Light rain
#define pic_6_width 57
#define pic_6_height 32
static unsigned char pic_6_bits[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x31,
0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x18, 0x03, 0x00, 0x00, 0x00,
0x00, 0x00, 0x60, 0x8c, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0xc6,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x80, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
// Sun, cloud and rain
#define pic_7_width 57
#define pic_7_height 32
static unsigned char pic_7_bits[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x39, 0xfb, 0x01, 0x00, 0x00, 0x00,
0x00, 0x80, 0xbb, 0xfb, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xfd,
0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x86, 0x07, 0x3e, 0x00, 0x00, 0x00,
0x00, 0xc0, 0x87, 0x03, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc6, 0x03,
0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0x01, 0xe0, 0x00, 0x00, 0x00,
0x00, 0x80, 0xfb, 0x01, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x80, 0xf9, 0x00,
0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3c, 0x00, 0xc0, 0x01, 0x00, 0x00,
// Snow
#define pic_8_width 57
#define pic_8_height 32
static unsigned char pic_8_bits[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x22,
0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x10, 0x11, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x88, 0x88, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x44, 0x44,
// Cloudy
#define pic_9_width 57
#define pic_9_height 32
static unsigned char pic_9_bits[] = {
0x00, 0x00, 0x00, 0xf8, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff,
0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0xff, 0x7f, 0x00, 0x00, 0x00,
0x00, 0x00, 0xc0, 0x1f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x07,
0xfc, 0x01, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x01, 0xf0, 0x03, 0x00, 0x00,
0x00, 0x00, 0xf0, 0x00, 0xe0, 0x03, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00,
0xc0, 0x07, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x80, 0x07, 0x00, 0x00,
0x00, 0x00, 0x3e, 0x00, 0x80, 0x0f, 0x00, 0x00, 0x00, 0x80, 0x3f, 0x00,
0x00, 0x0f, 0x00, 0x00, 0x00, 0xc0, 0x0f, 0x00, 0x00, 0x0e, 0x00, 0x00,
0x00, 0xe0, 0x07, 0x00, 0x00, 0x1e, 0x00, 0x00, 0x00, 0xe0, 0x01, 0x00,
0x00, 0x1e, 0x00, 0x00, 0x00, 0xf0, 0x01, 0x00, 0x00, 0x1e, 0x00, 0x00,
0x00, 0xf8, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00,
0x00, 0x1e, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x00,
0x00, 0xf8, 0x00, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x00, 0xf0, 0x00, 0x00,
0x00, 0x0f, 0x00, 0x00, 0x00, 0xf0, 0x01, 0x00, 0x80, 0x0f, 0x00, 0x00,
0x00, 0xe0, 0x03, 0x00, 0xc0, 0x07, 0x00, 0x00, 0x00, 0xc0, 0xff, 0xff,
0xff, 0x07, 0x00, 0x00, 0x00, 0xc0, 0xff, 0xff, 0xff, 0x01, 0x00, 0x00,
0x00, 0x00, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf8, 0xff,
// Showers
#define pic_10_width 57
#define pic_10_height 32
static unsigned char pic_10_bits[] = {
0x00, 0x00, 0x30, 0xc6, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x63,
0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8c, 0x31, 0x06, 0x00, 0x00, 0x00,
0x00, 0x00, 0xc6, 0x18, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x63, 0x8c,
0x01, 0x00, 0x00, 0x00, 0x00, 0x80, 0x31, 0xc6, 0x00, 0x00, 0x00, 0x00,
// Light Snow
#define pic_11_width 57
#define pic_11_height 32
static unsigned char pic_11_bits[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x01, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
// Windy
#define pic_12_width 57
#define pic_12_height 32
static unsigned char pic_12_bits[] = {
0x00, 0x00, 0x00, 0xf0, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf8,
0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x03, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x18, 0xc7, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xf7, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf3, 0x0f, 0x00, 0x00,
0x00, 0x00, 0x00, 0x80, 0x33, 0x0e, 0x00, 0x00, 0x00, 0xc0, 0xff, 0xff,
0x33, 0x0c, 0x00, 0x00, 0x00, 0xc0, 0xff, 0xff, 0x00, 0x0e, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0xc0, 0xff, 0xff,
0xff, 0x07, 0x00, 0x00, 0x00, 0xc0, 0xff, 0xff, 0xff, 0x03, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0xff, 0xff, 0xff, 0x01, 0x00, 0x00,
0x00, 0xc0, 0xff, 0xff, 0xff, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x00,
0x00, 0xc0, 0xff, 0xff, 0x11, 0x0c, 0x00, 0x00, 0x00, 0xc0, 0xff, 0xff,
0x33, 0x0e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x73, 0x0e, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xf3, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
0xe7, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x03, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0xb8, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf8,
0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf0, 0x01, 0x00, 0x00, 0x00,
// Fog
#define pic_13_width 57
#define pic_13_height 32
static unsigned char pic_13_bits[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00,
0x00, 0xc0, 0x00, 0x00, 0x80, 0x01, 0x00, 0x00, 0x00, 0xc0, 0x11, 0x11,
0x91, 0x01, 0x00, 0x00, 0x00, 0xc0, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xfc, 0xdf, 0xff, 0xff, 0x03, 0x00, 0x00,
0x00, 0x06, 0xf8, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x46, 0xfc, 0x00,
0x00, 0x03, 0x00, 0x00, 0x00, 0xfc, 0x9f, 0xff, 0xff, 0x03, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfe, 0xff, 0xff, 0x1f, 0x00, 0x00,
0x00, 0x00, 0x03, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x13, 0x11,
0x11, 0x31, 0x00, 0x00, 0x00, 0x00, 0xfe, 0xff, 0xff, 0x1f, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xf0, 0xff, 0xff, 0xfb, 0x03, 0x00, 0x00,
0x00, 0x18, 0x00, 0x00, 0x0b, 0x06, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00,
0x4b, 0x06, 0x00, 0x00, 0x00, 0xf0, 0xff, 0xff, 0xfb, 0x03, 0x00, 0x00,
/// ========== Images End ==========
pinMode(LED_PIN, OUTPUT);
Serial.begin(9600); // For Nextion Display
u8g2.begin();
u8g2.enableUTF8Print();
u8g2.setFont(u8g2_font_crox4hb_tf);
//u8g2.setFontMode(0);
//u8g2.setDrawColor(1);
WiFi.begin(ssid, pass);
delay(2000);
initSensor();
Blynk.config(auth, server, port);
Blynk.connect();
// Timed Lambda Function - // First forcast run
timer.setTimeout(1000L, []() {
getWeatherData();
}); // END Timer Function
timer.setInterval(4000L, nextionSend); // Update Nextion Values
timer.setInterval(1800000L, getWeatherData); // Update Nextion Forcast
// Timed Lambda Function - UpTime counter
timer.setInterval(1000L, []() { // Run every second
Blynk.virtualWrite(V3, millis() / 60000); // Display the UpTime in Minutes
void nextionSend() {
antiBurn = random(0, 30);
u8g2.clearDisplay();
digitalWrite(LED_PIN, LOW);
delay(2000);
digitalWrite(LED_PIN, HIGH);
printWeatherIcon(weatherID);
getTemperature();
sendTemperatureToNextion();
getHumidity();
sendHumidityToNextion();
getPressure();
sendPressureToNextion();
void initSensor() {
//bool status = bme.begin(BME280_ADDRESS);
bool status = bme.begin();
if (!status) {
Serial.println("Could not find a valid BME280 sensor, check wiring!");
while (1);
BLYNK_WRITE(V4) {
int pinValue = param.asInt();
if (pinValue == 1) {
led2.on();
if (pinValue == 0) {
led2.off();
float getTemperature() {
temperature = bme.readTemperature();
Blynk.virtualWrite(V0, String(temperature, 1));
u8g2.setCursor(15, 14 + antiBurn);
do {
u8g2.print(String(temperature, 1) + " C");
} while (
u8g2.nextPage() );
return 0;
float getHumidity() {
humidity = bme.readHumidity();
Blynk.virtualWrite(V1, String(humidity, 1));
u8g2.setCursor(15, 31 + antiBurn);
do {
u8g2.print(String(humidity, 1) + " %");
} while (
u8g2.nextPage() );
return 0;
float getPressure() {
pressure = bme.readPressure();
pressure = bme.seaLevelForAltitude(ALTITUDE, pressure);
pressure = pressure / 100.0F;
Blynk.virtualWrite(V2, String(pressure, 1));
return 0;
void getWeatherData() { //client function to send/receive GET request data.
String result = "";
WiFiClient client;
const int httpPort = 80;
if (!client.connect(servername, httpPort)) {
return;
// We now create a URI for the request
String url = "/data/2.5/forecast?id=" + CityID + "&units=metric&cnt=1&APPID=" + APIKEY;
// This will send the request to the server
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + servername + "\r\n" +
"Connection: close\r\n\r\n");
unsigned long timeout = millis();
while (client.available() == 0) {
if (millis() - timeout > 5000) {
client.stop();
return;
// Read all the lines of the reply from server
while (client.available()) {
result = client.readStringUntil('\r');
result.replace('[', ' ');
result.replace(']', ' ');
char jsonArray [result.length() + 1];
result.toCharArray(jsonArray, sizeof(jsonArray));
jsonArray[result.length() + 1] = '\0';
StaticJsonBuffer<1024> json_buf;
JsonObject &root = json_buf.parseObject(jsonArray);
if (!root.success()) {
Serial.print("parseObject() failed");
String location = root["city"]["name"];
String temperature = root["list"]["main"]["temp"];
String weather = root["list"]["weather"]["main"];
String description = root["list"]["weather"]["description"];
String idString = root["list"]["weather"]["id"];
String timeS = root["list"]["dt_txt"];
weatherID = idString.toInt();
Serial.print(weatherID);
endNextionCommand(); //We need that in order the nextion to recognise the first command after the serial print
void showConnectingIcon() {
//Serial.println();
String command = "weatherIcon.pic=3";
Serial.print(command);
void sendHumidityToNextion() {
String command = "humidity.txt=\"" + String(humidity, 1) + "\"";
void sendTemperatureToNextion() {
String command = "temperature.txt=\"" + String(temperature, 1) + "\"";
void sendPressureToNextion() {
String command = "pressure.txt=\"" + String(pressure, 1) + "\"";
void endNextionCommand() {
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
void printWeatherIcon(int id) {
switch (id) {
case 800: drawClearWeather(); break;
case 801: drawFewClouds(); break;
case 802: drawFewClouds(); break;
case 803: drawCloud(); break;
case 804: drawCloud(); break;
case 200: drawThunderstorm(); break;
case 201: drawThunderstorm(); break;
case 202: drawThunderstorm(); break;
case 210: drawThunderstorm(); break;
case 211: drawThunderstorm(); break;
case 212: drawThunderstorm(); break;
case 221: drawThunderstorm(); break;
case 230: drawThunderstorm(); break;
case 231: drawThunderstorm(); break;
case 232: drawThunderstorm(); break;
case 300: drawLightRain(); break;
case 301: drawLightRain(); break;
case 302: drawLightRain(); break;
case 310: drawLightRain(); break;
case 311: drawLightRain(); break;
case 312: drawLightRain(); break;
case 313: drawLightRain(); break;
case 314: drawLightRain(); break;
case 321: drawLightRain(); break;
case 500: drawLightRainWithSunOrMoon(); break;
case 501: drawLightRainWithSunOrMoon(); break;
case 502: drawLightRainWithSunOrMoon(); break;
case 503: drawLightRainWithSunOrMoon(); break;
case 504: drawLightRainWithSunOrMoon(); break;
case 511: drawLightRain(); break;
case 520: drawModerateRain(); break;
case 521: drawModerateRain(); break;
case 522: drawHeavyRain(); break;
case 531: drawHeavyRain(); break;
case 600: drawLightSnowfall(); break;
case 601: drawModerateSnowfall(); break;
case 602: drawHeavySnowfall(); break;
case 611: drawLightSnowfall(); break;
case 612: drawLightSnowfall(); break;
case 615: drawLightSnowfall(); break;
case 616: drawLightSnowfall(); break;
case 620: drawLightSnowfall(); break;
case 621: drawModerateSnowfall(); break;
case 622: drawHeavySnowfall(); break;
case 701: drawFog(); break;
case 711: drawFog(); break;
case 721: drawFog(); break;
case 731: drawFog(); break;
case 741: drawFog(); break;
case 751: drawFog(); break;
case 761: drawFog(); break;
case 762: drawFog(); break;
case 771: drawFog(); break;
case 781: drawFog(); break;
default: break;
void drawFog() {
String command = "weatherIcon.pic=13";
do {
u8g2.drawXBM(69, 0 + antiBurn, pic_13_width, pic_13_height, pic_13_bits); // Sunny
} while (
u8g2.nextPage() );
void drawHeavySnowfall()
String command = "weatherIcon.pic=8";
do {
u8g2.drawXBM(69, 0 + antiBurn, pic_8_width, pic_8_height, pic_8_bits); // Sunny
} while (
u8g2.nextPage() );
void drawModerateSnowfall()
do {
} while (
u8g2.nextPage() );
void drawLightSnowfall()
String command = "weatherIcon.pic=11";
do {
u8g2.drawXBM(69, 0 + antiBurn, pic_11_width, pic_11_height, pic_11_bits); // Sunny
} while (
u8g2.nextPage() );
void drawHeavyRain()
String command = "weatherIcon.pic=10";
do {
u8g2.drawXBM(69, 0 + antiBurn, pic_10_width, pic_10_height, pic_10_bits); // Sunny
} while (
u8g2.nextPage() );
void drawModerateRain()
String command = "weatherIcon.pic=6";
do {
u8g2.drawXBM(69, 0 + antiBurn, pic_6_width, pic_6_height, pic_6_bits); // Sunny
} while (
u8g2.nextPage() );
void drawLightRain()
do {
} while (
u8g2.nextPage() );
void drawLightRainWithSunOrMoon()
String command = "weatherIcon.pic=7";
do {
u8g2.drawXBM(69, 0 + antiBurn, pic_7_width, pic_7_height, pic_7_bits); // Sunny
} while (
u8g2.nextPage() );
void drawThunderstorm()
do {
u8g2.drawXBM(69, 0 + antiBurn, pic_3_width, pic_3_height, pic_3_bits); // Sunny
} while (
u8g2.nextPage() );
void drawClearWeather()
String command = "weatherIcon.pic=4";
do {
u8g2.drawXBM(69, 0 + antiBurn, pic_4_width, pic_4_height, pic_4_bits); // Sunny
} while (
u8g2.nextPage() );
void drawCloud()
String command = "weatherIcon.pic=9";
do {
u8g2.drawXBM(69, 0 + antiBurn, pic_9_width, pic_9_height, pic_9_bits); // Sunny
} while (
u8g2.nextPage() );
void drawFewClouds()
String command = "weatherIcon.pic=5";
do {
u8g2.drawXBM(69, 0 + antiBurn, pic_5_width, pic_5_height, pic_5_bits); // Sunny
} while (
u8g2.nextPage() );
Sorry, no custom Nextion data to post here… I don’t like signing up to those data storage sites or posting perma-links here
But If you are really interested (and have a 2.4" Nextion display) you can always PM and ask for the *.HMI file
Meanwhile you can use the base format I started with and extract, resize and edit the images as I did…
And since that is graphically embedded (thus no spell check), I need to make a whole new backdrop… lets see what I can mess up 2nd time round
eating is overrated anyhow.
(with or without a clear background) on top of another… so now I combined the title and the value…
I started looking around to see how other Arduino/ESP GUIs utilise fonts…Thankfully scalable fonts ARE a thing
Also, I am liking it because it can easily coexist with, operates similar too and complements my already existing Blynk projects with minimal changes in how I communicate between device and App(s).
Albeit on two separate slices of bread that can only be eaten in separate bytes
