Hi. I have two ESP8266 devkit 12E. One ESP with si7021 send data to blynk. And i need another ESP with Nextion screen read this data and show on Nextion screen… Is it possible? I dont find a sketch to read from blynk… Thanks.
Yes… a few ways…
Use Blynk on all ESPs, Bridge to share the data, and run the Nextion code on one of the ESPs.
http://docs.blynk.cc/#widgets-other-bridge
And your ‘missing’ sketches …
https://examples.blynk.cc/?board=ESP8266&shield=ESP8266%20WiFi&example=Widgets%2FBridge
Or use one ESP for everything… Study this and convert for ESP8266 and your sensor…
Otherwise If the ESP for the Nextion is non-Blynk and can use a virtual pin for an extra serial port then you can try EasyTransfer between the Blynk ESP and the Nextion ESP
http://www.billporter.info/2011/05/30/easytransfer-arduino-library/
Thanks. I tryed sketch with DHT sensor and was working. Now i trying sketch with si7021 sensor and is no working…But why? Thanks.
#include <Wire.h>
#include <SI7021.h>
float temp, hum;
bool SI7021_present = true;
#define I2C_SCL 4 //D6 // Barometric Pressure Sensor (BMP085)
#define I2C_SDA 5 // D7
SI7021 sensor;
char ssid[] = "";
char pass[] = "";
char auth[] = "deviceA"; // Put your Auth Token here. (see Step 3 above)
WidgetBridge bridge1(V1);
sensor.begin(SDA,SCL);
Wire.begin(I2C_SDA, I2C_SCL);
timer.setInterval(5000L,sendUptime);
void sendUptime()
float temperature = sensor.getCelsiusHundredths()/100;
float humidity = sensor.getHumidityPercent();
Blynk.virtualWrite(5, temperature);
Blynk.virtualWrite(6, humidity); // virtual pin
void blynkAnotherDevice() // Here we will send HIGH or LOW once per second
float temperature = sensor.getCelsiusHundredths();
// Send value to another device
bridge1.virtualWrite(V5, temperature);
bridge1.virtualWrite(V6, humidity);// Sends 0 value to BLYNK_WRITE(V5) handler on receiving side.
BLYNK_CONNECTED() {
bridge1.setAuthToken ("deviceB"); // Place the AuthToken of the second hardware here
Serial.println ("Sensor1 Linked to Master");
DeviceB:
char auth[] = "deviceB";
// Set password
char ssid[] = "ASUS72";
char pass[] = "";
float TempSensor1;
float HumiditySensor1;
BLYNK_WRITE(V5)
float TempSensor1 = param.asFloat(); // assigning incoming value from pin V5 to a variable
// You can also use:
// String i = param.asStr();
// double d = param.asDouble();
Serial.print("TempSensor1 is: ");
Serial.println(TempSensor1);
BLYNK_WRITE(V6)
float HumiditySensor1 = param.asFloat(); // assigning incoming value from pin V5 to a variable
Serial.print("HumiditySensor1 is: ");
Serial.println(HumiditySensor1);
//Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 8442);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8442);
Define “no working”… one, other or both devices not connecting to server, sender not reading sensor properly, receiver not receiving bridge call (can you test with another bridge call with test data or even App widget to same vPin), neither are making you coffee in the morning?
Both devices are cinnecting to blnyk server but device B no receiving temp and hum… In app Blynk in my phone deviceA show hum and temp and device B no… Thanks:-)
Well, in the sending device (A), double check that you are using the correct AUTH for the receiving (B) device.
Yes i have because if i use this sketch deviceB temp and hum receive.
#include "DHT.h"
#define DHTPIN D4
#define DHTTYPE DHT22
float hum = 0;
float temp = 0;
char auth[] = "";
char pass[] = "";
// Bridge widget on virtual pin 1
DHT dht(DHTPIN, DHTTYPE);
// Timer for blynking
void sendUptime()
Blynk.virtualWrite(5, temp); //virtual pin V10
Blynk.virtualWrite(6, hum); // virtual pin V11
float h = dht.readHumidity();
bridge1.virtualWrite(V5, t);
bridge1.virtualWrite(V6, h);// Sends 0 value to BLYNK_WRITE(V5) handler on receiving side.
BLYNK_CONNECTED() {
bridge1.setAuthToken("deviceB"); // Place the AuthToken of the second hardware here
dht.begin();
timer.setInterval(50000L, getDhtData);
// Call blynkAnotherDevice every second
timer.setInterval(1000L, blynkAnotherDevice);
timer.setInterval(50000L, sendUptime);
void getDhtData(void)
float tempIni = temp;
float humIni = hum;
temp = dht.readTemperature();
hum = dht.readHumidity();
if (isnan(hum) || isnan(temp)) // Check if any reads failed and exit early (to try again).
temp = tempIni;
hum = humIni;
And in sketch deviceB is good: float TempSensor1;
float HumiditySensor1; ? thanks
Umm, OK… so your issue is resolved then?
No because sketch with sensor si7021, deviceB no receive data from deviceA…But why ? Is possible bridge with library:wire no working? thanks
OK, I am not going to waste my time going though your code line by line… but a bridge1.virtualWrite()
is a one-way command that (in this case) emulates a Widget call to a BLYNK_WRITE()
function… so very simple actually.
Device A (Bridge Sender) - AUTH = xyzxyzxyz:
WidgetBridge MyBridgeName(vPin); // Initiating Bridge name and Widget on vPin... I think this widget is NOT required on the sender device but more for a reference and placeholder for the vPin... but I include it anyhow.
BLYNK_CONNECTED() {
MyBridgeName.setAuthToken("ReceivingDevicesAUTH"); // AUTH of the receiving Device's (B) sketch
MyBridgeName.virtualWrite(vPinOfReceiver,value); // Send value to the corresponding * vPinOfReceiver * function on the receiving device
Device B (Bridge Receiver) - AUTH = ReceivingDevicesAUTH:
On the receiving device, all is normal Blynk functions, just waiting for a Widget (from the project with the matching AUTH) or Bridge command (from a sketch set with matching Bridge AUTH) with the corresponding vPin to call (activate) them and possibly supply a value
… Simple.
Thanks. I delete void blynkAnotherDevice and to the void sendUptime add:
bridge1.virtualWrite(V5,temperature);
bridge1.virtualWrite(V6,humidity);
and now deviceB read data…
Hi. This sketch was working but now is not. Is possible something wrong in library? I am useing library blynk:0.4.0 and Arduino IDE 1.6.5… Or is problem in Simple timer? Thanks.
The latest Blynk library is 0.5.4 which was released on 6th September, so one should hope that you were using that version when you were working on this project back in October.
You also need to be using the latest ESP core and it wouldn’t hurt to update yourArduino IDE to the letest version either.
I assume that you’re using the Blynk Cloud servers? If not then you need to ensure that your local server is updated to the latest version.
You also need the latest version of the app as well.
Ok thanks i will try update library, Arduino ide and ESP core. And yes i am use Blynk Cloud.
