With the screen color set to “Blynk Gray” (and with the Input Line off), the Terminal Widget looks like a multi-line Value Display / Labeled Value Widget.
I’ll be darn. That doesn’t make any sense. Blynk.setProperty(vPin, “color”, …) is typically used to set the font color, not the background / screen color. How do you set the Terminal Widget font color? I assume you don’t.
In either case, I’ll take it! Thank you, @Gunner. You wouldn’t happen to have solutions to my other feature requests?
Nope… I don’t really like Tiles and I suspect the Terminal Widget is designed to emulate an old skoool one, thus what font you see is what font you get… but at least with some options.
