Local server, Raspberry , latest version
Huawey P9 lite mobile phone
Library, latest version
App, latest version
Wemos D1 , device
I have a display problem with the Super Chart widget
I have a virtual pin that becomes high every 60 seconds for 4 seconds. In the real time display everything is correct while looking at the following image at 15 minutes I have this
Pete, I have that kind of problem (âphantomâ lines) but I did not mention them in my initial message. The main problem is what I indicated in the first message that is the most important. I have not found any solution to this problem yet.
I recommend the same option as in that post⌠use the Beta App and send in the log reports. Developers can not always determine the issue from screenshots. In fact it might have already been resolved in the latest beta release.
For Android⌠I seem to recall you needed to scroll down? in the Playstoreâs Blynk page to the Join beta option.
In the App, back out of a project, as if to scroll to another one, click on the [i] in the upper right corner and choose Send Logs. Reference this topic URL.
I followed your directions but I did not find a way to download the Beta version. Maybe you have to be beta testers ⌠I do not know. Iâll wait for a new version of the non-beta app and I hope the problem will be solved as the widget is very useful.
This release is currently in open beta (and we plan to release next builds also first in beta), so to install it you need to open google play app and scroll it till the âbecome a beta testerâ section and click âjoin nowâ button:
Yep⌠I couldnât find the original topic in my quick search, but I knew it was something simple and easy to find. I guess I just assumed one would look on the phone version of Google Play.
