Hello
my easy project [1], before v5 it has no errors but after update to v5 get this error :
#include <BlynkSimpleEsp8266_SSL.h>
char pass[] = "YourPassword";
tried blynk ssl sketch above same error
In file included from C:\Users\plazma\AppData\Local\Temp\arduino_modified_sketch_479276\ESP8266_Standalone_SSL.ino:6:0:
D:\elektronik\arduino projeler\libraries\Blynk\src/BlynkSimpleEsp8266_SSL.h: In instantiation of 'bool BlynkArduinoClientSecure<Client>::connect() [with Client = WiFiClientSecure]':
D:\elektronik\arduino projeler\libraries\Blynk\src/Blynk/BlynkProtocol.h:215:17: required from 'bool BlynkProtocol<Transp>::run(bool) [with Transp = BlynkArduinoClientSecure<WiFiClientSecure>]'
C:\Users\plazma\AppData\Local\Temp\arduino_modified_sketch_479276\ESP8266_Standalone_SSL.ino:27:13: required from here
D:\elektronik\arduino projeler\libraries\Blynk\src/BlynkSimpleEsp8266_SSL.h:140:18: error: 'class WiFiClientSecure' has no member named 'verifyCertChain'
} else if (this->client->verifyCertChain(this->domain)) {
D:\elektronik\arduino projeler\libraries\Blynk\src/BlynkSimpleEsp8266_SSL.h: In instantiation of 'void BlynkArduinoClientSecure<Client>::setCACert_P(const uint8_t*, unsigned int) [with Client = WiFiClientSecure; uint8_t = unsigned char]':
D:\elektronik\arduino projeler\libraries\Blynk\src/BlynkSimpleEsp8266_SSL.h:205:11: required from 'void BlynkWifi<Transport>::config(const char*, const char*, uint16_t, const char*) [with Transport = BlynkArduinoClientSecure<WiFiClientSecure>; uint16_t = short unsigned int]'
D:\elektronik\arduino projeler\libraries\Blynk\src/BlynkSimpleEsp8266_SSL.h:232:47: required from 'void BlynkWifi<Transport>::begin(const char*, const char*, const char*, const char*, uint16_t, const char*) [with Transport = BlynkArduinoClientSecure<WiFiClientSecure>; uint16_t = short unsigned int]'
C:\Users\plazma\AppData\Local\Temp\arduino_modified_sketch_479276\ESP8266_Standalone_SSL.ino:22:31: required from here
D:\elektronik\arduino projeler\libraries\Blynk\src/BlynkSimpleEsp8266_SSL.h:132:9: error: 'class WiFiClientSecure' has no member named 'setCACert_P'
this->client->setCACert_P(caCert, caCertLen);
Şu dizinde 1.0 sürümündeki ESP8266WiFi kütüphanesi kullanılıyor: C:\Users\plazma\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
Şu dizinde 0.5.0 sürümündeki Blynk kütüphanesi kullanılıyor: D:\elektronik\arduino projeler\libraries\Blynk
exit status 1
Error compiling for board Generic ESP8266 Module.
