Set up Orange Pi Zero as Blynk Local Server
Change “pi” to your username
#Install Java Development Kit
sudo apt-get install default-jre
sudo apt-get install default-jdk
sudo apt-get install software-properties-common
sudo add-apt-repository "deb http://ppa.launchpad.net/webupd8team/java/ubuntu xenial main"
sudo apt-get update
sudo apt-get install oracle-java8-installer
sudo apt install oracle-java8-set-default
#Create a directory for the server called Blynk
mkdir /home/pi/Blynk
#Move into the working directory
cd Blynk
#Download the server
wget "https://github.com/blynkkk/blynk-server/releases/download/v0.23.1/server-0.23.1.jar"
#Generate self-signed certificates
openssl req -x509 -nodes -days 1825 -newkey rsa:2048 -keyout server.key -out server.crt
#Convert key to pem
openssl pkcs8 -topk8 -inform PEM -outform PEM -in server.key -out server.pem
#Copy the contents from the site given below
https://raw.githubusercontent.com/blynkkk/blynk-server/master/server/core/src/main/resources/server.properties
#and paste it in
sudo nano server.properties
#Change the following lines
server.ssl.cert=./server.crt
server.ssl.key=./server.pem
server.ssl.key.pass=PASSWORD_USED_IN_ABOVE_STEP
https://raw.githubusercontent.com/blynkkk/blynk-server/master/server/notifications/email/src/main/resources/mail.properties
#and paste it in
sudo nano mail.properties
#Set Gmail id and password. If you are using two step verification, generate app specific password from google account.
cd ..
#For Autostart on reboot
sudo nano /etc/rc.local
Add the following command mentioned before “exit”
java -jar /home/pi/Blynk/server-0.23.1.jar -dataFolder /home/pi/Blynk -serverConfig /home/pi/Blynk/server.properties -mailConfig /home/pi/Blynk/mail.properties &
#Now You can start the server
@shivasiddharth nice clear video, thanks for sharing.
Video and text, you are my hero! (I hate video’s, I love text LOL).
Hi shivasiddharth,
Is this guide still applicable to version 0.26.1 of the server?
I have followed exactly (except for downloading the latested server) but I cannot login to the admin web page, upon hitting login (with correct credentials) the page just refreshes with no errors or warnings (just cleared username and password fields.
Check out the new “admin account” change, made around the same time frame.
I just tried this on Chrome (I was using IE and Edge) which works ok.
Console for IE and Edge shows only this error, nothing else:
DOM7011: The code on this page disabled back and forward caching. For more information, see: http://go.microsoft.com/fwlink/?LinkID=291337
Default login name admin@blynk.cc, password admin.
blynk.log just show’s this, no other errors:
21:29:32.228 DEBUG- POST : /admin/login
Login Page:
https://192.168.0.38:9443/admin
Anyone else have this issue on IE\Edge?
Others have reported the same.
A post was split to a new topic: I have a problem with setup local Blynk server to Orange Pi Zero
