I will soon be at the end of my project.
I still need your help.
I would like to put a red led and green led depending on the position of the relay.
I have no problem with the green led. Can you help me with the red led.
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <OneWire.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "xxxxxxxxxxxx";
char pass[] = "xxxxxxxxxxxxxxxxxxx";
// Set your LED and physical button pins here
const int relais1 = 14;
const int btn1 = 27;
const int ledV1 = 17;
const int ledR1 = 13;
const int relais2 = 32;
const int btn2 = 26;
const int ledV2 = 5;
const int ledR2 = 2;
const int relais3 = 15;
const int btn3 = 25;
const int ledV3 = 18;
const int ledR3 = 4;
const int relais4 = 12;
const int btn4 = 33;
const int ledV4 = 19;
const int ledR4 = 16;
// one wire temperature
#define ONE_WIRE_BUS 23
int deviceCount = 3;
float tempC;
void checkPhysicalButton1();
void temperature();
int relais1Sate = LOW;
int btn1State = HIGH;
int ledV1State = LOW;
int ledR1State = LOW;
int relais2Sate = LOW;
int btn2State = HIGH;
int ledV2State = LOW;
int ledR2State = LOW;
int relais3Sate = LOW;
int btn3State = HIGH;
int ledV3State = LOW;
int ledR3State = LOW;
int relais4Sate = LOW;
int btn4State = HIGH;
int ledV4State = LOW;
int ledR4State = LOW;
int lcd_position[] = {16, 30, 44}; // position temperature sur l'écran
BLYNK_WRITE(V1) {
relais1Sate = param.asInt();
digitalWrite(relais1, relais1Sate);
ledV1State = param.asInt();
digitalWrite(ledV1, ledV1State);
BLYNK_WRITE(V2) {
relais2Sate = param.asInt();
digitalWrite(relais2, relais2Sate);
ledV2State = param.asInt();
digitalWrite(ledV2, ledV2State);
BLYNK_WRITE(V3) {
relais3Sate = param.asInt();
digitalWrite(relais3, relais3Sate);
ledV3State = param.asInt();
digitalWrite(ledV3, ledV3State);
BLYNK_WRITE(V4) {
relais4Sate = param.asInt();
digitalWrite(relais4, relais4Sate);
ledV4State = param.asInt();
digitalWrite(ledV4, ledV4State);
void temperature()
display.clearDisplay();
display.display();
display.setTextSize(1);
display.setTextColor(SSD1306_WHITE);
display.setCursor(0, 0);
display.println("---------------------");
display.setCursor(0, 6);
display.print("| Temperature |");
display.setCursor(0, 12);
display.setCursor(0, 16); // position 0
display.println(" Interieur |");
display.print("---------------------");
display.display();
display.setCursor(0, 30); // position 1
display.println(" Exterrieur |");
display.display();
display.setCursor(0, 44); // position 2
display.println(" Eau |");
display.display();
// Send command to all the sensors for temperature conversion
// Display temperature from each sensor
for (int i = 0; i < deviceCount; i++)
tempC = sensors.getTempCByIndex(i);
Blynk.virtualWrite(i + 21, tempC);
display.setCursor(80, lcd_position[i]);
display.print(tempC);
display.display();
if (digitalRead(btn1) == LOW) {
if (btn1State != LOW) {
// Toggle LED state
relais1Sate = !relais1Sate;
ledV1State = !ledV1State;
// Update Button Widget
Blynk.virtualWrite(V1, relais1Sate);
Blynk.virtualWrite(V1, ledV1State);
btn1State = LOW;
btn1State = HIGH;
if (digitalRead(btn2) == LOW) {
if (btn2State != LOW) {
// Toggle LED state
relais2Sate = !relais2Sate;
ledV2State = !ledV2State;
Blynk.virtualWrite(V2, relais2Sate);
Blynk.virtualWrite(V2, ledV2State);
btn2State = LOW;
btn2State = HIGH;
if (digitalRead(btn3) == LOW) {
if (btn3State != LOW) {
// Toggle LED state
relais3Sate = !relais3Sate;
ledV3State = !ledV3State;
Blynk.virtualWrite(V3, relais3Sate);
Blynk.virtualWrite(V3, ledV3State);
btn3State = LOW;
btn3State = HIGH;
if (digitalRead(btn4) == LOW) {
if (btn4State != LOW) {
// Toggle LED state
relais4Sate = !relais4Sate;
ledV4State = !ledV4State;
Blynk.virtualWrite(V4, relais4Sate);
Blynk.virtualWrite(V4, ledV4State);
btn4State = LOW;
btn4State = HIGH;
sensors.begin(); // debut de la librairie capteur de température
WiFi.begin(ssid, pass);
//timer.setInterval(3000L, checkBlynk); // check if connected to Blynk server every 3 seconds
Blynk.config(auth);
pinMode(relais1, OUTPUT);
pinMode(btn1, INPUT_PULLUP);
pinMode(ledV1, OUTPUT);
pinMode(relais2, OUTPUT);
pinMode(btn2, INPUT_PULLUP);
pinMode(ledV2, OUTPUT);
pinMode(relais3, OUTPUT);
pinMode(btn3, INPUT_PULLUP);
pinMode(ledV3, OUTPUT);
pinMode(relais4, OUTPUT);
pinMode(btn4, INPUT_PULLUP);
pinMode(ledV4, OUTPUT);
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("SSD1306 allocation failed"));
for (;;); // Don't proceed, loop forever
// Clear the buffer
display.display();
timer.setInterval(100L,checkPhysicalButton1);
timer.setInterval(10000L, temperature);
// to avoid delay() function!
