the led problem is solved thank you very much for your help.
Could you please explain this part to me?
I tried to modify but it doesn’t work anymore
You are capturing the same widget switch value using param.asInt() and assigning it to two different variables.
Why? What’s the point in doing that?
should I write like that
// Toggle LED state
relais1Sate = !relais1Sate;
digitalWrite(relais1, relais1Sate);
digitalWrite(ledV1, relais1Sate;);
digitalWrite(ledR1, !relais1Sate;);
Yes.
Synchronization with my button widget no longer works
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <OneWire.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
char auth[] = "xxxxxxxxxxxxx";
char ssid[] = "xxxxxxxxxxxx";
char pass[] = "xxxxxxxxxxxxxxx";
// Set your LED and physical button pins here
const int relais1 = 14;
const int btn1 = 27;
const int ledV1 = 17;
const int ledR1 = 13;
const int relais2 = 32;
const int btn2 = 26;
const int ledV2 = 5;
const int ledR2 = 2;
const int relais3 = 15;
const int btn3 = 25;
const int ledV3 = 18;
const int ledR3 = 4;
const int relais4 = 12;
const int btn4 = 33;
const int ledV4 = 19;
const int ledR4 = 16;
// one wire temperature
#define ONE_WIRE_BUS 23
int deviceCount = 3;
float tempC;
void checkPhysicalButton1();
void temperature();
int relais1Sate = LOW;
int btn1State = HIGH;
int ledV1State = LOW;
int ledR1State = LOW;
int relais2Sate = LOW;
int btn2State = HIGH;
int ledV2State = LOW;
int ledR2State = LOW;
int relais3Sate = LOW;
int btn3State = HIGH;
int ledV3State = LOW;
int ledR3State = LOW;
int relais4Sate = LOW;
int btn4State = HIGH;
int ledV4State = LOW;
int ledR4State = LOW;
int lcd_position[] = {16, 30, 44}; // position temperature sur l'écran
BLYNK_WRITE(V1) {
relais1Sate = param.asInt();
ledV1State = param.asInt();
digitalWrite(ledV1, ledV1State);
digitalWrite(ledR1, !ledV1State);
BLYNK_WRITE(V2) {
relais2Sate = param.asInt();
digitalWrite(relais2, relais2Sate);
ledV2State = param.asInt();
digitalWrite(ledV2, ledV2State);
digitalWrite(ledR2, !ledV2State);
BLYNK_WRITE(V3) {
relais3Sate = param.asInt();
digitalWrite(relais3, relais3Sate);
ledV3State = param.asInt();
digitalWrite(ledV3, ledV3State);
digitalWrite(ledR3, !ledV3State);
BLYNK_WRITE(V4) {
relais4Sate = param.asInt();
digitalWrite(relais4, relais4Sate);
ledV4State = param.asInt();
digitalWrite(ledV4, ledV4State);
digitalWrite(ledR4, !ledV4State);
void temperature()
display.clearDisplay();
display.display();
display.setTextSize(1);
display.setTextColor(SSD1306_WHITE);
display.setCursor(0, 0);
display.println("---------------------");
display.setCursor(0, 6);
display.print("| Temperature |");
display.setCursor(0, 12);
display.setCursor(0, 16); // position 0
display.println(" Interieur |");
display.print("---------------------");
display.display();
display.setCursor(0, 30); // position 1
display.println(" Exterrieur |");
display.display();
display.setCursor(0, 44); // position 2
display.println(" Eau |");
display.display();
// Send command to all the sensors for temperature conversion
// Display temperature from each sensor
for (int i = 0; i < deviceCount; i++)
tempC = sensors.getTempCByIndex(i);
Blynk.virtualWrite(i + 21, tempC);
display.setCursor(80, lcd_position[i]);
display.print(tempC);
display.display();
if (digitalRead(btn1) == LOW) {
if (btn1State != LOW) {
// Toggle LED state
digitalWrite(ledV1, relais1Sate);
digitalWrite(ledR1, !relais1Sate);
// Update Button Widget
Blynk.virtualWrite(V1, relais1Sate);
Blynk.virtualWrite(V1, ledV1State);
btn1State = LOW;
btn1State = HIGH;
if (digitalRead(btn2) == LOW) {
if (btn2State != LOW) {
// Toggle LED state
relais2Sate = !relais2Sate;
digitalWrite(ledV2, relais2Sate);
digitalWrite(ledR2, !relais2Sate);
Blynk.virtualWrite(V2, relais2Sate);
Blynk.virtualWrite(V2, ledV2State);
btn2State = LOW;
btn2State = HIGH;
if (digitalRead(btn3) == LOW) {
if (btn3State != LOW) {
// Toggle LED state
relais3Sate = !relais3Sate;
digitalWrite(ledV3, relais3Sate);
digitalWrite(ledR3, !relais3Sate);
Blynk.virtualWrite(V3, relais3Sate);
Blynk.virtualWrite(V3, ledV3State);
btn3State = LOW;
btn3State = HIGH;
if (digitalRead(btn4) == LOW) {
if (btn4State != LOW) {
// Toggle LED state
relais4Sate = !relais4Sate;
digitalWrite(ledV4, relais4Sate);
digitalWrite(ledR4, !relais4Sate);
Blynk.virtualWrite(V4, relais4Sate);
Blynk.virtualWrite(V4, ledV4State);
btn4State = LOW;
btn4State = HIGH;
BLYNK_CONNECTED()
Blynk.syncVirtual(V1);
Blynk.syncVirtual(V2);
Blynk.syncVirtual(V3);
Blynk.syncVirtual(V4);
sensors.begin(); // debut de la librairie capteur de température
WiFi.begin(ssid, pass);
//timer.setInterval(3000L, checkBlynk); // check if connected to Blynk server every 3 seconds
Blynk.config(auth);
pinMode(relais1, OUTPUT);
pinMode(btn1, INPUT_PULLUP);
pinMode(ledV1, OUTPUT);
pinMode(ledR1, OUTPUT);
pinMode(relais2, OUTPUT);
pinMode(btn2, INPUT_PULLUP);
pinMode(ledV2, OUTPUT);
pinMode(ledR2, OUTPUT);
pinMode(relais3, OUTPUT);
pinMode(btn3, INPUT_PULLUP);
pinMode(ledV3, OUTPUT);
pinMode(ledR3, OUTPUT);
pinMode(relais4, OUTPUT);
pinMode(btn4, INPUT_PULLUP);
pinMode(ledV4, OUTPUT);
pinMode(ledR4, OUTPUT);
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("SSD1306 allocation failed"));
for (;;); // Don't proceed, loop forever
// Clear the buffer
display.display();
timer.setInterval(100L, checkPhysicalButton1);
timer.setInterval(10000L, temperature);
// to avoid delay() function!
What exactly does that mean?
Is this your latest sketch? If so, what changes have you made since you said…
Yes this is my last sketch
I modified
// Toggle LED state relais1Sate = !relais1Sate; digitalWrite(relais1, relais1Sate); digitalWrite(ledV1, relais1Sate); digitalWrite(ledR1, !relais1Sate);
// Toggle LED state relais2Sate = !relais2Sate; digitalWrite(relais2, relais2Sate); digitalWrite(ledV2, relais2Sate); digitalWrite(ledR2, !relais2Sate);
// Toggle LED state relais3Sate = !relais3Sate; digitalWrite(relais3, relais3Sate); digitalWrite(ledV3, relais3Sate); digitalWrite(ledR3, !relais3Sate);
// Toggle LED state relais4Sate = !relais4Sate; digitalWrite(relais4, relais4Sate); digitalWrite(ledV4, relais4Sate); digitalWrite(ledR4, !relais4Sate);
So I was talking about changes that you should make to your BLYNK_WRITE routines and you appear to have modified different parts of your code.
here is my last sketch.
I have modified my error, but the synchronization does not work perfectly
#include <WiFi.h>
#include <Wire.h>
char auth[] = "xxxxxxxxxxx";
char ssid[] = "xxxxxxxxxxx";
char pass[] = "xxxxxxxxxxx";
float tempC;
void temperature();
BLYNK_WRITE(V1) {
BLYNK_WRITE(V2) {
BLYNK_WRITE(V3) {
BLYNK_WRITE(V4) {
void temperature()
display.display();
display.display();
display.display();
display.display();
display.display();
// Toggle LED state
ledV1State = !ledV1State;
btn1State = LOW;
btn1State = HIGH;
// Toggle LED state
ledV2State = !ledV2State;
btn2State = LOW;
btn2State = HIGH;
// Toggle LED state
ledV3State = !ledV3State;
btn3State = LOW;
btn3State = HIGH;
// Toggle LED state
ledV4State = !ledV4State;
btn4State = LOW;
btn4State = HIGH;
BLYNK_CONNECTED()
Blynk.config(auth);
// Clear the buffer
display.display();
I still don’t know exactly what this means!
You need to explain, and please don’t post a video!
If my button widget is in the ON position, and I activate the led and my relay changes state. the physical button works very well
but if my wideget button is OFF, when I press the physical button, the led and the relay change state but the synchronization does not work
You’re still using ledV1State
This variable is redundant - remember?
I have to change it by relais1Sate
here are the last modifications that I made.
I still have a synchronization problem. I turn on my ESP 32, I press the physical buttons, the synchronization with the application works well. But when I squeeze my application to change state, when I press a button the synchronization is reversed.
Do you have an idea of the problem ?
#include <WiFi.h>
#include <Wire.h>
char auth[] = "xxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "xxxxxxxxxx";
char pass[] = "xxxxxxxxxxxxx";
float tempC;
void temperature();
BLYNK_WRITE(V1) {
BLYNK_WRITE(V2) {
BLYNK_WRITE(V3) {
BLYNK_WRITE(V4) {
void temperature()
display.display();
display.display();
display.display();
display.display();
display.display();
// Toggle LED state
btn1State = LOW;
btn1State = HIGH;
// Toggle LED state
btn2State = LOW;
btn2State = HIGH;
// Toggle LED state
btn3State = LOW;
btn3State = HIGH;
// Toggle LED state
btn4State = LOW;
btn4State = HIGH;
BLYNK_CONNECTED()
Blynk.config(auth);
// Clear the buffer
display.display();
Either change your button widget settings to reverse the 0/1 output, or use the NOT operator (!) to reverse the logic levels in your sketch.
I will try to explain to you differently
If i press the physical button
Physical button / Widget Button / LED
ON / ON / GREEN
OFF / OFF/ RED
Synchronization is good
if I press the button widget
Widget Button / Physical button / LED
ON / ON / GREEN
OFF / OFF/ RED
but if I press the physical button again, that’s where the problem appears
ON / OFF/ GREEN
OFF / ON/ RED
ledV1State = !ledV1State; digitalWrite(ledV1, ledV1State); digitalWrite(ledR1, !ledV1State);
It won’t work correctly until you TOTALLY remove these ledVxState variables and replace them with the corresponding relaisxSate variables, as I told you yesterday.
do i need to edit here too
Of course!
The ledVxState declarations need to be deleted, as the variables are redundant.
the synchronization is still not good. I have no more ledVxState
here is the last version of my sketch
#include <WiFi.h>
#include <Wire.h>
char auth[] = "xxxxxx";
char ssid[] = "xxxxxxxx";
char pass[] = "xxxxxxxxx";
float tempC;
void temperature();
BLYNK_WRITE(V1) {
BLYNK_WRITE(V2) {
BLYNK_WRITE(V3) {
BLYNK_WRITE(V4) {
void temperature()
display.display();
display.display();
display.display();
display.display();
display.display();
// Toggle LED state
Blynk.virtualWrite(V1, !relais1Sate);
btn1State = LOW;
btn1State = HIGH;
// Toggle LED state
Blynk.virtualWrite(V2, !relais2Sate);
btn2State = LOW;
btn2State = HIGH;
// Toggle LED state
Blynk.virtualWrite(V3, !relais3Sate);
btn3State = LOW;
btn3State = HIGH;
// Toggle LED state
Blynk.virtualWrite(V4, !relais4Sate);
btn4State = LOW;
btn4State = HIGH;
BLYNK_CONNECTED()
Blynk.config(auth);
// Clear the buffer
display.display();
