Please tell me where you need to add what would work?
OK. I realized this when I found your post above. Thanks.
void pzemdata(){
result = node.readInputRegisters(0x0000, 10);
if (result == node.ku8MBSuccess)
voltage_usage = (node.getResponseBuffer(0x00) / 10.0f);
// current_usage = (node.getResponseBuffer(0x01) / 1000.000f);
// current_usage_h = (node.getResponseBuffer(0x02) / 10000.000f);
current_usage_l_h = ((node.getResponseBuffer(0x01) + (node.getResponseBuffer(0x02)*65532)) / 1000.000f);
// active_power = (node.getResponseBuffer(0x03) / 10.0f);
// active_power_h = (node.getResponseBuffer(0x04) / 100.0f);
active_power_l_h = ((node.getResponseBuffer(0x03) + (node.getResponseBuffer(0x04)*65532)) / 10.0f);
// active_energy = (node.getResponseBuffer(0x05) / 1000.0f);
// active_energy_h = (node.getResponseBuffer(0x06) / 10000.0f);
active_energy_l_h = ((node.getResponseBuffer(0x05) + (node.getResponseBuffer(0x06)*65532)) / 1000.0f);
frequency = (node.getResponseBuffer(0x07) / 10.0f);
power_factor = (node.getResponseBuffer(0x08) / 100.0f);
over_power_alarm = (node.getResponseBuffer(0x09));
Serial.print("VOLTAGE: "); Serial.println(voltage_usage); // V
Serial.print("CURRENT_USAGE: "); Serial.println(current_usage_l_h, 3); // A
Serial.print("ACTIVE_POWER: "); Serial.println(active_power_l_h); // W
Serial.print("ACTIVE_ENERGY: "); Serial.println(active_energy_l_h, 3); // kWh
Serial.print("FREQUENCY: "); Serial.println(frequency); // Hz
Serial.print("POWER_FACTOR: "); Serial.println(power_factor);
Serial.print("OVER_POWER_ALARM: "); Serial.println(over_power_alarm, 0);
Serial.println("====================================================");
How to reset Energy counter with ModbusMaster? I couldnât find any.
Read this:
Thanks a lot! It works!
Code.
Hello everyone , please I just baught pzem-004t V3 and when I interface it with esp8266 it doesnât work.Just RX on pzem blinks and TX is not . Pleaase any help !!!
how did u solve this ? i got the same problem
hy pete , i was follow your instruction to make sure both file are in the same folder location , but "settingPZEM.h still can read on arduino
My guess is that the file youâve created is actually called settingPZEM.h.ino
The best way to create these additional files is to use the drop-down arrow in the top rightâŚ
and choose âNew Tabâ and give it the desired name and paste your code into it.
hy pete ,i got the error message again about D5,D6 ,as we can see in the picture , can you help me again pete for solve this problem
You probably chose âgeneric ESP8266â as your board type in the IDE when you compiled the sketch.
Generic ESP8266 doesnât support the âDâ number designations for pins, so choose a more appropriate board type.
Totally delete your Blynk for Chinese library.
Copy the full compiler output text (not a screenshot) and post it, with triple backticks at the beginning and end of the text, so that it displays correctly.
[Unformatted compiler output deleted by moderator]
[Screenshot removed by moderator]
hy pete , would you check ,what wrong with my coding ? thanks
