So it’s time to get a new board, do you agree ?
I wouldn’t use this board as it stands, simply from a mains safety point of view. The GPIO0 issue us potentially solveanle, or a quick hack of the board could change it to use GPIO2, but in the end it’s just not worth the effort.
If I were building a project like this I’ll use a Wemos D1 Mini (or Pro) a Wemos dual base and a Wemos relay, like this…
If it’s going to be a garage door opener then I’d also probably add a reed switch to the upper and lower positions to act as limit switches and position detectors. I’d probably also add a 433Mhz receiver and pair it with a fob to give another way of opening the door.
All do-able with a D1 Mini, but not with an ESP-01 based board.
Merci pour votre aide précieuse, et votre disponibilité.
Concernant mon récepteur (lumière) je vais garder mon ESP-01s (piloté avec un switch virtuel) et pour mon récepteur nécessitant un bouton poussoir, je vais suivre vos conseils.
Pour moi le dossier est clôturé, et vous souhaites une bonne journée.
