Hallo everyone!!
I’ve done a project that uses multiple sensors to send over the internet to android. but the problem is that Nodemcu has only A0 pins and I need 4 pins. I get a reference from internet that can use ADC extender ads1115 16 bit with I2C communication. can be used but can not be sent via the internet. I do not know what’s wrong. Please help me. thank you.
#define BLYNK_MAX_SENDBYTES 256
#include <Wire.h>
#include <Adafruit_ADS1015.h>
/// I2C ADC EXTENDER///////////////////////
Adafruit_ADS1115 ads(0x48);
/// WIFI//////////////////////////////
char auth[] = "cba1761bec994abaac3a66a17892c8cf";
char ssid[] = "hotspotkokobodo";
char pass[] = "kokobodo1";
int A=0;
int B=0;
int C=0;
Wire.begin(D1,D2);
ads.setGain(GAIN_ONE);
ads.begin();
void sensor_kelenturan()
{ int16_t adc0,adc1,adc2,adc3; // inisialisasi pin ADC dari ads1115 alamat 0x49 - vcc
adc0 = ads.readADC_SingleEnded(4);
adc1 = ads.readADC_SingleEnded(5);
adc2 = ads.readADC_SingleEnded(6);
A=map(adc0,3100,6800,0,100);
B=map(adc1,4000,9800,0,100);
C=map(adc2,3800,9900,0,100);
Blynk.virtualWrite(V5 ,A);
Blynk.virtualWrite(V6 ,B);
Blynk.virtualWrite(V7 ,C);
Costas
October 24, 2017, 10:35am
2
@Kukuh_Priambodo welcome.
Post formatted code.
Search this site for ADS1115.
Gunner
October 24, 2017, 11:01am
3
Costas:
Or just wait for your freindly’ish neighbourhood mod to do it for you ('cuz… can’t sleep and bored )
Can you clarify the actual issue?
when I use this code, it works and can be seen in serial monitor ADC value. But when I combine it with code for Blynk and it does not work
#include <Wire.h>
Adafruit_ADS1115 ads(0x49);
void setup(void)
Wire.begin();
ads.begin();
void loop(void) {
int x,y,z,w;
int16_t adc0, adc1, adc2, adc3; // inisialisasi pin ADC dari ads1115
adc0 = ads.readADC_SingleEnded(0);
adc1 = ads.readADC_SingleEnded(1);
adc2 = ads.readADC_SingleEnded(2);
adc3 = ads.readADC_SingleEnded(3);
x=map(adc0,6877,10400,0,100);
y=map(adc1,6900,10500,0,100);
z=map(adc2,6900,10500,0,100);
w=map(adc3,0,17463,0,100);
Serial.println("x");
Serial.println(x);
Serial.println("y");
Serial.println(y);
Serial.println(" ");
Serial.println(w);
Serial.println("**************");
Gunner
October 24, 2017, 11:42am
5
Kukuh_Priambodo:
I see… well you need to create a timer (in your void setup() ) to actually call your scan and print data function
timer.setInterval(1000L, value);
like that ?
Costas
October 24, 2017, 1:05pm
7
Kukuh_Priambodo:
like that ?
not quite
timer.setInterval(1000L, yourFunction);
void yourFunction(){
// some code to establish / display value
#include <Wire.h>
int A=0;
int B=0;
int C=0;
void sensor()
Wire.begin(D1,D2);
ads.begin();
timer.setInterval(1000L, sensor);
Still not working on Blynk
Costas
October 24, 2017, 1:38pm
9
@Kukuh_Priambodo what did you learn by studying the existing ADS1115 projects?
I dont know much about ads1115. I just want to add an analog pin from nodemcu, so I can send ADC value to Blynk app. That is all. Maybe you have some suggestions on this so that I can send more than one ADC value to Blynk app. Thankyou @Costas
Costas
October 24, 2017, 1:54pm
11
@Kukuh_Priambodo to get the most out of Blynk and the internet generally you need to be able to search .
Hi Blynkers,
I wanted to show a small set-up using the ADS1115 with the Wemos Mini D1. This is not a “project” by itself, I posted several photos and more details in the forum a few months ago but the info was a little bit disordered so I think it’s a good idea to post all info together… I guess it could be useful in order to spread the world about Blynk …
-Description:
The ADS1115 is a 16 bit Analog Digital Converter:
-Library required:
-Schematics:
[image]
-The code (Keep …
I’ve tried but cannt send to blynk
Costas
October 24, 2017, 2:01pm
14
@Kukuh_Priambodo did you copy the sketch exactly?
Did you try a basic blink LED sketch before moving on to the ADS1115?
void READ()
int x=0;
x = analogRead(A0);
Blynk.virtualWrite(V0 ,x);
timer.setInterval(1000L, READ);
[260] Connecting to hotspotkokobodo
[1263] Connected to WiFi
[1263] IP: 192.168.137.192
[1263]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.4.8 on NodeMCU
[5001] Connecting to blynk-cloud.com:8442
[5795] Ready (ping: 1ms).
Thanks for your attention @Costas
