I tried to use a 4051 analog multiplexer to increase my ADC port on a ESP8266. The setup works in Arduino IDE but I’m unable to port it to Blynk. Whenever I put 2 or more virtualWrite in the loop, the ESP8266 keep resetting and disconnecting from the network. Any help will be very much appreciated. Here’s my setup and my code
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example runs directly on ESP8266 chip.
You need to install this for ESP8266 development:
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
char auth[] = "***********"; //insert here your token generated by Blynk
Blynk.begin(auth, SSID, password);
pinMode(5, OUTPUT); //s0
pinMode(6, OUTPUT); //s1
pinMode(7, OUTPUT); //s2
void pin1() //y0
digitalWrite(5, 0);
digitalWrite(6, 0);
digitalWrite(7, 0);
Blynk.virtualWrite(V0, analogRead(A0));
void pin2() //y1
digitalWrite(5, 1);
digitalWrite(6, 0);
digitalWrite(7, 0);
Blynk.virtualWrite(V1, analogRead(A0));
void pin3() //y2
digitalWrite(5, 0);
digitalWrite(6, 1);
digitalWrite(7, 0);
Blynk.virtualWrite(V2, analogRead(A0));
pin1(); //read sensor value from y0
delay(500);
pin2(); //read sensor value from y1
delay(500);
pin3(); //read sensor value from y2
delay(500);
(P/S please don’t be too harsh with comments, I’m still a newbie without any electronic background)
but that’s not sufficient for me as I’m trying to make a real time sensor
