Also in this update:
Fixed bug when Time Input widget wasn’t synced.
Fixed bug when LCD widget ignored setProperty command.
Added support for application/x-www-form-urlencoded content type in WebHook widget.
No more AP name restriction when provisioning a device via WiFi.
what about the custom notification sound / project function?
if - on local server - one can not push notification from hw to apple phone, nor the eventor widget not usable, what are the possibilities? why push notification is restricted on local server?
With one datastrem was working ok (also in fullscreen mode)
When I added two additional datastreams (3 in total) app crashed (and crashing after every time I try to pen Blynk) when I tried to swich to 3M history
Hope it will be solved,beacouse SuperCharts ROCKS!
I’ve just come across a bug with the Menu widget.
I’m running IOS 2.10.0 (5). Not sure if it was there in previous versions…
When you add a Menu widget then edit the widget to add additional menu options, these extra menu items disappear when you later go back and make a change to the Menu Widget.
Say you have options called A, B, C & D. When you edit the widget to change the title of the widget, only options A & B are shown in the drop-down. You have to go back and manually add the extra options each time a change is made.
