i download again the server files from bellow link
and test agail but the error doesn’t fix yet.
Ok. Thanks. I’ll check. For now you may add -Dcheckstyle.skip=true
to maven build command.
Do you have to remove Java 8?
Hi @Dmitriy,
I try #define BLYNK_USE_256_VPINS
but I still have 128 Pins
what I missed ?
server-0.40.1-java8.jar
Do you mean within the app?
No. Why?
yes dashboard buttons
For now support is done only on the server side. Do you really need 255 virtual pins?
Ok. We will try to add this into the next builds.
Its OK i now see that on Raspberry Pi Java 8 is OK if we use the correct version of Blynk Local Server.
I don’t know if his is the right place to say this but Blynk app could do with a switch that goes ON for a configured amount of time say 3, 4, 5… seconds for when you want to control a for lock for example where the lock has to remain open for a few seconds.
Nope, not the right place … try here: https://portal.productboard.com/blynk/tabs/2-all-your-ideas As well as searching this forum for all the similar timed button requests and alternative coding solutions - Like Here
