The BLYNK_WRITE_DEFAULT() function handle virtual write for all pins > 127, this is a small example to manage pins 181 and 190:
int pin = request.pin; // Which pin has trigger write
int value = param.asInt(); // Use param as usual.
//only for debug
Serial.print("virtual write pin: ");
Serial.print(pin);
Serial.print(" value: ");
Serial.println(value);
//handle pins actions
switch(pin){
case 181:
//your custom code for pin 181
Serial.println("TODO 181");
break;
case 190:
//your custom code for pin 190
Serial.println("TODO 190");
break;
Best Regards
