Hi
I’m using local server v0.41.0 and latest apps and latest Blynk library 0.5.4
My understanding is that it support up to 255 virtual pins; at least I can select them in my Blynk app.
However when I try to use Virtual Pins > 127 I get the following error when compiling. Is there something I’m missing ?
Blynk Library 0.5.4 is 2.5 months old whereas the App and Server references to this are newer… and I haven’t seen any reference to 255 vPins in any Blynk Library version notes, so it probably requires a newer library update (unreleased as of yet).
agree. I was thinking maybe there is a workaround / hack to enable it. I checked Blynkconfig.h
but nothing obvious. I even tried incorporating:
#define BLYNK_USE_256_VPINS
in my sketch but that didn’t work either
Found this… so yes, probably needs the full Blynk tribunal support (Server Apps (Beta only)
Library… sooooon? )
i think you have answered it - thank you.
Perhaps there is a quick and easy hack that Blynk community knows about…
I know that “no, not yet” is not the answer you want to hear … but based on what little I have looked at (as indicated in a simple library search for the number 128), It would be neither quick or easy to go through and modify all the relative lines of code to account for pins 129-255… assuming that is all that would be needed
But if you make it work, then great! let us know.
Eg. in Blynkhandlers.cpp
alone…
// Internal Virtual Pins
BLYNK_ON_WRITE_IMPL(InternalPinACON);
BLYNK_ON_WRITE_IMPL(InternalPinADIS);
BLYNK_ON_WRITE_IMPL(InternalPinRTC);
BLYNK_ON_WRITE_IMPL(InternalPinOTA);
// Regular Virtual Pins
BLYNK_ON_READ_IMPL(Default);
BLYNK_ON_WRITE_IMPL(Default);
BLYNK_ON_READ_IMPL(0 );
BLYNK_ON_READ_IMPL(1 );
BLYNK_ON_READ_IMPL(2 );
BLYNK_ON_READ_IMPL(3 );
BLYNK_ON_READ_IMPL(4 );
BLYNK_ON_READ_IMPL(5 );
BLYNK_ON_READ_IMPL(6 );
BLYNK_ON_READ_IMPL(7 );
BLYNK_ON_READ_IMPL(8 );
BLYNK_ON_READ_IMPL(9 );
BLYNK_ON_READ_IMPL(10);
BLYNK_ON_READ_IMPL(11);
BLYNK_ON_READ_IMPL(12);
BLYNK_ON_READ_IMPL(13);
BLYNK_ON_READ_IMPL(14);
BLYNK_ON_READ_IMPL(15);
BLYNK_ON_READ_IMPL(16);
BLYNK_ON_READ_IMPL(17);
BLYNK_ON_READ_IMPL(18);
BLYNK_ON_READ_IMPL(19);
BLYNK_ON_READ_IMPL(20);
BLYNK_ON_READ_IMPL(21);
BLYNK_ON_READ_IMPL(22);
BLYNK_ON_READ_IMPL(23);
BLYNK_ON_READ_IMPL(24);
BLYNK_ON_READ_IMPL(25);
BLYNK_ON_READ_IMPL(26);
BLYNK_ON_READ_IMPL(27);
BLYNK_ON_READ_IMPL(28);
BLYNK_ON_READ_IMPL(29);
BLYNK_ON_READ_IMPL(30);
BLYNK_ON_READ_IMPL(31);
#ifdef BLYNK_USE_128_VPINS
BLYNK_ON_READ_IMPL(32);
BLYNK_ON_READ_IMPL(33);
BLYNK_ON_READ_IMPL(34);
BLYNK_ON_READ_IMPL(35);
BLYNK_ON_READ_IMPL(36);
BLYNK_ON_READ_IMPL(37);
BLYNK_ON_READ_IMPL(38);
BLYNK_ON_READ_IMPL(39);
BLYNK_ON_READ_IMPL(40);
BLYNK_ON_READ_IMPL(41);
BLYNK_ON_READ_IMPL(42);
BLYNK_ON_READ_IMPL(43);
BLYNK_ON_READ_IMPL(44);
BLYNK_ON_READ_IMPL(45);
BLYNK_ON_READ_IMPL(46);
BLYNK_ON_READ_IMPL(47);
BLYNK_ON_READ_IMPL(48);
BLYNK_ON_READ_IMPL(49);
BLYNK_ON_READ_IMPL(50);
BLYNK_ON_READ_IMPL(51);
BLYNK_ON_READ_IMPL(52);
BLYNK_ON_READ_IMPL(53);
BLYNK_ON_READ_IMPL(54);
BLYNK_ON_READ_IMPL(55);
BLYNK_ON_READ_IMPL(56);
BLYNK_ON_READ_IMPL(57);
BLYNK_ON_READ_IMPL(58);
BLYNK_ON_READ_IMPL(59);
BLYNK_ON_READ_IMPL(60);
BLYNK_ON_READ_IMPL(61);
BLYNK_ON_READ_IMPL(62);
BLYNK_ON_READ_IMPL(63);
BLYNK_ON_READ_IMPL(64);
BLYNK_ON_READ_IMPL(65);
BLYNK_ON_READ_IMPL(66);
BLYNK_ON_READ_IMPL(67);
BLYNK_ON_READ_IMPL(68);
BLYNK_ON_READ_IMPL(69);
BLYNK_ON_READ_IMPL(70);
BLYNK_ON_READ_IMPL(71);
BLYNK_ON_READ_IMPL(72);
BLYNK_ON_READ_IMPL(73);
BLYNK_ON_READ_IMPL(74);
BLYNK_ON_READ_IMPL(75);
BLYNK_ON_READ_IMPL(76);
BLYNK_ON_READ_IMPL(77);
BLYNK_ON_READ_IMPL(78);
BLYNK_ON_READ_IMPL(79);
BLYNK_ON_READ_IMPL(80);
BLYNK_ON_READ_IMPL(81);
BLYNK_ON_READ_IMPL(82);
BLYNK_ON_READ_IMPL(83);
BLYNK_ON_READ_IMPL(84);
BLYNK_ON_READ_IMPL(85);
BLYNK_ON_READ_IMPL(86);
BLYNK_ON_READ_IMPL(87);
BLYNK_ON_READ_IMPL(88);
BLYNK_ON_READ_IMPL(89);
BLYNK_ON_READ_IMPL(90);
BLYNK_ON_READ_IMPL(91);
BLYNK_ON_READ_IMPL(92);
BLYNK_ON_READ_IMPL(93);
BLYNK_ON_READ_IMPL(94);
BLYNK_ON_READ_IMPL(95);
BLYNK_ON_READ_IMPL(96);
BLYNK_ON_READ_IMPL(97);
BLYNK_ON_READ_IMPL(98);
BLYNK_ON_READ_IMPL(99);
BLYNK_ON_READ_IMPL(100);
BLYNK_ON_READ_IMPL(101);
BLYNK_ON_READ_IMPL(102);
BLYNK_ON_READ_IMPL(103);
BLYNK_ON_READ_IMPL(104);
BLYNK_ON_READ_IMPL(105);
BLYNK_ON_READ_IMPL(106);
BLYNK_ON_READ_IMPL(107);
BLYNK_ON_READ_IMPL(108);
BLYNK_ON_READ_IMPL(109);
BLYNK_ON_READ_IMPL(110);
BLYNK_ON_READ_IMPL(111);
BLYNK_ON_READ_IMPL(112);
BLYNK_ON_READ_IMPL(113);
BLYNK_ON_READ_IMPL(114);
BLYNK_ON_READ_IMPL(115);
BLYNK_ON_READ_IMPL(116);
BLYNK_ON_READ_IMPL(117);
BLYNK_ON_READ_IMPL(118);
BLYNK_ON_READ_IMPL(119);
BLYNK_ON_READ_IMPL(120);
BLYNK_ON_READ_IMPL(121);
BLYNK_ON_READ_IMPL(122);
BLYNK_ON_READ_IMPL(123);
BLYNK_ON_READ_IMPL(124);
BLYNK_ON_READ_IMPL(125);
BLYNK_ON_READ_IMPL(126);
BLYNK_ON_READ_IMPL(127);
#endif
BLYNK_ON_WRITE_IMPL(0 );
BLYNK_ON_WRITE_IMPL(1 );
BLYNK_ON_WRITE_IMPL(2 );
BLYNK_ON_WRITE_IMPL(3 );
BLYNK_ON_WRITE_IMPL(4 );
BLYNK_ON_WRITE_IMPL(5 );
BLYNK_ON_WRITE_IMPL(6 );
BLYNK_ON_WRITE_IMPL(7 );
BLYNK_ON_WRITE_IMPL(8 );
BLYNK_ON_WRITE_IMPL(9 );
BLYNK_ON_WRITE_IMPL(10);
BLYNK_ON_WRITE_IMPL(11);
BLYNK_ON_WRITE_IMPL(12);
BLYNK_ON_WRITE_IMPL(13);
BLYNK_ON_WRITE_IMPL(14);
BLYNK_ON_WRITE_IMPL(15);
BLYNK_ON_WRITE_IMPL(16);
BLYNK_ON_WRITE_IMPL(17);
BLYNK_ON_WRITE_IMPL(18);
BLYNK_ON_WRITE_IMPL(19);
BLYNK_ON_WRITE_IMPL(20);
BLYNK_ON_WRITE_IMPL(21);
BLYNK_ON_WRITE_IMPL(22);
BLYNK_ON_WRITE_IMPL(23);
BLYNK_ON_WRITE_IMPL(24);
BLYNK_ON_WRITE_IMPL(25);
BLYNK_ON_WRITE_IMPL(26);
BLYNK_ON_WRITE_IMPL(27);
BLYNK_ON_WRITE_IMPL(28);
BLYNK_ON_WRITE_IMPL(29);
BLYNK_ON_WRITE_IMPL(30);
BLYNK_ON_WRITE_IMPL(31);
BLYNK_ON_WRITE_IMPL(32);
BLYNK_ON_WRITE_IMPL(33);
BLYNK_ON_WRITE_IMPL(34);
BLYNK_ON_WRITE_IMPL(35);
BLYNK_ON_WRITE_IMPL(36);
BLYNK_ON_WRITE_IMPL(37);
BLYNK_ON_WRITE_IMPL(38);
BLYNK_ON_WRITE_IMPL(39);
BLYNK_ON_WRITE_IMPL(40);
BLYNK_ON_WRITE_IMPL(41);
BLYNK_ON_WRITE_IMPL(42);
BLYNK_ON_WRITE_IMPL(43);
BLYNK_ON_WRITE_IMPL(44);
BLYNK_ON_WRITE_IMPL(45);
BLYNK_ON_WRITE_IMPL(46);
BLYNK_ON_WRITE_IMPL(47);
BLYNK_ON_WRITE_IMPL(48);
BLYNK_ON_WRITE_IMPL(49);
BLYNK_ON_WRITE_IMPL(50);
BLYNK_ON_WRITE_IMPL(51);
BLYNK_ON_WRITE_IMPL(52);
BLYNK_ON_WRITE_IMPL(53);
BLYNK_ON_WRITE_IMPL(54);
BLYNK_ON_WRITE_IMPL(55);
BLYNK_ON_WRITE_IMPL(56);
BLYNK_ON_WRITE_IMPL(57);
BLYNK_ON_WRITE_IMPL(58);
BLYNK_ON_WRITE_IMPL(59);
BLYNK_ON_WRITE_IMPL(60);
BLYNK_ON_WRITE_IMPL(61);
BLYNK_ON_WRITE_IMPL(62);
BLYNK_ON_WRITE_IMPL(63);
BLYNK_ON_WRITE_IMPL(64);
BLYNK_ON_WRITE_IMPL(65);
BLYNK_ON_WRITE_IMPL(66);
BLYNK_ON_WRITE_IMPL(67);
BLYNK_ON_WRITE_IMPL(68);
BLYNK_ON_WRITE_IMPL(69);
BLYNK_ON_WRITE_IMPL(70);
BLYNK_ON_WRITE_IMPL(71);
BLYNK_ON_WRITE_IMPL(72);
BLYNK_ON_WRITE_IMPL(73);
BLYNK_ON_WRITE_IMPL(74);
BLYNK_ON_WRITE_IMPL(75);
BLYNK_ON_WRITE_IMPL(76);
BLYNK_ON_WRITE_IMPL(77);
BLYNK_ON_WRITE_IMPL(78);
BLYNK_ON_WRITE_IMPL(79);
BLYNK_ON_WRITE_IMPL(80);
BLYNK_ON_WRITE_IMPL(81);
BLYNK_ON_WRITE_IMPL(82);
BLYNK_ON_WRITE_IMPL(83);
BLYNK_ON_WRITE_IMPL(84);
BLYNK_ON_WRITE_IMPL(85);
BLYNK_ON_WRITE_IMPL(86);
BLYNK_ON_WRITE_IMPL(87);
BLYNK_ON_WRITE_IMPL(88);
BLYNK_ON_WRITE_IMPL(89);
BLYNK_ON_WRITE_IMPL(90);
BLYNK_ON_WRITE_IMPL(91);
BLYNK_ON_WRITE_IMPL(92);
BLYNK_ON_WRITE_IMPL(93);
BLYNK_ON_WRITE_IMPL(94);
BLYNK_ON_WRITE_IMPL(95);
BLYNK_ON_WRITE_IMPL(96);
BLYNK_ON_WRITE_IMPL(97);
BLYNK_ON_WRITE_IMPL(98);
BLYNK_ON_WRITE_IMPL(99);
BLYNK_ON_WRITE_IMPL(100);
BLYNK_ON_WRITE_IMPL(101);
BLYNK_ON_WRITE_IMPL(102);
BLYNK_ON_WRITE_IMPL(103);
BLYNK_ON_WRITE_IMPL(104);
BLYNK_ON_WRITE_IMPL(105);
BLYNK_ON_WRITE_IMPL(106);
BLYNK_ON_WRITE_IMPL(107);
BLYNK_ON_WRITE_IMPL(108);
BLYNK_ON_WRITE_IMPL(109);
BLYNK_ON_WRITE_IMPL(110);
BLYNK_ON_WRITE_IMPL(111);
BLYNK_ON_WRITE_IMPL(112);
BLYNK_ON_WRITE_IMPL(113);
BLYNK_ON_WRITE_IMPL(114);
BLYNK_ON_WRITE_IMPL(115);
BLYNK_ON_WRITE_IMPL(116);
BLYNK_ON_WRITE_IMPL(117);
BLYNK_ON_WRITE_IMPL(118);
BLYNK_ON_WRITE_IMPL(119);
BLYNK_ON_WRITE_IMPL(120);
BLYNK_ON_WRITE_IMPL(121);
BLYNK_ON_WRITE_IMPL(122);
BLYNK_ON_WRITE_IMPL(123);
BLYNK_ON_WRITE_IMPL(124);
BLYNK_ON_WRITE_IMPL(125);
BLYNK_ON_WRITE_IMPL(126);
BLYNK_ON_WRITE_IMPL(127);
#endif
static const WidgetReadHandler BlynkReadHandlerVector[] BLYNK_PROGMEM = {
BlynkWidgetRead0, BlynkWidgetRead1, BlynkWidgetRead2, BlynkWidgetRead3,
BlynkWidgetRead4, BlynkWidgetRead5, BlynkWidgetRead6, BlynkWidgetRead7,
BlynkWidgetRead8, BlynkWidgetRead9, BlynkWidgetRead10, BlynkWidgetRead11,
BlynkWidgetRead12, BlynkWidgetRead13, BlynkWidgetRead14, BlynkWidgetRead15,
BlynkWidgetRead16, BlynkWidgetRead17, BlynkWidgetRead18, BlynkWidgetRead19,
BlynkWidgetRead20, BlynkWidgetRead21, BlynkWidgetRead22, BlynkWidgetRead23,
BlynkWidgetRead24, BlynkWidgetRead25, BlynkWidgetRead26, BlynkWidgetRead27,
BlynkWidgetRead28, BlynkWidgetRead29, BlynkWidgetRead30, BlynkWidgetRead31,
BlynkWidgetRead32, BlynkWidgetRead33, BlynkWidgetRead34, BlynkWidgetRead35,
BlynkWidgetRead36, BlynkWidgetRead37, BlynkWidgetRead38, BlynkWidgetRead39,
BlynkWidgetRead40, BlynkWidgetRead41, BlynkWidgetRead42, BlynkWidgetRead43,
BlynkWidgetRead44, BlynkWidgetRead45, BlynkWidgetRead46, BlynkWidgetRead47,
BlynkWidgetRead48, BlynkWidgetRead49, BlynkWidgetRead50, BlynkWidgetRead51,
BlynkWidgetRead52, BlynkWidgetRead53, BlynkWidgetRead54, BlynkWidgetRead55,
BlynkWidgetRead56, BlynkWidgetRead57, BlynkWidgetRead58, BlynkWidgetRead59,
BlynkWidgetRead60, BlynkWidgetRead61, BlynkWidgetRead62, BlynkWidgetRead63,
BlynkWidgetRead64, BlynkWidgetRead65, BlynkWidgetRead66, BlynkWidgetRead67,
BlynkWidgetRead68, BlynkWidgetRead69, BlynkWidgetRead70, BlynkWidgetRead71,
BlynkWidgetRead72, BlynkWidgetRead73, BlynkWidgetRead74, BlynkWidgetRead75,
BlynkWidgetRead76, BlynkWidgetRead77, BlynkWidgetRead78, BlynkWidgetRead79,
BlynkWidgetRead80, BlynkWidgetRead81, BlynkWidgetRead82, BlynkWidgetRead83,
BlynkWidgetRead84, BlynkWidgetRead85, BlynkWidgetRead86, BlynkWidgetRead87,
BlynkWidgetRead88, BlynkWidgetRead89, BlynkWidgetRead90, BlynkWidgetRead91,
BlynkWidgetRead92, BlynkWidgetRead93, BlynkWidgetRead94, BlynkWidgetRead95,
BlynkWidgetRead96, BlynkWidgetRead97, BlynkWidgetRead98, BlynkWidgetRead99,
BlynkWidgetRead100, BlynkWidgetRead101, BlynkWidgetRead102, BlynkWidgetRead103,
BlynkWidgetRead104, BlynkWidgetRead105, BlynkWidgetRead106, BlynkWidgetRead107,
BlynkWidgetRead108, BlynkWidgetRead109, BlynkWidgetRead110, BlynkWidgetRead111,
BlynkWidgetRead112, BlynkWidgetRead113, BlynkWidgetRead114, BlynkWidgetRead115,
BlynkWidgetRead116, BlynkWidgetRead117, BlynkWidgetRead118, BlynkWidgetRead119,
BlynkWidgetRead120, BlynkWidgetRead121, BlynkWidgetRead122, BlynkWidgetRead123,
BlynkWidgetRead124, BlynkWidgetRead125, BlynkWidgetRead126, BlynkWidgetRead127,
#endif
static const WidgetWriteHandler BlynkWriteHandlerVector[] BLYNK_PROGMEM = {
BlynkWidgetWrite0, BlynkWidgetWrite1, BlynkWidgetWrite2, BlynkWidgetWrite3,
BlynkWidgetWrite4, BlynkWidgetWrite5, BlynkWidgetWrite6, BlynkWidgetWrite7,
BlynkWidgetWrite8, BlynkWidgetWrite9, BlynkWidgetWrite10, BlynkWidgetWrite11,
BlynkWidgetWrite12, BlynkWidgetWrite13, BlynkWidgetWrite14, BlynkWidgetWrite15,
BlynkWidgetWrite16, BlynkWidgetWrite17, BlynkWidgetWrite18, BlynkWidgetWrite19,
BlynkWidgetWrite20, BlynkWidgetWrite21, BlynkWidgetWrite22, BlynkWidgetWrite23,
BlynkWidgetWrite24, BlynkWidgetWrite25, BlynkWidgetWrite26, BlynkWidgetWrite27,
BlynkWidgetWrite28, BlynkWidgetWrite29, BlynkWidgetWrite30, BlynkWidgetWrite31,
BlynkWidgetWrite32, BlynkWidgetWrite33, BlynkWidgetWrite34, BlynkWidgetWrite35,
BlynkWidgetWrite36, BlynkWidgetWrite37, BlynkWidgetWrite38, BlynkWidgetWrite39,
BlynkWidgetWrite40, BlynkWidgetWrite41, BlynkWidgetWrite42, BlynkWidgetWrite43,
BlynkWidgetWrite44, BlynkWidgetWrite45, BlynkWidgetWrite46, BlynkWidgetWrite47,
BlynkWidgetWrite48, BlynkWidgetWrite49, BlynkWidgetWrite50, BlynkWidgetWrite51,
BlynkWidgetWrite52, BlynkWidgetWrite53, BlynkWidgetWrite54, BlynkWidgetWrite55,
BlynkWidgetWrite56, BlynkWidgetWrite57, BlynkWidgetWrite58, BlynkWidgetWrite59,
BlynkWidgetWrite60, BlynkWidgetWrite61, BlynkWidgetWrite62, BlynkWidgetWrite63,
BlynkWidgetWrite64, BlynkWidgetWrite65, BlynkWidgetWrite66, BlynkWidgetWrite67,
BlynkWidgetWrite68, BlynkWidgetWrite69, BlynkWidgetWrite70, BlynkWidgetWrite71,
BlynkWidgetWrite72, BlynkWidgetWrite73, BlynkWidgetWrite74, BlynkWidgetWrite75,
BlynkWidgetWrite76, BlynkWidgetWrite77, BlynkWidgetWrite78, BlynkWidgetWrite79,
BlynkWidgetWrite80, BlynkWidgetWrite81, BlynkWidgetWrite82, BlynkWidgetWrite83,
BlynkWidgetWrite84, BlynkWidgetWrite85, BlynkWidgetWrite86, BlynkWidgetWrite87,
BlynkWidgetWrite88, BlynkWidgetWrite89, BlynkWidgetWrite90, BlynkWidgetWrite91,
BlynkWidgetWrite92, BlynkWidgetWrite93, BlynkWidgetWrite94, BlynkWidgetWrite95,
BlynkWidgetWrite96, BlynkWidgetWrite97, BlynkWidgetWrite98, BlynkWidgetWrite99,
BlynkWidgetWrite100, BlynkWidgetWrite101, BlynkWidgetWrite102, BlynkWidgetWrite103,
BlynkWidgetWrite104, BlynkWidgetWrite105, BlynkWidgetWrite106, BlynkWidgetWrite107,
BlynkWidgetWrite108, BlynkWidgetWrite109, BlynkWidgetWrite110, BlynkWidgetWrite111,
BlynkWidgetWrite112, BlynkWidgetWrite113, BlynkWidgetWrite114, BlynkWidgetWrite115,
BlynkWidgetWrite116, BlynkWidgetWrite117, BlynkWidgetWrite118, BlynkWidgetWrite119,
BlynkWidgetWrite120, BlynkWidgetWrite121, BlynkWidgetWrite122, BlynkWidgetWrite123,
BlynkWidgetWrite124, BlynkWidgetWrite125, BlynkWidgetWrite126, BlynkWidgetWrite127,
#endif
Perhaps as “simple” as creating an additional #ifdef
groups of code Don’t forget
BlynkHandlers.h
and other supporting files.
I don’t think he wants to wait
Virtual pins out of 0-127 range are be supported only via BLYNK_WRITE_DEFAULT() / BLYNK_READ_DEFAULT()
API
https://docs.blynk.cc/#blynk-firmware-blynktimer-blynk_write_default
There are no plans to support more than 128 pins on fw level via “easy API”.
The docs are updated
I never figured out how to use more than one of those functions at a time anyhow
And while this is @mars Topic… now I am curious… what does this have to do with when the official use of up to 255 virtual pins (using the normal functions) begin? Next Library release?
I had to hunt for this So for anyone curious…
http://docs.blynk.cc/#blynk-firmware-virtual-pins-control-blynkvirtualwritevpin-value
Note: For virtual pins with numbers > 127, the V128
syntax is not available.
Please use plain virtual pin number, for example:
Blynk.virtualWrite(128, "abc");
Ah, OK… I think that is where the assumptions started… that it was just code as normal, but now with MOWR vPins
thanks for that.
Just curious, is there a particular reason why
BLYNK_WRITE
is not supporting for vPIN > 127 ?
I tried
BLYNK_WRITE(V228) {
without
that runs too
