New widget Device Tiles. It is like Device Selector but with own layout for the group of devices, no docs yet. (Kindly ported back to Blynk app from one of the Blynk Business customer);
Dear @Dmytro,
I really thank you ( and your team ) for solving the problem ( 2 ) that I suffered a lot due to the excessive usage of terminal widget at my projects.
I already tested and it is fine now.
When you came Greece some time, I will buy your meal for sure…
Since you’re removing the history graph, i would ask if it would be possible to bring over a couple useful things to its successor, maybe as optional settings: showing numbered axes in the normal view (now they’re only in full screen) and grid lines.
I’m now seeing some very random times on the axis for the super graph. The time/value series is not correct. i.e. it is showing the wrong time against the value in the graph on both the x axis and when you trace the graph line with your finger. anyone else seeing this?
I tried Super Chart recently and it’s really modern, good looking chart. But is there any particular reason for removing History Chart out of Widget box? Why not keeping both of them in the offering? I’m asking you this because Super Chart is not compatible with Android versions bellow 7.0; I don’t know how it’s affecting iOS users, but Super Chart is not working on my wife’s Samsung J3.
Yes. It was built with very old “graph library” version. And superchart is built with new “graph library” version. So right now we have to support 2 different versions of the same library. That increases maintenance cost and APK file size.
No, in this case I’m using Blynk cloud. I’ve just tried it on old Samsung S2 with Android 4.3, same thing happens. Just empty widget frame with SOON sign on it.
