You guys gonna add them to the non full screen type aswell ?
Not that I have noticed… however on Android, I can have a triple tap zoom option that works with any app.
Super Graph is very super
But i still have 1 problem with it.
When i press and hold on screen a white line with date appears and also below the legend there are values. This is ok. But if i move my finger to the left or right values under legend go away.
I am using Samsung Edge 7.
Update: Sometimes i get empty values under legend just with pressing and not moving my finger.
It’s ok, as you probably are viewing graph with connect missing points option set to ON.
So does this release fix the twitchy sliders in Android ?
Cheers
kev
nice update. but we need trigger between devices. for example if temp on arduino go to 30 degree C then nodemcu pin D5 turn on
Yeah. But Eventor should do this job.
Yeah. but eventor only worked with one device ! for two device we must set same token ID in two devices
I know. This is in todo list.
Hi @Dmitriy I have checked the sliders in android on the new version and they work perfect!!!
Top job guys.
Cheers
Kev
@Dmitriy just a heads up to say the 6h plot still has the duplicated hours e.g. 10, 12, 13, in the latest version.
On the x labels - they are correct, for example, first 23 could be something like 23.05 and last one 23.55. We are working on corrections of x labels and some other issues in new graph, and they will released during several next builds.
@BlynkAndroidDev not sure you see the bug. It’s the reference to two 3am’s in a day. If you pull up any 6h plot in landscape mode you will see several hours of the day repeated. Therefore it’s unclear if it’s really a 6h plot or a 10 / 11h plot. Presumably it is actually a 6h plot but you can’t really see when events actually occurred with two 10am’s two 12 noon’s and two 1pm’s etc.
I can assure you that it is 6h in described case. It happens due to the formatting of x axis
