They also dont send the values. The switching shouldnt happen, but as I see it also doesnt send the values. The joystick widget also doesnt move around
Just tilting the joystick should not cause sending values, as they would not change. Only moving joystickâs handle (in tilt mode or not) would result in sending values (and itâs autoreturn if its enabled). Iâve rechecked: joystick is sending its data.
I donât see anything wrong with its work. Please explain whatâs works incorrectly.
Seems it is a bug of an incorrect display, Iâll check.
I donât understand how it should work. The values should be send on tilting the phone or not? Otherwise itâs kind of useless if you ask me. You says the moving the JoyStick would cause sending the values, but also it doesnât send values of you tilt it? Which is it?
With tilt ON the joystick could be used in landscape mode with same axises rotated according to the tilt (landscape, reversed landscape, reversed portrait).
Yes exactly, it doesnât do that. No matter how hard I try. It wonât move.
Iâm sure it is working. Iâll prepare additional a logging build to check screen orientation changes. Maybe you have something like portrait lock option on your device?
Check this logging build - it will log screen orientation changes
I;ve send you the log. I tried tilting in all ways. Hope it helps.
No, all other apps just rotate fine. That doesnât sound like the problem to me. If I have tilt on, the JoyStick just doesnât move around. When I control it manual (with the magic fingerâŚ) it works fine. Values get send nice and the servo is limited to the values I entered.
Hello.
I am using the Step H widget, and until a couple of days ago this widget accepted negative values.
Now it seems this does not work anymore.
I am using this to set how many degrees to lower temperature at night.
Positive values works fine, but it will not accept -1
or any negative number.
Is it a bug or is it not supported anymore?
Android Blynk version: 2.14.3
I donât see any joystickâs drag in your log - how are you using it?. Getting screen orientation works correctly on your device.
With trying to tilt. Only the shadow on the widget moves, not the JoyStick it self.
Could you record a video? I donât see any data to be sent from your joystick.
Could you show screenshot of the settings of this widget and describe the workflow of your work when it does not accept negative values
Iâve sent you the log and a video capture. The moving of the joystick in the middle is me using my finger, but otherwise, tilting doesnât work. It also disconnects, but itâs probably sending too fast, I would never steer my car this erratic, LOL
Fixed, Itâs just not showing selectorâs as a selected target. Next build with fixes would be released soon.
This shadow is indicating the tilt orientation (it is under the joystickâs handle). When you was moving the joystick - it was in a landscape orientation.
âbut otherwise, tilting doesnât workâ - what is not working, how are you expecting it to work?
I expect the damn joystick to move around when I tilt my phoneâŚ
