Same thing happening, only x and y get switched. 2.14.3 is app version. Let me know if you need to debug something
Readded widget, but didnt help
Ok, please describe what is wrong, and how it should work
I"ve set the two axis on the JoyStick from 100 - 124 and 0 - 250.
Itās mode is set to Auto return and Tilt on Phone rotate⦠So, the center value is 125 and 112. When I tilt my phone the two center values swap. E.g. 112 becomes 125 and vice versa. It doesnāt actually move the JoyStick widget, just swaps the Auto return values.
I donāt see such behavior in latest build. I see that in some cases it is possible that in value list in the widget this values could be swapped, but all data is sent corretly - if for pin 0 (which is X axis) you had setuped 100-124 it will send only data in this range on any tilt
Hmm, that is weird. Iāve also added the widget again with latest app update, but it still doesnāt work the way it should. I have it setup in Split mode b.t.w. I can try with merge mode though.
could you attach log of the data from your sketch?
Good question⦠you mean the debug log? I could try, but I think it will be tomorrow, my vision is starting to get blurred at this point (sun, garden, beerā¦)
Ok, I still think you are saying about the values you see in the widgetās top right corner? They are swapping, yes? Weāll fix it, but Iām sure the data is sent correctly
Well, my servo went haywire, thatās why I noticed it. Itās not really a big problem, but it would be REALLY cool if I could drive my van with phone tilting
Iāll try and make a log file for you to analyze.
Iām already working on logging build to log appās sent data
When will you have time - check this build and reproduce this bug with joystick and send us log (project list - info button on actionbar - āsend logā option in about screen)
My phone says it App not.installed. Gonna have to dig around why not. Iāll get back to you when I figured out how to install, stupid phone.
You need to uninstall the current version and install new.
Insightful, tnx
You got the logs but with this build it doesnt even switch the x and y anymore. Iām probably doing something wrong ā¦
Yep, itās a build with latest fixes to valueās show in the widget. I need log just to check values sending, are they correct or no.
Itās just the same with the latest release. I checked and there are no values send to the hardware when tilting Phone (via serial console on Wemos). Not even when the x- and y-axis seem to switch places on the widget.
Just tilting joystick should not cause value sending - itās a correct behavior
Widget is not showing X, Y values in top right corner, it is showing Pin 1 and Pin 2 values, so they should not be switched on tilt also. If you will drag joytickās handle correct data would be send.
Hi.
In my project are 5 devices. I switch devices with using widget Device selector. Each device haves Graph widget.
Problem: when I edit properties of Graph widget I link each this Graph with Device selector, but in editing window of Graph widget in part Source I see not Device selector - I see one from devices name.
In other way, when I link Graph widget with for example first device - in this case all remained devices haves Graph widgets which are linked with first devise also. This is the bug or I not understand how edit the properties of this widget.
Explain me please what I am doing not right.
Thank You.
PS. Android App v2.14.3.
