Hello i use this project. But i wanted to use the Menu widget instead of just go to the next patern with pushing the preset button.
I am a really big noob and just getting into this. So maybe what i say will sound stupid, but hey
we’ve all been there. I geuss.
Also i would like it that you can adjust the brightness of a pattern with the brightness slider. This is because sometimes i want it just to be darker or brighter. Possible??
I used the project from the link with the latest code.
SO how to use this code
BLYNK_WRITE(V1) {
switch (param.asInt())
case 1: // Item 1
Serial.println("Item 1 selected");
break;
case 2: // Item 2
Serial.println("Item 2 selected");
break;
case 3: // Item 3
Serial.println("Item 3 selected");
break;
default:
Serial.println("Unknown item selected");
With those things?
BLYNK_WRITE(vPIN_PRESET) {
if (varZone == ZONE || varZone == 1 && param.asInt()) nextPattern();
FastLED.show();
#define ARRAY_SIZE(A) (sizeof(A) / sizeof((A)[0]))
void nextPattern() {
gCurrentPatternNumber = (gCurrentPatternNumber + 1) % ARRAY_SIZ
void rainbow() {
// FastLED's built-in rainbow generator
fill_rainbow( leds, LED_NUMBER, gHue, varRainbowSpeed);
Blynk.virtualWrite(vPIN_BRIGHTNESS, varBrightness);
FastLED.delay(1000 / varSpeed);
void rainbowWithGlitter() {
// built-in FastLED rainbow, plus some random sparkly glitter
rainbow();
addGlitter(80);
void addGlitter( fract8 chanceOfGlitter) {
if ( random8() < chanceOfGlitter) leds[ random16(LED_NUMBER) ] += CRGB::White;
void confetti() {
// random colored speckles that blink in and fade smoothly
fadeToBlackBy( leds, LED_NUMBER, 10);
int pos = random16(LED_NUMBER);
leds[pos] += CHSV( gHue + random8(64), 200, 255);
void sinelon() {
// a colored dot sweeping back and forth, with fading trails
fadeToBlackBy( leds, LED_NUMBER, 20);
int pos = beatsin16(13, 0, LED_NUMBER);
leds[pos] += CHSV( gHue, 255, 192);
void juggle() {
// eight colored dots, weaving in and out of sync with each other
byte dothue = 0;
for ( int i = 0; i < 8; i++) {
leds[beatsin16(i + 7, 0, LED_NUMBER)] |= CHSV(dothue, 200, 255);
dothue += 32;
Now it is my own topic I’ve changed some thing in te post and title
