International Sub-Topics
@wanek Discourse has an option for you to “watch” / “track” topics / categories.
will check that out, thanks!
Am I the only one with font issues?
blynk_charset
blynk_topic
Possibly due to the KB/Language settings on your PC?
Mine is set for US English
MN = Montenegro (it could be ME as well)
BH = Bosnia and Herzegovina (BA, maybe?)
I can see that SLO is marked with SK. SLO is for Slovenian, SK is for Slovakian, those are completely different languages.
This is how I see it… looks like you don’t have emojis :frowning:
Well… I have both en_US and sv_SE installed so I’m way cooler than you :yum:
I have lots of emojis when composing messages! :face_with_raised_eyebrow: :scream: :thinking: :expressionless: :hushed:
Leading by example, I tried that Google-thing @Gunner keeps talking about :rofl: Apparently there have been some issues with displaying unicode emojis in Chrome and Windows 7. But my system is up-to-date so it shouldn’t affect me… but it does since I can’t render all symbols correct on this page:
Full Emoji List, v15.1 :rage:
I’ll look in to it and get back!
Ha… I just added Russian and Hebrew, just so I can Blynk notify in ways I can’t understand, but quantity over quality has got to count once in awhile. :stuck_out_tongue:
This might be more complicated than I first thought :weary:
If not previously installed, this patch will update the Segoe UI symbol font on Windows 7 and add support for emojis. GREAT!
Except that it’s Segoe UI Emoji that’s needed! :rage:
Quick fix: Download Segoe UI Emoji, install, reboot. Then it gets better, but not perfect:
Good enough for me!
Hey! Perhaps do not add HK and MO next to CN? It can be misleading since those two places use traditional chinese and primarily Cantonese.
@Pavlo hey I have the chinese subtitles for your kickstarter video I made a while back, would you be interested?
I do. let’s go
@Rahul
I thought that it’s misleading, but wasn’t sure. Will update.
Regarding the subtitles - please send me the file! Would love to add it to the video
I see no Italian yet :wink:
Language:
IT
Category Subtitle:
Domande, aiuto con i tuoi progetti Blynk, idee e soluzioni realizzate con Blynk. Lettura di sensori e controllo di dispositivi.
Topic template:
Prima di creare una nuova discussione:
  1. Cerca nel forum se esistono argomenti simili
  2. Controlla http://docs.blynk.cc e http://help.blynk.cc/ (in futuro aggiungeremo i collegamenti alla documentazione tradotta)
  3. Includi tutti i dettagli:
    • Modello del dispositivo e sistema di comunicazione. Ad esempio: Arduino UNO con lo shield Ethernet
    • Sistema operativo dello smartphone (iOS o Android) e relativa versione
    • Server Blynk o server locale
    • Versione della libreria Blynk
    • Includi il codice del tuo sketch. :point_up:Il codice va formattato come mostrato qua sotto
Basta racchiudere il codice tra due triplette di ```
Se non formatti il codice, la tua discussione potrebbe essere cancellata dai moderatori.
Hi @Pavlo,
Please, see Spanish translation from @RobertoMD and myself:
Category Subtitle:
Preguntas, ayuda en tus proyectos con Blynk, ideas y soluciones hechas con Blynk. Lee de cualquier sensor, controla cualquier hardware.
Topic template:
Antes de publicar un nuevo mensaje:
Busca en el foro hilos similares.
Comprueba http://docs.blynk.cc y http://help.blynk.cc/
Añade los siguientes detalles:
• Modelo de hardware y tipo de comunicación. Por ejemplo: Arduino UNO con escudo Ethernet.
• Sistema Operativo y versión de tu Smartphone (iOS o Android).
• Utilizas Servidor Blynk o un Servidor Local.
• Incluye la Versión de la librería Blynk.
• Añade tu código de programa. :point_up: El código debe estar formateado como se muestra a continuación:
Simplemente, pega tu código entre los símbolos ```
Si no le das formato a tu código, tu mensaje puede ser eliminado por los moderadores.
Best regards!!!
Hello … all …
I am TOOM from Thailand … I request to make Thai version of Blynk … Let me show and share…
Sawadee krap Toon. Can you translate the text below and post it here?
ภาษา :
TH (ชื่อย่อ)
Category Subtitle:
คำถามและความช่วยเหลือสำหรับโครงการ แนวความคิดและผลงานที่ทำด้วย Blynk. การอ่านค่าจากเซ็นเซอร์ต่างๆและการควบคุมบอร์ดฮาร์ดแวร์ใดๆ
Topic template:
ก่อนที่จะเริ่มหัวข้อใหม่
ค้นหากลุ่มหัวข้อการสนทนาที่คล้ายกันโดย
ตรวจสอบจาก http://docs.blynk.cc and http://help.blynk.cc/
ข้อมูลเพิ่มเติม
• บอร์ดฮาร์ดแวร์ +รูปแบบการสื่อสาร. ตัวอย่างเช่น :บอร์ด Arduino UNO กับ อินเทอร์เน็ตชิลด์
• ระบบปฎิบัติการของสมาร์ทโฟน (iOS or Android) + รุ่นที่ใช้
• ใช้เซริฟเวอร์ของ Blynk หรือ ตั้งเซริฟเวอร์เอง
• รุ่นของ Blynk Library
• เพิ่มส่วนของโปรแกรม sketch code. : โปรแกรมจะมีโครงสร้างตามรูปแบบข้างล่าง
สามารถวางส่วนของโปรแกรมระหว่างเครื่องหมายนี้ ```
ถ้าคุณไม่ได้ปรับส่วนของโปรแกรมของคุณ ห้วข้อนี้จะถูกลบโดยผู้ประสานงาน
กรูณาตอบกลับในหัวข้อนี้ เราจะดำเนินการสร้างหัวข้อภาษาระหว่างเราและเพิ่มเติมตามข้อมูลข้างบน
Language :
TH (use abbreviation)
Greetings to all the Blynkers, I could also collaborate in my free time with the community in Spanish.
I would like to see more content in my native language and attract more people from my environment to this great platform.
