Hi. As previously stated, i have bought a Samsung Gear Watch (LTE) just because of this app. I have also paid for the PRO version (GW) It works
Just a few thoughts in case someone is interested…
Background: i run a local server with several devices.
So, my list in order of importance (for me)
- a status widget is more than required. i cannot stress enough how important that is. a simple led like will do. or at least the button to change color depending on status if a small LED like is too hard to implement.
- a slider. you click on it and after that, from the rotating bezel, you set the desired value. touching the screen after setting the value should send that value.
- vibrate IF the button was detected as pressed.
- a longer time for executing the press of the button widget. if the press is not really short the command is not executed at all. if you press it really quick it works as supposed to.
- ability to add widget screens per device. you have only 6 buttons and that is all. if you can add one widget per device the possibilities are huge.
- one huge widget with only one big button on it. the color can change depending on status for example.
I can offer more ideas but i do not want to sound picky or to impose in any way. These are just ideas, but some of them are really useful and i really think they are not just for me.
I thank you for your work and i will stay tunned for any future updates. My personal advice: charge us 10Euros for it but make it more versatile.
P.S. Adding tokens by hand never was an issue for me. You will work
“hard” only once so i never used your token import feature. But that’s just me.
