Nice illustration of whole house monitoring showing the fridge / freezer compressor kicking in and powering down through the night (blue and red lines) and the first cuppa of the day
pF can also be worked out for those that are interested (0.86).
@PeteKnight fair comment about Kw and Amps, it was just some code testing we were doing. The screenshots are not true reflections of the app and the screenshot below is the first 2 tabs of the 4 tabs.
Actually I think you have a bug in My Apps for the 2 themes. Having changed the original project to dark, updated the app and also selected dark in the app settings, then as expected it gives the dark theme.
If the phone goes to sleep sometimes when it wakes it decides the light theme would be best. Or technically a variation of light with a bit of dark around the edges.
If I exit the app and return, the dark theme is OK again, until the next sleep.
A little bit late but the Dark theme look awesome!
In fact I have updated my projects using the SuperChart to dark!
IMHO, Dark theme is more comfortable to read.
Okay I think I need to buy a smart meter for my home since Im pulling about 45A 24/7 from my 63A supply and really need to keep an eye on it so nothing melts!
In the next couple of weeks we are hoping to do a major overhaul of one of our websites to give our appraisal of the different hardware systems we have tested. Obviously each individual has a different set of criteria, so for example if your maximum budget is $2 (plus ESP8266) then the ACS712 will be the way to go.
If you are not qualified to work with mains electricity then the Open Energy Monitor systems are probably best for you.
If you or your best mate are qualified electricians then the PeaceFair system is an excellent choice.
We will post a link to the website here when it’s been updated.
Meanwhile we are looking for 1000 individuals, only , who would be interested in obtaining low cost, high accuracy energy monitoring and control systems.
So @Castle you might want to hold off on your purchase.
