Now swap the buzzer for an LED but the resistor goes between D1 and the LED not GND and 3V3.
I have change the buzzer to LED. The LED always on even the fire is havenāt started but the light very dim.
Resistor is in the wrong place, D1 ā> 470R ----> LED. Once we have this working we can work out why the LED is not switching on and off, after this we will put the buzzer back in place. LEDās are great.
Just perfect.
But, the the LED canāt light on.
You keep changing your sketch!!!
Comment out all the Blynk.notify and Blynk.email calls in your sketch as I previously said they canāt be used until you have removed all the bugs from your code and added flame status conditions to stop them being repeated more frequently than every 15s.
Remove all this from setup() as you only have to wait 150ms to be informed if there is a fire.
// Notify immediately on startup
if(val==HIGH){
Blynk.notify("Flame!!!");
Blynk.email("nurlela.dabukke@gmail.com", "Flame!!!", "Sensor activated");
//Setup a function to be called every minute
timer.setInterval(10L, readSensor);
Use this for readSensor
void readSensor()
sensor = analogRead(analoog);
Serial.println(sensor); // display sensor value
// You can send any value at any time but don't send more that 10 values per second.
//Blynk.virtualWrite(V1, sensor); // if you have a display widget set up on V1 you can uncomment this
if (sensor < 100) // When the flame sensor detects a signal, buzzer beep
digitalWrite (buzzer, HIGH);
// Send email and PUSH messages but max 1 every 15s, logic to be added for this
//Blynk.email("nurlela.dabukke@gmail.com", "Flame!!!", "Sensor activated");
//Blynk.notify("Flame detected") + uptime + " minutes.");
digitalWrite (buzzer, LOW);
Serial.print("Buzzer state is ");
Serial.println(digitalRead(buzzer);
When you have done this let me know if the secondary LED on the flame sensor board is going on and off when you add and remove a flame.
Also paste the contents of Serial Monitor (not a screenshot, just paste the data).
Iām so sorry, I forgot to add comment to that line.
I have add comments, and the LED still off when the fire is started. And the content of serial monitor is:
Buzzer state is 0
888.00
Buzzer state is 0
887.00
Buzzer state is 0
888.00
Buzzer state is 0
887.00
Buzzer state is 0
888.00
Buzzer state is 0
889.00
Buzzer state is 0
887.00
Buzzer state is 0
Do you mean the LED attached to D1 or the secondary LED on the flame sensor board?
Iām interested in the LED on the flame sensor board that appeared to be working the other day and giving readings of < 100 in Serial Monitor.
Paste your sketch again.
Both LED are off.
char auth[] = "******************************************";
char ssid[] = "Redmi 3s";
char pass[] = "***********";
int buzzer = D1 ;// define buzzer Interface
int pin = D0; // define the flame sensor interface
int analoog = A0; // define the flame sensor interface
int val ;// define numeric variables val
float sensor; //read analoog value
void readSensor()
Serial.println(digitalRead(buzzer));
pinMode (buzzer, OUTPUT) ;// define buzzer as output interface
pinMode (pin, INPUT) ;// output interface defines the flame sensor
pinMode (analoog, INPUT) ;// output interface defines the flame sensor
Blynk.notify("Device started");
//if(val==HIGH){
//Blynk.notify("Flame!!!");
//timer.setInterval(10L, readSensor);
// Setup a function to be called every 200ms Costas
timer.setInterval(150L, readSensor); // Costas
I have cleaned up your code, save this as FlameSensorBad.ino and I will work back through this thread to find the version that appeared to work and we will call this FlameSensorGood.ino
// FlameSensorBad.ino per https://community.blynk.cc/t/create-push-notification-over-flame-sensor/15891/172
int buzzer = D1 ; // define buzzer Interface
int val ; // define numeric variables val
float sensor; // sensor variable as a float, think it needs to be an int
void readSensor()
Serial.begin(115200); // Debug console
//Blynk.notify("Device started"); // Notify immediately on startup
As per the comment I added I think you need int not float for āsensorā but donāt go changing anything yet.
I notice that your Fritzing schematics keep changing and that you were connecting the digital pin of the flame sensor to D0 on the WeMos and now itās shown as D5.
What is the actual connection on your bread board?
Iām not convinced this digital pin actually does anything other than give a second interface in addition to the analog interface.
Having compared the āgoodā sketch with the ābadā sketch there is very little difference so Iām going to say you are messing up on the bread board. Stop messing around with the sketch and make sure all the connections are going to the right pins and that you donāt have any loose connections.
Have you actually soldered pin headers on the WeMos or are you trying to do it with a āpush fitā header.
The latter generally will not work as I hate soldering and Iāve tried many times with āpush fitā headers.
Keep trying until the LED on the flame sensor starts working again and you get new analog values in Serial Monitor. Once this is reliable the LED / Buzzer attached to D1 on the WeMos should be plain sailing.
Sorry, I made wrong schematic diagram cause I remake it. But, in my circuit, D0 pin of sensor still connect to D0 of Wemos.
Any addition with the code? I have tried upload again that FlameSensorGood.ino, but still nothing happened with the secondary LED of the sensor.
Yes.
Have you soldered headers to the WeMos?
You donāt need to do anything with the sketch, keep checking all your connections and add / remove the flame until the flame sensor LED works and Serial Monitor gives different analog values.
Below is the cleaned up āgoodā sketch. You can try it but I donāt think itās a problem with the sketch.
/* FlameSensorGoodV1.ino per https://community.blynk.cc/t/create-push-notification-over-flame-sensor/15891/151
"The value in serial monitor amount 840 and 841 when the fire is off. Whereas the fire is on, the value is amount 40 and 41." */
char auth[] = "*********************************************";
void readSensor()
Serial.println(sensor); // display temperature
val = digitalRead (pin) ;// digital interface will be assigned a value of 3 to read val
if (val == HIGH) // When the flame sensor detects a signal, buzzer beep
Actually the sample sketches I have seen are using analog or digital NOT both. Iām not an analog fan so Iām going to provide a new sketch just using the digital pins. Disconnect the wire from A0 on the WeMos and try this:
/* FlameSensorDigitalV1.ino per https://community.blynk.cc/t/create-push-notification-over-flame-sensor/15891/
Just using digital interface, disconnect wire from AO on the WeMos and watch LED on the flame sensor board */
//int analoog = A0; // define the flame sensor interface NOT NEEDED
//float sensor; // sensor variable as a float, think it needs to be an int NOT NEEDED
void readSensor()
//sensor = analogRead(analoog);
//Serial.println(sensor); // display temperature
Serial.print("Digital pin is ");
Serial.println(val);
// pinMode (analoog, INPUT) ;// output interface defines the flame sensor NOT NEEDED
Then, if I use analog pin, I canāt use buzzer? Cause, I need measure the flame value .
You can still use the buzzer but letās try to get the LED working (on the sensor board and the one attached to the WeMos).
For reference the trim pot is used to alter the sensitivity of the digital sensor trigger (not analog values).
I think, itāll better if I remove the buzzer. But, I want to add an LDR and two PIR sensors with LED indicator, how to do it? The condition for LDR and PIR 1 is LED will be on only if there is light and if there is motion. And the condition for PIR 2 is LED will be on only if there is motion. By the way, the analog PIN on my wemos have been used by flame sensor and the LDR use analog pin. Should I change the shield?
