Hi, all
I want to make a Flame Sensor project with Push Notification when only the fire appear.
Here is my code:
#define BLYNK_PRINT SwSerial
char auth[] = "*****************************************";
int buzzer = 13 ;// define buzzer Interface
int pin = 2; // define the flame sensor interface
int analoog = A0; // define the flame sensor interface
int val ;// define numeric variables val
float sensor; //read analoog value
void notifyUptime()
sensor = analogRead(analoog);
Serial.println(sensor); // display temperature
long uptime = millis() / 60000L;
val = digitalRead (pin) ;// digital interface will be assigned a value of 3 to read val
if (val == HIGH) // When the flame sensor detects a signal, buzzer beep
digitalWrite (buzzer, HIGH);
digitalWrite (buzzer, LOW);
pinMode (buzzer, OUTPUT) ;// define buzzer as output interface
pinMode (pin, INPUT) ;// output interface defines the flame sensor
pinMode (analoog, INPUT) ;// output interface defines the flame sensor
SwSerial.begin(9600);
Blynk.begin(Serial, auth);
// Notify immediately on startup
if(val==HIGH){
Blynk.notify("Flame!!!");
// Setup a function to be called every minute
timer.setInterval(60000L, notifyUptime);
When I upload the code, there is no notif appear in my app, could you help me to fix it?
1 - where are you using sw serial in your sketch? i think nowhere. you should give some detail what board / mcu / communication module / flame sensor are you using.
2 - you shouldn’t use so long delays in blynk sketch like 1000 millis. remove that. (ideally you shouldn’t use delays at all)
3 - you are checking the val variable in setup, but you do not assign value to it only in notifyUptime, which is called after // Notify immediately on startup part. this way the value of val will always be 0 on first read.
4 - if(val==HIGH) Blynk.notify("Flame!!!"); is called only once, in setup, but never called in main loop. you should put this in the notifyUptime function, or a dedicated function, and call say every 15 seconds… or, probably better, you can hook up the digital output of the sensor to an interrupt pin, and get alarms in real time.
note, however, that interrupts are not beginner stuff. you have to study and understand very carefully what is written in that article. look for the details!
char auth[] = "*************************";
const byte interruptPin = 2;
volatile byte state = LOW;
//BlynkTimer timer;
void blink()
//long uptime = millis() /
state = !state;
Blynk.notify("Flame is detected");
pinMode (interruptPin, INPUT_PULLUP) ;
attachInterrupt(digitalPinToInterrupt(interruptPin), blink, CHANGE);
digitalWrite(buzzer,state);
//timer.run();
But, still nothing notif when upload it. Is there something wrong in my code?
@Maria, could you specify what kind of flame sensor are you using? a link from the webshop you’ve bought would be the best. it has analog or digital output? because in the sketch you hooked up to a digital pin, i assume it has a digital output.
if digital, please confirm:
it was correctly set the threshold value with the trimpot?
on flame present, it has low or high output? (this should be in specification, or you can simply test with a multimeter)
with your current code, at least the buzzer sounds correctly on flame event? if not:
first you should write a minimalist, non blynk sketch, and test if it works correctly:
#define FLAME 2
#define BUZZER 13
// we should know the sensor output level on flame detection is low or high?
// if low: use INPUT_PULLUP
// if high: use INPUT + a phisical pulldown resistor, say 10k
// in the following sketch i will assume that the sensor has a low signal on flame detection and threshold is set correctly with trimpot
pinMode(FLAME, INPUT_PULLUP);
pinMode(BUZZER, OUTPUT);
digitalWrite(BUZZER, LOW);
if (!digitalRead(FLAME)) digitalWrite(BUZZER, HIGH); // if sensor output is high, remove "!" from the if statement
else digitalWrite(BUZZER, LOW);
please confirm if this works correctly before going further!
in online mode, first of all, you have to be sure that you have a solid connection to blynk server, both on phone and mcu. (you can test this with sending just the mcu uptime in every second and see on a display widget in blynk app if increments regularly)
after all the above points are working reliable, you can implement the code for the flame sensor.
I use KY-026, and here is my reference code: https://tkkrlab.nl/wiki/Arduino_KY-026_Flame_sensor_module
It has 4 pin: VCC, A0, D0, & GND. I have test the sensor, it has run correctly. If there are no flame, then serial monitor will show value about about 1000 and the alarm is off. Whereas, if there are flame, the serial monitor will show value under 500 depending on the distance the flame from sensor. If the distance is very close to sensor, then the value under 50 and the alarm sound so loud.
@Maria looks like your very first sketch was the most suitable. Look at the mods marked as “Costas” in this one and see if it works. You might need to increase the 200L for timer.setInterval as you are using one of those slow Arduino devices.
void readSensor() // Costas
// long uptime = millis() / 60000L; Costas
//delay(1000); // Costas
if(val==HIGH){
// Setup a function to be called every 200ms Costas
timer.setInterval(200L, readSensor); // Costas
Ok, I will try. But, if I use ESP8266-01, how is the circuit diagram for push notif? Because I just use USB serial for the connection, but it’s not stable connection.
I would recommend against using the ESP-01 as it is very limited.
For almost the same price you can now buy a decent ESP i.e. one that is plug and play with a USB port.
Just to be clear the decent ESP’s only use USB for power / flashing and not the poor USB internet connection method.
See how you go with the latest sketch, consider which ESP you should be using and then someone will advise the required connections if you are still unsure.
For me the WeMos authentic ESP’s are #1.
I wouldn’t consider the clones unless you want a few hundred of them and have a good returns policy with the vendor.
If you decide to use WeMos you then just need to work out which one:
WeMos D1 - full size but AFAIK no benefit over the Mini
WeMos D1 Mini - I believe they are no longer produced or sold by WeMos
WeMos D1 Mini Pro - like the D1 mini but 16MB flash (rather than 4MB) and provisioned to accept an external antenna.
16MB use is still not available in the Arduino core so it works as a 4MB device. Work has been done for 16MB flash and with some manual tweaks it can be used but I have only ever used 4MB. Hopefully 16MB flash will appear in the core some time soon.
Then, I’ll use WeMos D1 because I just have WeMos D1 and ESP8266-01. But, the operating voltage max.3,3 V. Must I use breadboard power supply to increase the voltage?
You will be looking to reduce any 5V feeds down to the WeMos’ 3.3V.
Power the sensor with 3.3V as it might work at 3.3V. If it doesn’t use a voltage divider between sensor and the pins on the WeMos.
I have change the connection to WeMos, here is the sketch:
char ssid[] = "Redmi 3s";
char pass[] = "69AEE473";
int buzzer = 8 ;// define buzzer Interface
int pin = 4; // define the flame sensor interface
// long uptime = millis() / 6000L; Costas
if(val==HIGH){
But, when I upload, there are error:
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
I set the Board: “Wemos D1 & R2 mini”, CPU Frequency: “80 MHz”, Flash Size: “4M (3M SPIFFS)”, and Upload Speed: “115200”. Is it correct?
If not, the “CPU Frequency” is for which CPU? Is it my computer CPU? And what the mean of Flash Size: "4M (3M SPIFFS)?
