I have a problem when veryfy example “boards_GSM”. “SerialAT.begin(115200)” was not declared in scope.
Please help me!
I moved your question into a new topic instead of that years old one.
Your issue is probably bad syntax (aka code typos)
This is NOT a code factory or code mechanics shop, but please post the full code you are using here (properly formatted after pasting, as per the instructions).
The example is fine, problem is your code/board config. But with such a “flood” of information it is all we can say here…
