I am trying the new libraries with the MKR1400 (UBLOX SARA-U201). I have tried everything I know to try, and what has been suggested in the forums. I am using Hologram for SIM service, and I have no issues sending data to the cloudsocket.hologram.io server using the MKRGSM.h library. When I try to use Blynk v0.5.3 libraries along with TinyGSM 0.3.5 libraries, my modem simply does not respond. Here is my code (any help would be greatly appreciated!):
//#define BLYNK_PRINT Serial
#define TINY_GSM_MODEM_UBLOX
//#define BLYNK_HEARTBEAT 30
#define SerialAT Serial1
// libraries
#include <TinyGsmClient.h>
#include <BlynkSimpleSIM800.h>
// APN data
char apn[] = "hologram";
char user[] = "";
char pass[] = "";
//Blynk App Auth Token
char auth[] = "bd83de9139b847fcb67c53ba33d93d50";
TinyGsm modem(SerialAT);
// initialize sensor variables
#define M A1
int value;
String mval;
void SensorRead()
pinMode(M, OUTPUT);
value = analogRead(M);
Serial.println(value);
BLYNK_READ(V5)
SensorRead();
Blynk.virtualWrite(V5, value); //sending to Blynk
// Debug
// Set GSM module baud rate
SerialAT.begin(19200);
delay(3000);
modem.restart();
delay(3000);
String modemInfo = modem.getModemInfo();
Serial.print("Modem: ");
Serial.println(modemInfo);
//Function Calls
I have also been able to get my device to work over Wia in this way:
#include <ArduinoHttpClient.h>
#include <MKRGSM.h>
#include <ArduinoJson.h>
// PIN Number
const char PINNUMBER[] = ""; //blank if no pin
// APN data: check settings on mobile for sim provider or contact carrier for network settings
const char GPRS_APN[] = "hologram";
const char GPRS_LOGIN[] = "";
const char GPRS_PASSWORD[] = "";
// get this from the wia dashboard. it should start with `d_sk`
const char* device_secret_key = "SECRETKEYHERE";
GSMClient client;
GPRS gprs;
GSM gsmAccess;
#define M A1
int value;
String mval;
// Wia API parameters
char server[] = "api.wia.io";
char path[] = "/v1/events";
int port = 80;
StaticJsonBuffer<512> jsonBuffer;
HttpClient httpClient = HttpClient(client, server, port);
JsonObject& root = jsonBuffer.createObject();
String response;
int statusCode = 0;
String dataStr;
void SensorRead()
pinMode(M, OUTPUT);
SensorRead();
// initialize serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Starting GSM connection to Wia!.");
// connection state
boolean connected = false;
// After starting the modem with GSM.begin()
// attach the shield to the GPRS network with the APN, login and password
while (!connected) {
if ((gsmAccess.begin(PINNUMBER) == GSM_READY) &&
(gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY)) {
connected = true;
Serial.println("Not connected");
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, port)) {
Serial.println("connected");
// if you didn't get a connection to the server:
Serial.println("connection failed");
root["name"] = "DATA";
root["data"] = value;
postToWia(root);
// read the status code and body of the response
statusCode = httpClient.responseStatusCode();
response = httpClient.responseBody();
Serial.print("Status code: ");
Serial.println(statusCode);
Serial.print("Response: ");
Serial.println(response);
delay(3.6e6); // Wait for 3 seconds to post again
void postToWia(JsonObject& data) {
data.printTo(dataStr);
httpClient.beginRequest();
httpClient.post(path);
httpClient.sendHeader("Content-Type", "application/json");
httpClient.sendHeader("Content-Length", data.measureLength());
httpClient.sendHeader("Authorization", "Bearer " + String(device_secret_key));
httpClient.beginBody();
httpClient.print(dataStr);
httpClient.endRequest();
