However, it might be not exactly what you need here. In general, you should not set the device owner in the meta field of the template. Because that’s a default value that will be used if the device doesn’t have an owner. If you want the new user to see the notifications you can transfer device ownership to this user - https://docs.blynk.io/en/blynk.console/devices/actions-with-devices#device-transfer.
In that case you don’t need to set the device owner in the template.
If you’re not the owner of the device, you still can get the notifications, for example you can specify receivers as “All users of the organization” or you can add the “contact” metafield to the device and fill it within the specific device with your email. In that case you’ll need to add “contact” meta as a receiver in the notifications.
Not quite clear. In template Device owner is empty. Now I have transferred Device owner to the User. In fact, I am not the owner of the device now, why should I receive notifications?
I got confused - after I transferred the Owner to the new User for some time notifications came to the device that was no longer the owner and nothing but the Device owner was registered in the recipient by default. Why?
Sorry to write on this old post, but I have the same problem and after looking thru the forum I found this one with a good solution, but unfortunately the step 3 dont work for me. After clicking on notifications settings the only page that appears is to search event.
what I am missing?
Hi Pete. In fact after doing a lot of work on all pages, I did a refresh and event showed on step3. From there I can include/exclude users from receiving notification, but the funny part is that on the event itself, I still only see the owner user.
I just posted the step 1, because as I said the step 3 appeared after I did a refresh on the page. Now i can make changes on the users. The only thing that I dont understant is why I can do it on the Edit Event page… but anyway, is working… thanks,
Good morning Pete. I assumed that was worked too fast. None of the users assigned received a notification… I read the documentation - Notifications Settings - Blynk Documentation - and the only thing that is different is the screenshot below:
That´s what is my page:
Although I can hover over the name and click on it and this screen appears:
As you can see there are 3 users listed.
As I said before, I still cannot change the users when configuring the event itself - see below:
and just to confirm, notifications management is enable…
What do you think is happening?
And just one last note, I checked if the notification is enable on the smartphones… they are…
Hello there. Just posting this so other users don´t make the same mistake as I did.
When creating an new event you have to insert a NAME - and the EVENT CODE field start copying what you write in the name with one litle difference that changes ALL. It copies using LOWER cases, so if you put a name and use any upper case, it will change to lower case.
In the event that the NAME and the EVENT CODE are the same and you dont pay attention to this, the event will never work because it will be different from what you coded on the device.
It will be better that this field dont start filling automatically.
Anyway, the problem was solved with the right spelling.
