Hello!
I need to know how to avoid DELAY in my code, it is blocking the sending of push data.
Thank you!
hardware: 2 ds18b20, Sonoff Basic (ESP8266)
#include <OneWire.h>
OneWire ourWire(14);
DallasTemperature sensors(&ourWire);
int RELAY = 12;
char auth[] = "********";
char ssid[] = "****";
char pass[] = "******";
void bomba()
{ sensors.requestTemperatures();
float TempE = sensors.getTempCByIndex(1);
float TempS = sensors.getTempCByIndex(0);
if (TempS < (3 + TempE))
{ int A = TempS;
delay (30000);
int B = TempS;
if (B <= A)
digitalWrite (RELAY, LOW);
if (TempS > (4 + TempE))
{ int C = TempS;
delay (30000);
int D = TempS;
if (D <= C)
digitalWrite (RELAY, HIGH);
void myTimerEvent()
Blynk.virtualWrite(V5, TempS);
Blynk.virtualWrite(V6, TempE);
pinMode(12, OUTPUT);
sensors.begin();
bomba();
void bomba()
{ int A = TempS;
int B = TempS;
if (B <= A)
{ int C = TempS;
int D = TempS;
if (D <= C)
sensors.begin();
timer.setInterval(2500L, bomba);
Thank you very much for your information Alexis, but I need there to be 30 seconds between the two temperature readings. This is so that the ralay is executed when the temperature stops increasing.
make 2 functions
Bomba1 and bomba2
and two timers
timer.setInterval(2500L, bomba1);
timer.setInterval(32500L, bomba2);
It does not work, int A = TempS is repeated every 2500ms and int B = TempS every 32500ms, therefore it compares the values ​​every 2500ms. I need you to compare the current temperature with that of 30sec behind.
Gunner
October 22, 2018, 11:32pm
6
Well, I fixed your post with proper formatting as required:
Hey, welcome to Blynk Community. This is the best place to ask questions, leave feedback and share your ideas. If this is the first time you hear about Blynk, check out our website www.blynk.cc and come back! As the community is big (and growing),...
But not too many will take lots of time to diagnose and rewrite your code for you… I suggest you work WITH @Blynk_Coeur and try to learn from what he has provided, not just say "It does not work… I need you to…"
Gunner
October 22, 2018, 11:42pm
7
Look at using timeout timers instead of delay()
void DoSomethingNow() {
// do stuff now
timer.setTimeout(30000, DoSomethingLater); // will run this function in 30 seconds
void DoSomethingLater() {
// do the later stuff
https://playground.arduino.cc/Code/SimpleTimer#Functions
#12 - Timers simplified… perhaps…
Some have a difficult time understanding timers… and since this is a fundamental building block of Blynk… I buried this reference in the middle of this entire topic Well anyhow…
This is a “real world” timer example where i am using two timers to alternately turn ON and OFF an LED… yes, there are many ways to do this, but this example is all about timers.
The first timer will run it’s assigned function 500ms (1/2 second) after boo…
perfect! thank you! I’m going to try that now!
32500-2500=30000 = 30 sec
so I don’t understand what do you want
if you need 2500 ms between A and B
just change timer, or use lambda function as @Gunner suggested you
there is an other mistake
A and B are int
TempS and TempE are float
Alexis thank you for your reply!
I need that when 30 seconds pass and the temperature has not increased the relay will turn on.
Sorry, but I’m very inexperienced in this and I can do it here and I do not know how to continue … XD
if pump1 runs every 2500ms (loop type) … when pump2 run for first time (32500ms), the comparison will not be made between pump2 and pump1 of the 30000ms?
Gunner
October 23, 2018, 7:16pm
12
Brian_Galli:
Part pseudo code… but should help stimulate the imagination and start the learning curve.
int variable1; // or float if required
int variable2; // or float if required
// check temperature, store value in variable1
// check temperature, store in variable2
// if variable 2 < variable1 then activate relay until next check
// else deactivate relay
here we go!!
char auth[] = "xxx";
char ssid[] = "xxx";
char pass[] = "xxx";
float TempS;
float TempE;
float A;
int RELAY = 13;
void myTimerEvent()
void lectura()
float A = TempS;
timer.setTimeout(30000, encendido);
void encendido()
if (TempS <= A)
{ pinMode(13, OUTPUT);
sensors.begin();
TempE = sensors.getTempCByIndex(0);
TempS = sensors.getTempCByIndex(1);
if (TempS > (TempE + 4))
lectura();
Gunner
October 23, 2018, 7:32pm
15
Now take all this OUT of the void loop() (no need to run it thousands of times a second) and put it in a timed function
@Gunner ,
I did this, is it ok?
the problem is that “A” changes value every time f “CONTROL” runs (1000ms)
char pass[] = "xxxx";
float A;
float B;
int RELAY = 13;
void myTimerEvent()
float TempE = sensors.getTempCByIndex(0);
float TempS = sensors.getTempCByIndex(1);
void control()
float TempP = sensors.getTempCByIndex(0);
float TempC = sensors.getTempCByIndex(1);
if (TempC > (TempP + 4))
A = TempC;
if (TempC < (TempP + 3))
B = TempC;
timer.setTimeout(20000, apagado);
void encendido()
float Temp2 = sensors.getTempCByIndex(1);
if (Temp2 <= A)
void apagado()
float Temp4 = sensors.getTempCByIndex(1);
if (Temp4 <= B)
sensors.begin();
timer.setInterval(1000L, control);
Gunner
October 24, 2018, 3:04am
17
Brian_Galli:
I am not actually following your code in any detail, I have my own projects I am working on I am just pointing out various notable things that I can see at a glance
Do you need these functions to run together? if so, merge them into ONE timed function… otherwise stagger them so they DON’T try to run at the exact same time (see the link to my timers post, above).
Gunner:
perfect, thank you very much!
The problem is I still can not compare temperatures with 30 seconds of difference
can you better explain what you are trying to accomplish? the logic in your latest code is hard to follow.
Also by looking at the drawing you provided it shows the comparison of two temperatures only 2500 ms apart
I did what @Gunner told me.
My oroginal code was this:
{ int A = TempS;
delay (30000);
if (TempS <= A)
{ int C = TempS;
delay (30000);
if (TempS <= C)
But I need to avoid DELAY function because it’s blocking the sending of data to Blynk app.
I need to compare the current temperature with the temperature of 30 seconds ago.
Thanks!!
