@Gunner told you how to do
Sorry ⦠But I do not understand that, where is the 30-second pause?
timer.setTimeout(30000, DoSomethingLater); // will run this function in 30 seconds
thatās what I did ⦠but how do I make that loop repeat?
if (TempC > (TempP + 4))
A = TempC;
timer.setTimeout(30000, encendido);
if (TempC < (TempP + 3))
B = TempC;
timer.setTimeout(20000, apagado);
void encendido()
float Temp2 = sensors.getTempCByIndex(1);
if (Temp2 <= A)
digitalWrite (RELAY, HIGH);
Your code snippets are still hard to decipher.
The concept of timers depends on the timer you use⦠you really need to sit down and read all about their different options, then experiment with simple concepts before plunging into something that affects real-world controls⦠checkout that link above⦠to my example sketches⦠it also has links to the SimpleTimer library that Blynk Timer is based on.
Then you can do lots of different ātimingā things without the delay()
Another pseudo code example⦠you want to have an action, every 5 minutes to take a reading, then compare it to itself 60 seconds later (for whatever reason⦠just spitballinā¦)
Ideally you would have an interval timer in setup() repeatedly calling a function, say⦠every 5 minutes. Then that function calls another for the reading, then runs a different type of timer⦠the timeout timer, which only runs the one time, x seconds later, to call another function⦠that then calls your sensors again, compares them, and does whatever logic you want based on the results.
timer.setInterval(3000000, MyFirstreading); // Interval timer will run this function every 5 minutes
void MyFirstreading() {
MySensors(); // run the sensor function
firstTemp = temp; // transfer the value
timer.setTimeout(60000, MySecondReading); // then run a timeout timer that runs once, 60 seconds later, each each time this containing function is called
void MySecondReading() {
secondTemp = temp;
// compare firstTemp with secondTemp and do something based on result
void MySensors() {
temp = sensor_read_command; // read a sensor, store it in a variable called temp
This example could be further refined with less functions⦠but I am trying to spread them out (the differing timers) for better viewing
Opps
I had the wrong type of timer showing in my above post, the one in setup() is supposed to be an interval, not a timeout. It is fixed now⦠and a few other syntax issues⦠happens when I make non-running pseudo code that is not verified in a compiler.
Excellent!!!
3000000 or 30000?
Well, it depends on how long you want the timer to run⦠I may have added an extra zero, making my example 50 minutes⦠opps
The defining number (a Long Integer) is in milliseconds, so 1,000 = 1 second & 60,000 = 1 minute. Multiply that by 5 = 300,000 = 5 minutes.
Math and me donāt get along, and we canāt use the thousands designation , in the code⦠so that is my excuse
Iām somewhat mathematically challenged, (AKA Iām crap at maths) so I prefer to do it this way:
timer.setInterval(5x(1000*60), MyFirstreading); // 5 minutes
timer.setInterval(50x(1000*60), MyFirstreading); // 50 minutes
timer.setInterval(120x(1000*60), MyFirstreading); // 120 minutes = 2 hours
or
timer.setInterval(2x(1000*60*60), MyFirstreading); // 2 hours
I like this approach because itās easy to see the actual value that youāre going to get at the start of the equation, and I can usually mange to remember that there are 1,000 millis in a second, 60 seconds in a minute and 60 minutes in an hour (at least after the first couple of cups of coffee!).
Excellent, and dare I say, obvious (just not to myself
) this might save me from having to remove my socks when countingā¦
Thank you very much to all!!!
It is working perfectly
You were very kind to me.
