I am having trouble getting my device connected. I am using an Arduino Uno Wifi rev2 board. My blynk library version is 1.0.1. I have seen that it says in the list of supported hardware to use MKR WiFi 1010 example for the uno wifi rev 2 board. I have then selected my board as “Arduino MKR1000” and my connection as “Arduino wifi shield 101”. When i try to upload this code to my board i get the following errors.
In file included from C:\Users\Admin\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:36:0,
from C:\Users\Admin\Documents\Arduino\libraries\Blynk\src/BlynkApiArduino.h:14,
from C:\Users\Admin\Documents\Arduino\libraries\Blynk\src/Adapters/BlynkWiFiCommon.h:24,
from C:\Users\Admin\Documents\Arduino\libraries\Blynk\src/BlynkSimpleWiFiShield101.h:19,
from C:\Users\Admin\OneDrive\Documents\FYP\Code\Uno\Uno.ino:27:
C:\Users\Admin\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h: In member function ‘long long int BlynkParam::iterator::asLongLong() const’:
C:\Users\Admin\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h:48:50: error: ‘atoll’ was not declared in this scope
long long asLongLong() const { return atoll(ptr); }
C:\Users\Admin\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h:48:50: note: suggested alternative: ‘atol’
atol
C:\Users\Admin\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h: In member function ‘long long int BlynkParam::asLongLong() const’:
C:\Users\Admin\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h:89:46: error: ‘atoll’ was not declared in this scope
long long asLongLong() const { return atoll(buff); }
C:\Users\Admin\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h:89:46: note: suggested alternative: ‘atol’
atol
exit status 1
Error compiling for board Arduino Uno WiFi Rev2.
This is my code:
#define BLYNK_TEMPLATE_ID "TMPLku1_viBB"
#define BLYNK_DEVICE_NAME "Quickstart Device"
#define BLYNK_AUTH_TOKEN "AzTvKBngOmwa05PJomky-LoEALnhidN-"
#include <WiFi101.h>
#include <BlynkSimpleWiFiShield101.h>
char pass[] = "YourPassword";
void myTimerEvent()
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
