Arduino Email Sending
how do i check if the terminal is connected?
Cut and paste the terminal text here (with backticks) and remove any tokens before uploading the post.
Don’t upload images of text.
Last login: Mon Mar  5 17:14:40 on ttys000
Daniils-Macbook:~ daniilkharlashko$ cd documents
Daniils-Macbook:documents daniilkharlashko$ cd arduino
Daniils-Macbook:arduino daniilkharlashko$ cd librariess
-bash: cd: librariess: No such file or directory
Daniils-Macbook:libraries daniilkharlashko$ cd scripts
-bash: cd: scripts: No such file or directory
Daniils-Macbook:libraries daniilkharlashko$ cd blynk
Daniils-Macbook:blynk daniilkharlashko$ cd  scripts
Daniils-Macbook:scripts daniilkharlashko$ sh ./blynk-ser.sh
       1 ports found. You can specify port manually using -c option
-n Select serial port [ /dev/tty.usbmodem1421 ]:
Resetting device /dev/tty.usbmodem1421...
[ Press Ctrl+C to exit ]
Connecting: GOPEN:/dev/tty.usbmodem1421,raw,echo=0,clocal=1,cs8,nonblock=1,ixoff=0,ixon=0,ispeed=9600,ospeed=9600,crtscts=0 <-> openssl-connect:blynk-cloud.com:8441,cafile=/Users/daniilkharlashko/documents/arduino/libraries/blynk/scripts/certs/server.crt,nodelay
2018/03/05 19:30:22 socat[31323] N opening character device "/dev/tty.usbmodem1421" for reading and writing
2018/03/05 19:30:23 socat[31323] N opening connection to LEN=16 AF=2 188.166.206.43:8441
2018/03/05 19:30:23 socat[31323] N successfully connected from local address LEN=16 AF=2 192.168.1.108:55239
2018/03/05 19:30:23 socat[31323] N trusting certificate, commonName matches
2018/03/05 19:30:23 socat[31323] N SSL connection using ECDHE-RSA-AES128-GCM-SHA256
2018/03/05 19:30:23 socat[31323] N SSL connection compression "none"
2018/03/05 19:30:23 socat[31323] N SSL connection expansion "none"
2018/03/05 19:30:23 socat[31323] N starting data transfer loop with FDs [5,5] and [8,8]
2018/03/05 19:30:23 socat[31323] E read(5, 0x7ffced804e00, 8192): Resource temporarily unavailable
2018/03/05 19:30:23 socat[31323] N exit(1)
Reconnecting in 3s...
2018/03/05 19:30:26 socat[31327] N opening character device "/dev/tty.usbmodem1421" for reading and writing
2018/03/05 19:30:26 socat[31327] N opening connection to LEN=16 AF=2 188.166.206.43:8441
2018/03/05 19:30:27 socat[31327] N successfully connected from local address LEN=16 AF=2 192.168.1.108:55241
2018/03/05 19:30:27 socat[31327] N trusting certificate, commonName matches
2018/03/05 19:30:27 socat[31327] N SSL connection using ECDHE-RSA-AES128-GCM-SHA256
2018/03/05 19:30:27 socat[31327] N SSL connection compression "none"
2018/03/05 19:30:27 socat[31327] N SSL connection expansion "none"
2018/03/05 19:30:27 socat[31327] N starting data transfer loop with FDs [5,5] and [8,8]
2018/03/05 19:30:27 socat[31327] E read(5, 0x7fbabb808800, 8192): Resource temporarily unavailable
2018/03/05 19:30:27 socat[31327] N exit(1)
2018/03/05 19:30:30 socat[31332] N opening character device "/dev/tty.usbmodem1421" for reading and writing
2018/03/05 19:30:30 socat[31332] N opening connection to LEN=16 AF=2 188.166.206.43:8441
2018/03/05 19:30:31 socat[31332] N successfully connected from local address LEN=16 AF=2 192.168.1.108:55245
2018/03/05 19:30:31 socat[31332] N trusting certificate, commonName matches
2018/03/05 19:30:31 socat[31332] N SSL connection using ECDHE-RSA-AES128-GCM-SHA256
2018/03/05 19:30:31 socat[31332] N SSL connection compression "none"
2018/03/05 19:30:31 socat[31332] N SSL connection expansion "none"
2018/03/05 19:30:31 socat[31332] N starting data transfer loop with FDs [5,5] and [8,8]
2018/03/05 19:30:34 socat[31332] E read(5, 0x7fa2bf815c00, 8192): Resource temporarily unavailable
2018/03/05 19:30:34 socat[31332] N exit(1)
2018/03/05 19:30:38 socat[31338] N opening character device "/dev/tty.usbmodem1421" for reading and writing
2018/03/05 19:30:38 socat[31338] N opening connection to LEN=16 AF=2 188.166.206.43:8441
2018/03/05 19:30:38 socat[31338] N successfully connected from local address LEN=16 AF=2 192.168.1.108:55246
2018/03/05 19:30:38 socat[31338] N trusting certificate, commonName matches
2018/03/05 19:30:38 socat[31338] N SSL connection using ECDHE-RSA-AES128-GCM-SHA256
2018/03/05 19:30:38 socat[31338] N SSL connection compression "none"
2018/03/05 19:30:38 socat[31338] N SSL connection expansion "none"
2018/03/05 19:30:38 socat[31338] N starting data transfer loop with FDs [5,5] and [8,8]
Looks like it’s dropping the connection.
socat is obviously running but I don’t see sudo before sh ./blynk-ser.sh
Could be that or a recent port change done by Blynk that is not in the script.
Do you know what library version you are using for Blynk?
@Dmytro any port changes needed for USB connection?
i am not sure what version i am running, with sudo it didn’t let me but with sh before ./blynk-ser.sh it worked
Google is everyone’s friend.
Your error message in Google suggests “temporary server fault”.
Either ports blocked at your end or the recent port changes by Blynk.
You need to know all version numbers for everything at all times. Check where you picked up the libraries for the version number. Meanwhile paste blynk-ser.sh here.
my blynk library is 100% 0.5.1 because i saw in my downloads
OK that’s the latest version but any port changes might not be included because USB is not particularly common. People generally use either the nigthmare ESP shield or simple ESP standalone.
Paste the script.
#define BLYNK_PRINT SwSerial
char auth[] = "confidential_token_here";
void myTimerEvent()
  SwSerial.begin(9600);
  Blynk.begin(Serial, auth);
I am very thankful for your help!
I didn’ t want to see the sketch, especially with your token, I wrote:
Whilst we are referring to the sketch it might be worth removing all the USB2TTL stuff like this:
//#define BLYNK_PRINT SwSerial
//#include <SoftwareSerial.h>
//SoftwareSerial SwSerial(10, 11); // RX, TX
void myTimerEvent()
  //SwSerial.begin(9600);
i am not sure what you mean by blynk-ser.sh here. and what do you mean by USB2TTL?
I am just new to this kind of stuff and i wanted to create something simple and then gradually increase the level of difficulty i still don’t know any specific keywords .
i have retried the terminal and this came up
Last login: Mon Mar  5 19:28:59 on ttys001
Daniils-Macbook:libraries daniilkharlashko$ vd blynk
-bash: vd: command not found
2018/03/05 20:42:43 socat[33048] N opening character device "/dev/tty.usbmodem1421" for reading and writing
2018/03/05 20:42:43 socat[33048] N opening connection to LEN=16 AF=2 188.166.206.43:8441
2018/03/05 20:42:43 socat[33048] N successfully connected from local address LEN=16 AF=2 192.168.1.108:55876
2018/03/05 20:42:44 socat[33048] N trusting certificate, commonName matches
2018/03/05 20:42:44 socat[33048] N SSL connection using ECDHE-RSA-AES128-GCM-SHA256
2018/03/05 20:42:44 socat[33048] N SSL connection compression "none"
2018/03/05 20:42:44 socat[33048] N SSL connection expansion "none"
2018/03/05 20:42:44 socat[33048] N starting data transfer loop with FDs [5,5] and [8,8]
2018/03/05 20:43:08 socat[33048] N socket 2 (fd 8) is at EOF
2018/03/05 20:43:08 socat[33048] N exiting with status 0
2018/03/05 20:43:11 socat[33076] N opening character device "/dev/tty.usbmodem1421" for reading and writing
2018/03/05 20:43:11 socat[33076] N opening connection to LEN=16 AF=2 188.166.206.43:8441
2018/03/05 20:43:11 socat[33076] N successfully connected from local address LEN=16 AF=2 192.168.1.108:55880
2018/03/05 20:43:12 socat[33076] N trusting certificate, commonName matches
2018/03/05 20:43:12 socat[33076] N SSL connection using ECDHE-RSA-AES128-GCM-SHA256
2018/03/05 20:43:12 socat[33076] N SSL connection compression "none"
2018/03/05 20:43:12 socat[33076] N SSL connection expansion "none"
2018/03/05 20:43:12 socat[33076] N starting data transfer loop with FDs [5,5] and [8,8]
2018/03/05 20:43:27 socat[33076] N socket 2 (fd 8) is at EOF
2018/03/05 20:43:27 socat[33076] N exiting with status 0
2018/03/05 20:43:30 socat[33084] N opening character device "/dev/tty.usbmodem1421" for reading and writing
2018/03/05 20:43:30 socat[33084] N opening connection to LEN=16 AF=2 188.166.206.43:8441
2018/03/05 20:43:30 socat[33084] N successfully connected from local address LEN=16 AF=2 192.168.1.108:55883
2018/03/05 20:43:31 socat[33084] N trusting certificate, commonName matches
2018/03/05 20:43:31 socat[33084] N SSL connection using ECDHE-RSA-AES128-GCM-SHA256
2018/03/05 20:43:31 socat[33084] N SSL connection compression "none"
2018/03/05 20:43:31 socat[33084] N SSL connection expansion "none"
2018/03/05 20:43:31 socat[33084] N starting data transfer loop with FDs [5,5] and [8,8]
2018/03/05 20:43:46 socat[33084] N socket 2 (fd 8) is at EOF
2018/03/05 20:43:46 socat[33084] N exiting with status 0
2018/03/05 20:43:49 socat[33089] N opening character device "/dev/tty.usbmodem1421" for reading and writing
2018/03/05 20:43:49 socat[33089] N opening connection to LEN=16 AF=2 188.166.206.43:8441
2018/03/05 20:43:49 socat[33089] N successfully connected from local address LEN=16 AF=2 192.168.1.108:55885
2018/03/05 20:43:50 socat[33089] N trusting certificate, commonName matches
2018/03/05 20:43:50 socat[33089] N SSL connection using ECDHE-RSA-AES128-GCM-SHA256
2018/03/05 20:43:50 socat[33089] N SSL connection compression "none"
2018/03/05 20:43:50 socat[33089] N SSL connection expansion "none"
2018/03/05 20:43:50 socat[33089] N starting data transfer loop with FDs [5,5] and [8,8]
2018/03/05 20:44:11 socat[33089] N socket 2 (fd 8) is at EOF
2018/03/05 20:44:12 socat[33089] N exiting with status 0
2018/03/05 20:44:15 socat[33095] N opening character device "/dev/tty.usbmodem1421" for reading and writing
2018/03/05 20:44:15 socat[33095] N opening connection to LEN=16 AF=2 188.166.206.43:8441
2018/03/05 20:44:15 socat[33095] N successfully connected from local address LEN=16 AF=2 192.168.1.108:55886
2018/03/05 20:44:15 socat[33095] N trusting certificate, commonName matches
2018/03/05 20:44:15 socat[33095] N SSL connection using ECDHE-RSA-AES128-GCM-SHA256
2018/03/05 20:44:15 socat[33095] N SSL connection compression "none"
2018/03/05 20:44:15 socat[33095] N SSL connection expansion "none"
2018/03/05 20:44:15 socat[33095] N starting data transfer loop with FDs [5,5] and [8,8]
Don’t be confused by the fact it looks like a URL, the .sh is a shell script that you are running with socat.
It is in the libraries that you downloaded from Blynk’s GitHub.
I could d/l it myself but you already have it hand for pasting here.
The fact you are not familiar with the file suggests you might not have done some of the recommended edits stated in the script file.
Let me know if you struggle to find it in the libraries.
so what do i need to do now>?
Paste here, with backticks, the contents of a file called blynk-ser.sh that was in the zip file you took from Blynk GitHub.
#!/bin/bash
# Detect script path
pushd `dirname $0` > /dev/null
SCRIPTPATH=`pwd`
popd > /dev/null
# === Edit default options to match your need ===
FROM_TYPE="SER" # SER, TCP
TO_TYPE="SSL"   # TCP, SSL
COMM_BAUD=9600
SERV_ADDR=blynk-cloud.com
SERV_PORT_SSL=8441
SERV_PORT_TCP=8442
SERV_PORT_2WAY=8443
LSTN_PORT=8442
SRVR_CERT="$SCRIPTPATH/certs/server.crt"
CLNT_CERT="$SCRIPTPATH/certs/client.pem"
# === Edit the lines below only if absolutely sure what you're doing ===
usage="
    This script redirects serial communication to the server.
    You can specify port, baud rate, and server endpoint like this:
      blynk-ser.sh -c <serial port> -b <baud rate> -s <server address> -p <server port>
    The defaults are:
      -c,--comm      single available port (on Linux, OSX)
                     COM1                  (on Windows)
      -b,--baud      9600
      -s,--server    blynk-cloud.com
      -p,--port      8442
    If the specified serial port is not found, it will ask to enter another one.
    The script also tries to reestablish connection if it was lost.
avrdude_warn="Warning: avrdude is running
 Avoid uploading sketches and running this script at the same time.
 If you didn't run avrdude, maybe it just stuck. You can kill it using:
   killall avrdude
function detect_conflicts {
    # Detect if avrdude is running
    if pgrep avrdude; then echo -n "$avrdude_warn"; fi
detect_conflicts
# Detect socat
if ! hash socat 2>/dev/null; then
    echo "This script uses socat utility, but could not find it."
    echo
    if [[ "$OSTYPE" == "linux-gnu"* ]]; then
        echo "  Try installing it using: sudo apt-get install socat"
    elif [[ "$OSTYPE" == "darwin"* ]]; then
        echo "  Try installing it using: brew install socat"
    fi
    exit 1
fi
# Execute getopt
    ARGS=$(getopt -o hf:c:b:l:t:s:p: -l "help,from:,comm:,baud:,listen:,to:,server:,port:,cert:" -n "blynk-gateway.sh" -- "$@");
    ARGS=$(getopt hf:c:b:l:t:s:p: $*);
fi
# Bad arguments
if [ $? -ne 0 ];
then
  echo -n "$usage"
  exit 1
fi
eval set -- "$ARGS";
while true; do
  case "$1" in
    -h|--help)
      shift
      echo -n "$usage"
      exit 0
    -f|--from)
      shift
      if [ -n "$1" ]; then
        FROM_TYPE=$1
        shift
      fi
    -c|--comm)
      shift
        COMM_PORT_USER=$1
        shift
      fi
    -b|--baud)
      shift
        COMM_BAUD=$1
        shift
      fi
    -l|--listen)
      shift
        LSTN_PORT=$1
        shift
      fi
    -t|--to)
      shift
        TO_TYPE=$1
        shift
      fi
    -s|--server)
      shift
        SERV_ADDR=$1
        shift
      fi
    -p|--port)
      shift
        SERV_PORT_SSL=$1
        SERV_PORT_TCP=$1
        SERV_PORT_2WAY=$1
        shift
      fi
    --cert)
      shift
        SRVR_CERT=$1
        shift
      fi
      shift;
      break;
  esac
done
# Construct command
GEN_ATTR="-d -d"
TCP_ATTR="nodelay" #,nonblock=1,rcvtimeo=1,sndtimeo=1
SER_ATTR="raw,echo=0,clocal=1,cs8,nonblock=1"
if [[ "$FROM_TYPE" == "SER" ]]; then
        COMM_WCARD="/dev/ttyUSB* /dev/ttyACM*"
        COMM_STTY="-F"
        COMM_WCARD="/dev/tty.usbserial* /dev/tty.usbmodem*"
        COMM_STTY="-f"
        echo "Can't detect OS type!"
        exit 1
    fi
    COMM_FOUND=`ls $COMM_WCARD 2> /dev/null`
    COMM_QTY=`printf "%s\n" $COMM_FOUND | wc -l`
    if [[ ! "$COMM_PORT_USER" == "" ]]; then
        COMM_PORT=$COMM_PORT_USER
    elif [[ "$COMM_QTY" == "1" ]]; then
        # Select single available port
        COMM_PORT=$COMM_FOUND
        # Ask for serial port interactively
        echo "$COMM_QTY ports found. You can specify port manually using -c option"
        echo -n "Select serial port [" $COMM_FOUND "]: "
        read COMM_PORT
    fi
    if [ ! -e "$COMM_PORT" ]; then
        echo "Can't find port: $COMM_PORT"
        echo "Please specify port manually using -c option"
        exit 1
    fi
    echo "Resetting device $COMM_PORT..."
    stty $COMM_STTY $COMM_PORT hupcl
    # Disable restarting
    #stty $COMM_STTY $COMM_PORT -hupcl
        FROM_ATTR="FILE:$COMM_PORT,$SER_ATTR,b$COMM_BAUD"
        FROM_ATTR="GOPEN:$COMM_PORT,$SER_ATTR,ixoff=0,ixon=0,ispeed=$COMM_BAUD,ospeed=$COMM_BAUD,crtscts=0"
    fi
elif [[ "$FROM_TYPE" == "TCP" ]]; then
    FROM_ATTR="TCP-LISTEN:$LSTN_PORT,reuseaddr,fork,$TCP_ATTR"
    echo "$FROM_TYPE is not supported."
    exit 1
fi
if [[ "$TO_TYPE" == "TCP" ]]; then
    echo "Warning: Server connection may be insecure!"
    TO_ATTR="TCP:$SERV_ADDR:$SERV_PORT_TCP,$TCP_ATTR"
elif [[ "$TO_TYPE" == "SSL" ]]; then
    if [ -e "$SRVR_CERT" ]; then
        TCP_ATTR="cafile=$SRVR_CERT,$TCP_ATTR"
        echo "Warning: $SRVR_CERT not found. Skipping server verification (connection may be insecure)!"
        TCP_ATTR="verify=0,$TCP_ATTR"
    fi
    if [ -e "$CLNT_CERT" ]; then
        TCP_ATTR="cert=$CLNT_CERT,$TCP_ATTR"
    fi
    TO_ATTR="openssl-connect:$SERV_ADDR:$SERV_PORT_SSL,$TCP_ATTR"
elif [[ "$TO_TYPE" == "2WAY" ]]; then
    echo "2WAY is not supported yet."
    exit 1
    echo "$TO_TYPE is not supported."
    exit 1
fi
# Setup exit handler
trap "echo Exited!; exit;" SIGINT SIGTERM
echo [ Press Ctrl+C to exit ]
while [ 1 ]; do
    echo Connecting: "$FROM_ATTR <-> $TO_ATTR"
    socat $GEN_ATTR "$FROM_ATTR" "$TO_ATTR"
    detect_conflicts
    echo Reconnecting in 3s...
    sleep 3
done
I have to go now i will talk tommorow thank you
Let me know when you are around tomorrow and we can work through the script you have posted.
@vshymanskyy and @Dmytro have any of the following port references for USB connections changed and if so what should they be now?
SERV_PORT_SSL=8441
SERV_PORT_TCP=8442
SERV_PORT_2WAY=8443
LSTN_PORT=8442
@Dankharl try changing this line in the script:
to
TO_TYPE="TCP" # TCP, SSL
See port change requirements in the next post.
Yes. In the latest library release - yes.
SERV_PORT_SSL=8441
SERV_PORT_TCP=80
SERV_PORT_2WAY=8443
LSTN_PORT=80
