Now m terminal is working but when i get to the blynk app it still does not display anything.
TERMINAL
Last login: Tue Mar 6 16:34:03 on ttys000
Daniils-Macbook:~ daniilkharlashko$ cd documents
Daniils-Macbook:documents daniilkharlashko$ cd arduino
Daniils-Macbook:arduino daniilkharlashko$ cd libraaries
-bash: cd: libraaries: No such file or directory
Daniils-Macbook:arduino daniilkharlashko$ cd libraries
Daniils-Macbook:libraries daniilkharlashko$ cd blynk
Daniils-Macbook:blynk daniilkharlashko$ cd scripts
Daniils-Macbook:scripts daniilkharlashko$ sh ./blynk-ser.sh
1 ports found. You can specify port manually using -c option
-n Select serial port [ /dev/tty.usbmodem1421 ]:
Resetting device /dev/tty.usbmodem1421...
[ Press Ctrl+C to exit ]
Connecting: GOPEN:/dev/tty.usbmodem1421,raw,echo=0,clocal=1,cs8,nonblock=1,ixoff=0,ixon=0,ispeed=9600,ospeed=9600,crtscts=0 <-> openssl-connect:blynk-cloud.com:8441,cafile=/Users/daniilkharlashko/documents/arduino/libraries/blynk/scripts/certs/server.crt,nodelay
2018/03/06 16:37:47 socat[36523] N opening character device "/dev/tty.usbmodem1421" for reading and writing
2018/03/06 16:37:47 socat[36523] N opening connection to LEN=16 AF=2 188.166.206.43:8441
2018/03/06 16:37:47 socat[36523] N successfully connected from local address LEN=16 AF=2 192.168.1.108:59359
2018/03/06 16:37:47 socat[36523] N trusting certificate, commonName matches
2018/03/06 16:37:47 socat[36523] N SSL connection using ECDHE-RSA-AES128-GCM-SHA256
2018/03/06 16:37:47 socat[36523] N SSL connection compression "none"
2018/03/06 16:37:47 socat[36523] N SSL connection expansion "none"
2018/03/06 16:37:47 socat[36523] N starting data transfer loop with FDs [5,5] and [8,8]
http://twitter.com/blynk_app
=> USB HOWTO: http://tiny.cc/BlynkUSB
char auth[] = "ABC";
DebugSerial.begin(9600);
Blynk.begin(Serial, auth);
