More like a horizontal line coming out from the LAST point, stretching to the left. But it is just a guess…
The last or the previous one (second from the last)
Not exactly. It appears to be connected to the most recent data point on the graph (right side) and then a straight line across the graph to the left. I also still saw one of my projects not draw any lines on the graph when i switched to it.
I’m uploading a new beta update:
I hope we are near release now.
Had anybody faced mentioned here gradient fill bug in chart and tabs glitches?
The live charts does not moving
Yep, I see that I’d broke live mode in super chart. The fix is uploading.
Sorry, I really tried to find a bug in the Bluetooth classic and BLE connectivity on ESP32, and I give it up: I didn’t find any bug. Not a single time “Packet too big”. No need to relogin, … Congratulations, I am convinced this will be the best build you made up till now for BT/BLE developpers!
App crashed when swiching between tabs in stop mode.
I’m report the bug from app
Update: app crashes when go to widget settings and get back.
tabs settings or any widget’s settings?
Any widget settings and switching between tabs in stop mode.
I could not reproduce and hadn’t received crash report o_0
Your device’s OS version?
Will it be possible to include a working Eventor or Email or Notification widget with BT/BLE? The options are not grayed out but the last time i tested it i did not any have success. The app kept bringing up a message saying the Blynk version is outdated. Please if its possible, at least let one of these widgets be compatible with BLE
Email and notification will not work with BLE/BT, maybe when we will have time to implement resending of their commands received from the BLE/BT device, but this mean that when the device will be disconnected - this logic would not work. Same issues apply to Eventor.
Looks like it is a crash with super chart. I just received the report - is your device Sony Xperia?
yes. XPERIA Z Ultra. but all widget settings crashes when open settings and get back
It is super chart widget crash, probably even not visible (pre-inited in the background tab)
I’m uploading new beta build with a fix to this issue.
Thanks for your time
I notice that pull data doesn’t always switch on automatically in BLE mode.
The strange thing is that when using Bluetooth classic, it does start automatically in all those cases.
What is ‘app loses focus’? Do you mean multi-window use of the app?
It is strange that 2 and 3 not working - I’ll check.
