Dashboard layout: variable rows amount (on devices like Pixel 2 XL, Samsung S9, etc.), drag/resize support fixes for the smartphones with disabled animations, double click on a widget should show the resize frame
Better color picker
Image Widget: refresh memory cache on images changes via set property commands
Super Chart: fix for not drawing lines bug
Device Tiles: Map widget support for templates, support for tile’s widgets selection to be used in home screen widgets
BLE support fixes
UI fixes and improvements
This update does not require server’s version update in the case of the local server setup.
it is a very good improvement !!
but now, the gauge always keeps the same color
Gunner
January 31, 2019, 11:02am
4
Ah, yes… it looks like we lost the colour gradient options?
Hm, I’ll check they should be available
What’s Android version is on your device - alpha slider looks bad and incorrect.
Gauge changes colors on my side, how to reproduce this behavior?
Gunner
January 31, 2019, 12:05pm
8
That might be due to the gif… it looks smoother in all my devices. Although the transparency can be a bit distracting.
as @Gunner said , we lost the colour gradient options.
last Android beta
ErfanDL
January 31, 2019, 12:11pm
10
Lost color changeing. Must selecting another color then back to the first color to apply changes.
On which widgets color selection is not working? I could not reproduce such behavior.
Does anybody have such UI of the alpha slider?
But you first gif looks much different, do you use different devices and they heave different look of this element?
my gif image is a screenshot from nox player
Got it, as I remember it is on Android 6?
I’ve fixed gradient, after alpha slider height fix I’ll upload new beta build.
Pavlo
January 31, 2019, 1:00pm
17
Please also fix transparency of the drawer background. It should be solid color. Thanks!
yes Android 6 on both, my phone and my nox player.
we are talking about those color gradients.
Yep, they are already fixed. I’ll make a post here when I’ll upload a new beta build.
