A post was split to a new topic: I would like to control the Nodemcu with natural voice commands
Can i use this code to link my esp8266 with my google home ? Because in GH i need a wemo account
Google Home doesnāt have the same native integration as Alexa, but you can connect through IFTTT. Just use IFTTTās Google Assistant trigger and the Blynk webhook action (instructions in the header comments of the code).
The great thing about Google Homeās IFTTT trigger is that you can specify any phrase, provide alternate phrases, and even create a custom response.
Hey,
The code works perfectly. But I have a case usually after power cut the wifi modem takes some time to be up. But the nodemcu immediately creates its own AP and stays there even after the wifi signal is back. in such cases I have connect to the hotspot and do a reset. Have you also faced such issue?
I had a look into the Documentation of WifiManager on Github.I found this:
https://github.com/tzapu/WiFiManager#configuration-portal-timeout
wifiManager.setConfigPortalTimeout(180);
So replacing this
with:
WiFiManager wifiManager;
//sets timeout until configuration portal gets turned off
//useful to make it all retry or go to sleep
//in seconds
wifiManager.setTimeout(180);
//fetches ssid and pass and tries to connect
//if it does not connect it starts an access point with the specified name
//here "AutoConnectAP"
//and goes into a blocking loop awaiting configuration
if(!wifiManager.autoConnect("AutoConnectAP")) {
Serial.println("failed to connect and hit timeout");
delay(3000);
//reset and try again, or maybe put it to deep sleep
ESP.reset();
delay(5000);
Hope this is helpful to people facing similar problems
I am using wemos D1 mini and relay board (4 relays, but for testing I keept everything.
Here is my code
#include <ESP8266WebServer.h>
#include <WiFiManager.h>
#include <DNSServer.h>
#define BLYNK_PRINT Serial // This prints to Serial Monitor
#include <ESP8266WiFi.h> // for ESP8266
#include <BlynkSimpleEsp8266.h> // for ESP8266
#include <ESP8266mDNS.h> // For OTA w/ ESP8266
#include <WiFiUdp.h> // For OTA
#include <ArduinoOTA.h> // For OTA
#include "WemoSwitch.h"
#include "WemoManager.h"
#include "CallbackFunction.h"
char auth[] = "xxxx";
char ssid[] = "xxxx";
char pass[] = "xxxx";
//for Alexa
//on/off callbacks
void bedroomlightson();
void bedroomlightsoff();
void loungelightson();
void loungelightsoff();
void gymlightson();
void gymlightsoff();
void tvon();
void tvoff();
void chargeron();
void chargeroff();
void switch1on();
void switch1off();
WemoManager wemoManager;
WemoSwitch *bedroomlights = NULL;
WemoSwitch *loungelights = NULL;
WemoSwitch *gymlights = NULL;
WemoSwitch *tv = NULL;
WemoSwitch *charger = NULL;
WemoSwitch *switch1 = NULL;
const int RelayPin1 = D4;
const int RelayPin2 = D7;
const int RelayPin3 = D6;
const int RelayPin4 = D5;
const int RelayPin5 = D0;
const int RelayPin6 = D1;
//end Alexa
//Alexa
pinMode(RelayPin1, OUTPUT);
digitalWrite(RelayPin1, LOW); // Turn relay OFF when unit is powered on
pinMode(RelayPin2, OUTPUT);
digitalWrite(RelayPin2, LOW); // Turn relay OFF when unit is powered on
pinMode(RelayPin3, OUTPUT);
digitalWrite(RelayPin3, LOW); // Turn relay OFF when unit is powered on
pinMode(RelayPin4, OUTPUT);
digitalWrite(RelayPin4, LOW); // Turn relay OFF when unit is powered on
pinMode(RelayPin5, OUTPUT);
digitalWrite(RelayPin5, LOW); // Turn relay OFF when unit is powered on
pinMode(RelayPin6, OUTPUT);
digitalWrite(RelayPin6, LOW); // Turn relay OFF when unit is powered on
//end Alexa
Serial.begin(9600); // BLYNK_PRINT data
//Alexa
WiFiManager wifi; //WiFiManager intialization.
wifi.autoConnect("FakeWemo"); //Create AP, if necessary
wemoManager.begin();
// Format: Alexa invocation name, local port no, on callback, off callback
bedroomlights = new WemoSwitch("bedroom lights", 80, bedroomlightson, bedroomlightsoff);
loungelights = new WemoSwitch("lounge lights", 81, loungelightson, loungelightsoff);
gymlights = new WemoSwitch("gym lights", 82, gymlightson, gymlightsoff);
tv = new WemoSwitch("tv", 83, tvon, tvoff);
charger = new WemoSwitch("charger", 84, chargeron, chargeroff);
switch1 = new WemoSwitch("switch 1", 85, switch1on, switch1off);
wemoManager.addDevice(*bedroomlights);
wemoManager.addDevice(*loungelights);
wemoManager.addDevice(*gymlights);
wemoManager.addDevice(*tv);
wemoManager.addDevice(*charger);
wemoManager.addDevice(*switch1);
//end alexa
WiFi.begin(ssid, pass);
Blynk.connect();
ArduinoOTA.setHostname("Wemos_0518"); // For OTA - Use your own device identifying name
ArduinoOTA.setPassword("xxxx");
ArduinoOTA.begin(); // For OTA
//Alexa
// Toggle the relay on
digitalWrite(RelayPin1, HIGH);
Blynk.virtualWrite(V1, HIGH); // Sync the Blynk button widget state
digitalWrite(RelayPin2, HIGH);
Blynk.virtualWrite(V2, HIGH); // Sync the Blynk button widget state
void gymlightson()
digitalWrite(RelayPin3, HIGH);
Blynk.virtualWrite(V3, HIGH); // Sync the Blynk button widget state
void tvon()
digitalWrite(RelayPin4, HIGH);
Blynk.virtualWrite(V4, HIGH); // Sync the Blynk button widget state
void chargeron()
digitalWrite(RelayPin5, HIGH);
Blynk.virtualWrite(V5, HIGH); // Sync the Blynk button widget state
void switch1on()
digitalWrite(RelayPin6, HIGH);
Blynk.virtualWrite(V6, HIGH); // Sync the Blynk button widget state
// Toggle the relay off
Blynk.virtualWrite(V1, LOW); // Sync the Blynk button widget state
Blynk.virtualWrite(V2, LOW); // Sync the Blynk button widget state
void gymlightsoff()
Blynk.virtualWrite(V3, LOW); // Sync the Blynk button widget state
void tvoff()
Blynk.virtualWrite(V4, LOW); // Sync the Blynk button widget state
void chargeroff()
Blynk.virtualWrite(V5, LOW); // Sync the Blynk button widget state
void switch1off()
Blynk.virtualWrite(V6, LOW); // Sync the Blynk button widget state
// Handle switch changes originating on the Blynk app
BLYNK_WRITE(V1){
int SwitchStatus1 = param.asInt();
if (SwitchStatus1 == 1) {
else {
BLYNK_WRITE(V2){
int SwitchStatus2 = param.asInt();
if (SwitchStatus2 == 1) {
else {
BLYNK_WRITE(V3){
int SwitchStatus3 = param.asInt();
if (SwitchStatus3 == 1) {
else {
BLYNK_WRITE(V4){
int SwitchStatus4 = param.asInt();
if (SwitchStatus4 == 1) {
else {
BLYNK_WRITE(V5){
int SwitchStatus5 = param.asInt();
if (SwitchStatus5 == 1) {
else {
BLYNK_WRITE(V6){
int SwitchStatus6 = param.asInt();
if (SwitchStatus6 == 1) {
else {
//end Alexa
//Alexa
wemoManager.serverLoop();
//end Alexa
ArduinoOTA.handle(); // For OTA
But when I try to compile the sketch, I get this error:
You need to choose how youāre going to connect the wifi. Right now, youāve got BOTH hard coded provisioning and WiFi Manager built into the sketch. If youāre going to hard code the SSID and password, youāll have to remove all of the WiFi Manager code.
Otherwise, just leave the provisioning code as it was in the example, and use Blynk.auth(āyour_tokenā) to connect to Blynk. You donāt need Blynk.connect or WiFi.begin.
So I can not have one default wifi network? For example that my home network is always entered and I do not need to reenter it everytime I come in a range of home network (I am using it also in my camper van)
I copied that code on my Wemos D1 mini, didnāt change anything (except auth), but I still get this error ![]()
The simple answer is āno,ā you canāt do both dynamic provisioning and hard-coded provisioning.
However, you could try static provisioning first, and if itās unable to connect, then run the WiFi manager code. I havenāt tested this, but hereās how Iād probably do it. In the Setup function, Iād try:
WiFi.begin("SSID", "password");
// Create a 10 second timeout for connecting with the saved credentials
int WiFiTimeout = millis() + 10000;
while (WiFi.status() != WL_CONNECTED && WiFiTimeout > millis())
delay(500);
Serial.print(".");
// If it didn't connect before the timeout expired, run WiFi Manager to set up dynamic provisioning
if(WiFi.status() != WL_CONNECTED){
WiFiManager wifi;
if(!wifi.autoConnect("FakeWEMO")) {
Serial.println("Failed to connect.");
ESP.reset(); //reset if new credentials failed.
Blynk.auth("your_token");
I use Wemos D1 miniā¦
@monaco A Wemos D1 Mini IS an ESP8266 based board
⦠and it appears you are running a old ESP8266 Arduino Core version of 2.2.0 ⦠so click on the link I provided above above, update it, then try again.
If anyone is having an issue with devices always responding āONā after updating to ESP8266 Arduino core 2.4.x, see the following article for the fix:
@chrome1000 I am trying to make this project with local blynk server and I write blynk.config(auth, ipaddress(192,168,1,15), 8080) but i start getting random errors about functions not being in scope. What should I do? It was working fine with blynk cloud server.
Thanks. Help will be appreciated.
If you want to use the IPAddress variable type then you need to identify it correctly (the first three characters are capitals, as Iāve just shown).
Otherwise just use a string literal like this:
blynk.config(auth, ā192.168.1.15ā, 8080)
@Chirag1712 you already have a topic open about this, please keep further correspondence on this issue in that topic.
this usually happens in this code when you have a missing closing bracket ā}ā
Itās now fixed in his other thread about which port to use.
Maybe @Gunner could do a bit of a cleanup on this thread to get rid of the detritus?
very nice project, all up and running on my blynk local server as well, i removed wifi manager in setup. now we have multiple ways of switching things with button feedbackā¦nice
