For about a month, I’ve been using Blynk with the IFTTT Maker Channel to connect projects to my Amazon echo. The thing that bugs me is that the Maker Channel requires the use of the word “trigger.” This makes for some awkward commands. Instead of saying “Alexa, turn on the bedroom lights,” I’m forced to say “Alexa, TRIGGER the bedroom lights on.”
However, the Echo has native integration with certain products (among them, the Belkin Wemo) that allow natural voice commands. The downside is that a Wemo switch is $50, and isn’t programmable. Thankfully, some clever folks have written code for the ESP8266 that allows it to emulate the Wemo, giving seamless integration with the Echo, and one in particular is written as a library that appears to be compatible with Blynk. Now, I can use natural voice commands, physical inputs, or Blynk to control the ESP. Using WiFiManager for provisioning, the code is pretty dead simple, too (EDIT - replaced with latest version. New features and options described in comments):
* Witnessmenow's ESP8266 Wemo Emulator library is an awesome way to build an IoT device on
* the cheap, and its direct integration with Alexa / Echo means that voice control can
* be done with natural sounding commands. However, it is limited by its reliance solely on
* voice control, as it doesnt work with the official Wemo app. It also provided no affordance
* for toggling the switch when an internet connection was unavailable.
* With just a bit of additional code, devices can be made controllable by the Blynk app, hardware
* switches, IFTTT event triggers,and of course, Alexa. Toss in OTA updates and Tzapulica's
* WiFiManager for easy provisioning, and you've got a really versatile, easy to use device.
* OTA updates are hardware dependent, but don't seem to cause any problems for devices
* that don't support it.
* Wemo Emulator and WiFi Manager libraries:
* https://github.com/witnessmenow/esp8266-alexa-wemo-emulator
* https://github.com/tzapu/WiFiManager
* In order to control a multitude of devices with a single Blynk dashboard, each ESP8266
* should be programmed with a unique virtual pin assignment, corresponding to a Blynk switch.
* The onboard LED is set to ON when the relay is off. This made sense to me, if you're looking
* for the physical switch in a dark room.
* For IFTTT control, use the Maker Channel with the following settings:
* URL: http://blynk-cloud.com:8080/YOUR_TOKEN/V1 Substitute your own token and vitual pin
* Method: PUT
* Content type: application/json
* Body: ["1"] Use 1 for ON, 0 for OFF
#include <DNSServer.h>
#include <WiFiManager.h>
#include <ESP8266WebServer.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include "WemoSwitch.h"
#include "WemoManager.h"
#include "CallbackFunction.h"
#define VPIN V1 //Use a unique virtual pin for each device using the same token / dashboard
char auth[] = "YOUR_TOKEN"; //Get token from Blynk
//on/off callbacks
void lightOn();
void lightOff();
WemoManager wemoManager;
WemoSwitch *light = NULL;
boolean LampState = 0;
boolean SwitchReset = true; //Flag indicating that the hardware button has been released
const int TacSwitch = 0; //Pin for hardware momentary switch. On when grounded. Pin 0 on Sonoff
const int RelayPin = 12; //Relay switching pin. Relay is pin 12 on the SonOff
const int LED = 13; //On / Off indicator LED. Onboard LED is 13 on Sonoff
WiFiManager wifi; //WiFiManager intialization.
wifi.autoConnect("FakeWemo"); //Create AP, if necessary
wemoManager.begin();
// Format: Alexa invocation name, local port no, on callback, off callback
light = new WemoSwitch("SonOfWemo", 80, lightOn, lightOff);
wemoManager.addDevice(*light);
pinMode(RelayPin, OUTPUT);
pinMode(LED, OUTPUT);
pinMode(TacSwitch, INPUT_PULLUP);
digitalWrite(RelayPin, LOW);
digitalWrite(LED, LOW);
Blynk.config(auth);
ArduinoOTA.begin();
timer.setInterval(100, ButtonCheck);
wemoManager.serverLoop();
ArduinoOTA.handle();
// Toggle the relay on
void lightOn() {
Serial.println("Switch 1 turn on ...");
digitalWrite(RelayPin, HIGH);
digitalWrite(LED, HIGH);
LampState = 1;
Blynk.virtualWrite(VPIN, HIGH); // Sync the Blynk button widget state
// Toggle the relay off
void lightOff() {
Serial.println("Switch 1 turn off ...");
LampState = 0;
Blynk.virtualWrite(VPIN, LOW); // Sync the Blynk button widget state
// Handle switch changes originating on the Blynk app
BLYNK_WRITE(VPIN){
int SwitchStatus = param.asInt();
Serial.println("Blynk switch activated");
// For use with IFTTT, toggle the relay by sending a "2"
if (SwitchStatus == 2){
ToggleRelay();
else if (SwitchStatus){
lightOn();
else lightOff();
// Handle hardware switch activation
void ButtonCheck(){
// look for new button press
boolean SwitchState = (digitalRead(TacSwitch));
// toggle the switch if there's a new button press
if (!SwitchState && SwitchReset == true){
Serial.println("Hardware switch activated");
if (LampState){
lightOff();
else{
lightOn();
// Flag that indicates the physical button hasn't been released
SwitchReset = false;
delay(50); //debounce
else if (SwitchState){
// reset flag the physical button release
SwitchReset = true;
void ToggleRelay(){
LampState = !LampState;
if (LampState){
lightOn();
else lightOff();
The Wemo emulator library can be found here: https://github.com/witnessmenow/esp8266-alexa-wemo-emulator
Yes, I realize that I’m breaking the Blynk rules by having additional code in the main loop, but it works!
Should’ve put manual override Dave.
or use amazon alexa app.
