If there were a way, either from the hardware side, or the app side, the clear the terminal blynk terminal window data. I read about send 24 new lines, but mine actually has way more than that in it. And that kinda is not a very good way to do it. Just a suggestion. It could be like the "erase all data’ on the graph widget.
Terminal now has a clear() method. It will be supported in upcoming iOS app update.
Oh, good news!
also in the next android update?
Ever since…
Either way works fine with Android 0.24.0 and up
terminal.clear();
Blynk.virtualWrite(Vx, "clr"); // Terminal Widget
I need to pay better attention to this… thnx!
It can be very difficult to keep up… even if you spend too much time in the forum like I do But the Announcement topics are worthy of reading through each time.
