WT32-Eth01 ethernet connection to blynk
Hi everyone
this my first post here, sorry if did it wong.
The program im using is Arduino IDE.
Im use wt32-eth01 that use’s eth.h Libary that has 8720 Ethernet chip
i have had it working with wifi and it works good ready my voltage, but there one location has no wifi only ethernet port available, i tried different sketchs but can’t seem get it working.
hope someone can point me right way.
lan port works fine, it get IP and can talk too google server(code removed).
Thanks Luke.
#define BLYNK_TEMPLATE_ID "TMPL6ImQYeF9o"
#define BLYNK_TEMPLATE_NAME "solar site"
#define BLYNK_AUTH_TOKEN "token code"
#include <ETH.h>
#include <Blynk.h>
static bool eth_connected = false;
void WiFiEvent(WiFiEvent_t event)
  switch (event) {
    case ARDUINO_EVENT_ETH_START:
      Serial.println("ETH Started");
      //set eth hostname here
      ETH.setHostname("esp32-ethernet");
      break;
    case ARDUINO_EVENT_ETH_CONNECTED:
      Serial.println("ETH Connected");
      break;
    case ARDUINO_EVENT_ETH_GOT_IP:
      Serial.print("ETH MAC: ");
      Serial.print(ETH.macAddress());
      Serial.print(", IPv4: ");
      Serial.print(ETH.localIP());
      if (ETH.fullDuplex()) {
        Serial.print(", FULL_DUPLEX");
      Serial.print(", ");
      Serial.print(ETH.linkSpeed());
      Serial.println("Mbps");
      eth_connected = true;
      break;
    case ARDUINO_EVENT_ETH_DISCONNECTED:
      Serial.println("ETH Disconnected");
      break;
    case ARDUINO_EVENT_ETH_STOP:
      Serial.println("ETH Stopped");
      break;
    default:
      break;
  WiFi.onEvent(WiFiEvent);
  ETH.begin();
  Blynk.begin(BLYNK_AUTH_TOKEN);
I suspect this may be your problem.
This might help…
Hi Pete,
i did see your project but i haven’t had lucky get it working, ethernet port wont light up at all, not sure where im going wrong. if don’t mind can help me get it working?
pretty sure my board base on esp32-s1 with 8720 add on top.
pin info:
ethernet:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO0_IN
phy_addr: 1
power_pin: GPIO16
Thanks Luke.
i have retry your project i get this error now
only settings i have change is ethernet pin info.
n file included from C:\Users\MiSTiC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\WiFi\src/WiFi.h:29,
from C:\Users\MiSTiC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\libraries\Ethernet\src/ETH.h:24,
from C:\Users\MiSTiC\AppData\Local\Temp.arduinoIDE-unsaved2023730-12632-1dw72aj.50md\sketch_aug30a\sketch_aug30a.ino:11:
C:\Users\MiSTiC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\cores\esp32/IPv6Address.h:92:2: error: multiple types in one declaration
C:\Users\MiSTiC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\cores\esp32/IPv6Address.h:92:2: error: declaration does not declare anything [-fpermissive]
When you post compiler error messages (or serial monitor output) you should use triple backticks in the same way as when you post code.
I don’t have your hardware, so that’s going to be very difficult.
In your original sketch, what have you replaced #include <Blynk.h> with?
sorry about that forgot backticks :sweat_smile:
i have tried different #include but no luck but i try using same one yours again.
OMG it is finally working after fixing some errors.
send my PSU unit voltage (testing) to blynk and it workings
thanks for help ALOT, i been tinkering for weeks with no luck. :joy: :joy: :joy:
you may know answer that this simple question, got mind blank going on atm.
my PSU is left on, i reboot MCU it seems too slowly count number up not showing true value straight away.
ETH MAC: C4:DE:E2:B2:D0:83, IPv4: 192.168.1.85, FULL_DUPLEX, 100Mbps
Voltage:1.58V
Voltage:2.91V
Voltage:4.32V
Voltage:5.70V
Voltage:7.06V
Voltage:8.47V
Voltage:9.84V
Voltage:11.28V
Voltage:12.70V
Voltage:14.09V
Voltage:14.02V
Voltage:14.08V
Voltage:14.15V
here’s full code and incase someone want use wt32-eth01 with blynk with ethernet.
#define BLYNK_TEMPLATE_ID "*********ID*******"
#define BLYNK_TEMPLATE_NAME "********name*******"
#define BLYNK_AUTH_TOKEN "**********token code******"
#define BLYNK_FIRMWARE_VERSION        "1.0.0" // For Blynk.Air OTA, Increment with each
//voltage input pin
#define IN_PIN 39 //voltage input pin
#define WINDOW_SIZE 10 //voltage sample size
#include <ETH.h>
// You can use either the SSL or non-SSL library. Stick with SSL unless you have a good reason to change...
//#include <BlynkSimpleEsp32.h>
#include <BlynkSimpleEsp32_SSL.h>
#include <Update.h>   // For Blynk.Air OTA
#include <HTTPClient.h> // For Blynk.Air OTA
//voltage settings/calc
int INDEX = 0;
int VALUE = 0;
int SUM = 0;
int READINGS[WINDOW_SIZE];
int AVERAGED = 0;
int voltage_offset = 14;// set the correction offset value
float voltage = 0;
  // This function is called every time the Virtual Pin 0 state changes
  BLYNK_WRITE(V0)
  // Set incoming value from pin V0 to a variable
  int value = param.asInt();
  // Update state
  Blynk.virtualWrite(V0, value);
  switch (event) {
      break;
      break;
      Serial.print(", ");
      break;
      break;
      break;
    default:
      break;
  ETH.begin();
 Blynk.config(BLYNK_AUTH_TOKEN);
    Blynk.connect();
    pinMode(IN_PIN, INPUT);
  if (eth_connected)
  // reading voltage io39 and calcation
  SUM = SUM - READINGS[INDEX];       // Remove the oldest entry from the sum
  VALUE = analogRead(IN_PIN);        // Read the next sensor value
  READINGS[INDEX] = VALUE;           // Add the newest reading to the window
  SUM = SUM + VALUE;                 // Add the newest reading to the sum
  INDEX = (INDEX+1) % WINDOW_SIZE;   // Increment the index, and wrap to 0 if it exceeds the window size
  AVERAGED = SUM / WINDOW_SIZE;      // Divide the sum of the window by the window size for the result
  double voltage = map(AVERAGED,0, 4096, 0, 1650) + voltage_offset;
  voltage /= 100;
  Blynk.virtualWrite(V0, voltage);
  Serial.print("Voltage:");
  Serial.print(voltage);
  Serial.println("V");
  delay (1000);
void myTimerEvent()
  Blynk.virtualWrite(V1, millis() / 1000); //uptime data to V1
BLYNK_WRITE(InternalPinOTA) // For Blynk.Air OTA
  String overTheAirURL = param.asString();
  HTTPClient http;
  http.begin(overTheAirURL);
  int httpCode = http.GET();
  if (httpCode != HTTP_CODE_OK) {return;}
  int contentLength = http.getSize();
  if (contentLength <= 0) {return; }
  bool canBegin = Update.begin(contentLength);
  if (!canBegin) { return;}
  Client& client = http.getStream();
  int written = Update.writeStream(client);
  if (written != contentLength) {return;}
  if (!Update.end()) {return;}
  if (!Update.isFinished()) {return;}
reboot();
void reboot() // For Blynk.Air OTA
  ESP.restart();
  for (;;) {} // Wait here until the restart has begun
i haven’t found it yet, how mark this topic as (solved) ???
Your void loop is a mess, and breakers several of the Blynk basic rules.
You should read this…
https://docs.blynk.io/en/legacy-platform/legacy-articles/keep-your-void-loop-clean
Looks like you voltage is the average of 10 reading. When you reboot it has to take 10 readings to get an accurate average. If you look at your output, after the 10th reading it stabilizes around 14V. You also have a delay (a no no for BLYNK) of 1 second. So it should take approx 10 seconds to get the 10 required measurements.
Thanks for info Pete it was rough insert of code too test it, on my list too clean it up now.
Hi toro
I added delay as last minute thing just testing.
Ok I miss understood how it works thanks for clarifying that up.
Thanks for help everyone, post is SOLVED :smiley::smiley:
