Hi friends. I have problem with my sketch and soil moisture sensor. the sensor show high value when outside the water and show low value when inside the water. where is problem ?
the V1 is showing waterlevel in percent
#include <FS.h> //this needs to be first, or it all crashes and burns...
//#define BLYNK_DEBUG // Comment this out to disable debug and save space
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
//for LED status
#include <Ticker.h>
Ticker ticker;
#include <ArduinoJson.h> //https://github.com/bblanchon/ArduinoJson
char blynk_token[34] = "bacd4b889a5547379c07ec0cda1f269e";
char server[] = "192.168.1.104";
const int sensorPin= A0; //sensor pin connected to analog pin A0
float liquid_level;
int liquid_percentage;
int top_level = 500; //Maximum water level
int bottom_level = 0; //Minimum water level
bool shouldSaveConfig = false; //flag for saving data
void tick()
//toggle state
int state = digitalRead(BUILTIN_LED); // get the current state of GPIO1 pin
digitalWrite(BUILTIN_LED, !state); // set pin to the opposite state
void saveConfigCallback () { //callback notifying us of the need to save config
Serial.println("Should save config");
shouldSaveConfig = true;
ticker.attach(0.2, tick); // led toggle faster
Serial.println();
pinMode(sensorPin, INPUT);
Blynk.virtualWrite(V0, liquid_level);
Blynk.virtualWrite(V1, liquid_percentage);//This wil show the percentage of water in the container in a virtual pin V1
//set led pin as output
pinMode(BUILTIN_LED, OUTPUT);
// start ticker with 0.5 because we start in AP mode and try to connect
ticker.attach(0.6, tick);
//SPIFFS.format(); //clean FS, for testing
Serial.println("Mounting FS..."); //read configuration from FS json
if (SPIFFS.begin()) {
Serial.println("Mounted file system");
if (SPIFFS.exists("/config.json")) {
//file exists, reading and loading
Serial.println("Reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
Serial.println("Opened config file");
size_t size = configFile.size();
// Allocate a buffer to store contents of the file.
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
json.printTo(Serial);
if (json.success()) {
Serial.println("\nparsed json");
strcpy(blynk_token, json["blynk_token"]);
Serial.println("Failed to load json config");
Serial.println("Failed to mount FS");
//end read
// The extra parameters to be configured (can be either global or just in the setup)
// After connecting, parameter.getValue() will get you the configured value
// id/name placeholder/prompt default length
WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 33); // was 32 length
Serial.println(blynk_token);
//WiFiManager
//Local intialization. Once its business is done, there is no need to keep it around
WiFiManager wifiManager;
wifiManager.setSaveConfigCallback(saveConfigCallback); //set config save notify callback
//set static ip
// this is for connecting to Office router not GargoyleTest but it can be changed in AP mode at 192.168.4.1
//wifiManager.setSTAStaticIPConfig(IPAddress(192,168,10,111), IPAddress(192,168,10,90), IPAddress(255,255,255,0));
wifiManager.addParameter(&custom_blynk_token); //add all your parameters here
//wifiManager.resetSettings(); //reset settings - for testing
//set minimu quality of signal so it ignores AP's under that quality
//defaults to 8%
//wifiManager.setMinimumSignalQuality();
//sets timeout until configuration portal gets turned off
//useful to make it all retry or go to sleep, in seconds
wifiManager.setTimeout(600); // 10 minutes to enter data and then Wemos resets to try again.
//fetches ssid and pass and tries to connect, if it does not connect it starts an access point with the specified name
//and goes into a blocking loop awaiting configuration
if (!wifiManager.autoConnect("CentralHeatingAP", "MY123PWD")) {
Serial.println("Failed to connect and hit timeout");
delay(3000);
//reset and try again, or maybe put it to deep sleep
ESP.reset();
delay(5000);
Serial.println("Connected Central Heating System :)"); //if you get here you have connected to the WiFi
ticker.detach();
//turn LED off
digitalWrite(BUILTIN_LED, HIGH);
strcpy(blynk_token, custom_blynk_token.getValue()); //read updated parameters
if (shouldSaveConfig) { //save the custom parameters to FS
Serial.println("saving config");
JsonObject& json = jsonBuffer.createObject();
json["blynk_token"] = blynk_token;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("Failed to open config file for writing");
json.printTo(configFile);
configFile.close();
//end save
Serial.println("local ip");
Blynk.config(blynk_token, server);
Blynk.connect();
liquid_level = analogRead(sensorPin);
liquid_percentage = ((liquid_level-bottom_level)/top_level)*100;//Percentage of water in the container
Serial.println(liquid_level);//This will print the liquid level in the monitor
Serial.println(liquid_percentage);//This will print the percentage of liquid in the monitor
delay(100);
